Question about Zyxel Prestige 660HW Wireless Router (PRESTIGE660HW)
Access to my settings
When I type in I only get internet options and cannot access my settings
  • raythedon Feb 07, 2008
    thanks for trying but still have the problem
It seems to be the most common problem not been able to get into your router settings -check this out go to start on your computer -click on run -type in cmd and run it.A black box will appear,where the cursor appears type in ipconfig /all then scroll to default gateway write down the address it gives you ie 192.168.etc,then use this in your address bar to get you into your router..............maybe........otherwise call your support line.
Hope that helps.........
Posted on Apr 18, 2008
    Problem Solver:
  • 21 Answers
Make sure that is your default gateway. go to your command prompt and type in 'ipconfig'. Use your default gateway to access your configuration settings.
Posted on Feb 07, 2008
  • edhel joy callo Feb 08, 2008
    >> ok! so if is really your default gateway, type that to your run field. type inside run'. i hope that works. Also make sure to check 'prompt for username and password' on your IE configuration settings.
How to Activate internet settings for java applications in Nokia e72?
To activate internet settings for applications, you need to define an access point (or "Destination") in your E72. Here's how:
1) Open Menu by pressing home key.
2) Goto "Ctrl. Panel"
3) Select "Settings"
4) Select "Connection" tab.
5) Select "Destinations" option.
You will see different destination or access point types such as "Internet","Multimedia msg." and "WAP services" etc. Some java applications use standard Internet access points while some use WAP settings. To activate internet settings click on the "Internet" option. Then use your left soft key to open menu and select "New access point" to create internet profile for your applications. You can have multiple settings and order of the profiles define priority. (e.g. 1st profile in list will be used first and if not available, only then the 2nd will be used)
Mar 04, 2011 | Computers & Internet
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
Blank page when opening a new tab in IE 8. I reset advanced options, didn't work. Do I need to check a box in there
Access the Internet Options dialog box. If the menu bar is visible, you can select "Tools" - "Internet Options".
If the Command Bar is visible, click the "Tools" button and select "Internet Options". If neither are available, try typing Alt + T then O.
When the "Internet Options" dialog box appears, underneath "Tabs", click the "Settings" button.
The "Tabbed Browsing Settings" dialog box appears. Underneath "When a new tab is opened, open" click the pull-down and choose from any one of the following options:
  • * A blank page
  • * The new tab page
  • * Your first home page
Click "OK" on the dialog boxes to store your settings.
Jul 06, 2009 | Microsoft Internet Explorer 8
Unable to access internet through local area network.
in this case first you need to check the ip address by goin on start- run - type cmd -- then type ipconfig , if its giving you a valid ip address then try to access internet and select the option that says automatically detect settings and you will find that option under -- open internet explorer then go to tools- internet option- connections - lan settings
if you are not getting any ip address then do a right click on my compuetr icon on your desktop adn go to properties-- hardware- device manager-- network adaptors - and uninstall all the adaptors and then do a right click on network adaptors and then scan for hardware changes .
and the third option is to uninstall Internet explorer 8 adn try with IE 6
kindly rate this solution as well
Mar 24, 2009 | Microsoft Internet Explorer 8
Can;t use intent on mobile
Here is what you should do step by step:
I.Configure your Computer
1.Install Bluetooth Adapter
2. Bluetooth Configuration->Local Services-> Add Serial Services ->Bluetooth Serial Port->Properties
Check – Startup Automatically
Check – Secure Connection
COM Port: COMx( mine is COM6)
3.Control Panel -> Phone and Modem Options->Modems->Add-> Check Don’t detect my modem->Next->(Standard Modem Types)->Communication cable between two computers->Next-> on witch port do you want to install it ? -> Selected ports -> COMx ( in my case COM6)->Next->Finished
Now in phone and modem options->Modems you should have : Communications cable between two computers : Attached to : COMx ( COM6 my case)
Select Communications cable between two computers -> Properties->Modem-> Maximum Port Speed : 115200 -> ok ->ok.
