Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Replaced gears, now only moves about 3 feet
My opener was acting up then"froze". I opened it up and saw the gears were shot (white plastic snow everywhere and worn down gear), I replaced the gears and now it moves, however, it only moves about 3 feet then reverses. It does not even go far enough to hit the up/down settings/sensors. I have unplugged it, played with tension, up/down settings etc with no success. Thoughts?
  • 2 more comments
  • Tim32 Feb 07, 2008
    I actualy have the door unhooked and yes, the door itself opens and closes fine so no rail issues. Tension adjustments won't matter if door is not locked on right or should I hook door back up? As for limit adjusters the door (the thing the door locks onto) is stuck in a 3 foot path between the stops, meaning it does not reach the up sensor or return to the down sensor. Just moves very slightly in the open space between them...
  • Ed_flyfish Feb 11, 2008
    I have the same problem, but I already have the rpm sensor in place. Could the rpm sensor be bad? I unplugged the circuit and had the same results. I removed the chain and limit sections as well. I also tried to adjust the tension to both extermes without success.
    My earlier comment asked if the rpm sensor was bad. I have the end cap in place. I was not implying that the end cap was the sensor, but the eye that it passes through. Could it also be a sensor alighment problem?
  • rubbishman Mar 01, 2008
    The top gear that drives the chain broke off of the opener, so I replaced it with the new gears. Now when I try to open the garage door it only moves maybe 7". Itryed to set the force and limmit switch with no effect. Is there some sort of way to reset the opener?
Fixed it earlier tody...I hate to admit it but I forgot to put the RPM sensor back on the end cap...(actually, I put it on the otherside of the motor)...nice move huh?
Posted on Feb 07, 2008
    Scholar:
  • 163 Answers
Look for a screw adjustment for the ammt of load it will accept.. Generally a screw adjust on the back.. Providing its not binding. If you release will it open by hand normally? Some also have up/down limit adjustments and maybe the gears werent timed right to coincide after they got chewed up..
  • Ken LaDere Feb 07, 2008
    Sounds like the gears are not timed with the rest.. Or there could be excessive force on the drive chain you cannot see.. Unhook this as well or look for an obstructed link/Bad drive gear tooth. Somthings hitting a block period)..(Turn down force adjust so as not to damage new gears)..There is a way to Zero all of it and it should be ok..
    (Why do I get myself into these)? because I like to fix everything...
    Good luck bud!
  • Ken LaDere Feb 09, 2008
    Hey.. Things happen..
Powerland auger not turning. shear pins are in tact. drive belt replaced
you might have blew the gear box
if you can move large auger without anything else turning gear is shot
Feb 15, 2014 | Powerland Snow Blower Professional 389CC...
2005 dodge durango rear hatch will not unlock to open
I own a 04 durango and the door lock actuator froze up internally and I could not open