4.Control Panel ->Network Connections ->Create a new connection-> Next->Set up an advanced Connection-> Next-> Accept incoming connections->Next-> Check : Communications cable between two computers ->Next-> Check: Do not allow virtual private connections->next->next->select: Internet Protocol(TCP/IP)->Properties:
Network access : Check Allow callers to access my local area network
TCP/IP address assignment : Specify TCP/IP addresses:
To: 192.168.0.y (y=52 in my case)
5.Network Connections
Bluetooth Network -> Enable
Internet Connection ( your internet connection ) -> properties->Advanced->Check:Allow other network users to connect trought this computer’s Internet Connection->OK
If all goes well : Bluetooth Network-> Properties-> Internet Protocol ( TCP/IP)->Properties Should have the following setting:
Checked Use the followind IP address:
IP address:
Subnet mask:
6.Start->Control Panel->Administrative Tools->Services->Routing and remote access->Properties->General: Startup type : Automatic - this service MUST be started
**7.Install AnalogX Proxy (for the latest version)
Proxy->Configure-> Proxy Binding: 192.168.0.x ( for me x=50 )->ok.
! If you use a proxy, remember to start it .
II. Configure Phone:
1.Install GnuBox - ( for the latest version)
2.Configure Access point
Tool->Settings->Connection->Accces Points-> New Access point->Use Default Settings
Connection name: Bt
Data Bearer: Packet data
Access point name : Bt
User name: none
Promt Password: NO
Password: ****
Authentication: Secure
Homepage: none
Option->Advanced settings
Network Type: IPv4
Phone IP address: Automatic
Name Servers: Automatic
**Proxy serv. Address: 192.168.0.x ( for me x=50)
**Proxy port number: 6588
3.Configure all the applications from your phone witch require internet acces to use Bt Access Point
4.Configure GnuBox
Options->Install Set to GPRS
Options->Install Create Records
Options->Install->Copy settings from GPRS
Options->Install->set RAS login script
Exit GnuBox
Open Gnubox
Options->2box Bluetooth->Serial Port
Select – your computer
Do you want to require encryption? Yes
Options-> Install->change default AP
** Configure NetFront
Enable Proxy : Yes
Proxy Host : 192.168.0.x ( in my case x=50)
Now you can browse the internet from your phone.
NOTE: First Configure the phone and your pc without the ** settings, and if you can’t browse the Internet form your phone then use the ** settings.
Hope this works fine.Thank you.
Nov 25, 2008 | Computers & Internet
Error code 80048820
MSN Message error 80048820, unable to signin
- While you try to Sign in MSN Messenger you getting an error message with the no. 80048820
- Unable to Sing in
Probably reasons-
- Your system time/date incorrect
- Internet Proxy setting incorrect
- softpub.dll disable/missing
- Firewall does not allow to access, etc.
- Remove Internet Explorer proxy server settings and check the 'Automatically detect settings'.
- Launch Internet Explorer, click "Tools" and then click Internet Options. From the Internet Options dialog box, go to the Connections tab. Click LAN Setting. Uncheck the Use a proxy server for your LAN checkbox. Finally tick/check: 'Automatically detect settings'.
- Correct the computer system's Time/Day as current (if required).
- Click Start (Button), and then click Run, type regsvr32 softpub.dll click ok.
- Turn off the firewall. Check firewall settings such as Norton: "Block access to secure sites". If this cures the problem, make sure that Microsoft's MSN Messenger is allowed full access through your firewall.
Reference from:
Aug 12, 2008 | Computers & Internet
Internet access for samsung e250
Check your internet connections on your phone. And ask samsung customer care and make themselves to set your fone's internet settings. All the best.
Oct 05, 2007 | Samsung SGH-E900 Cellular Phone
Zyxel Prestige 660HW Wireless Router (PRESTIGE660HW) Logo
113 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
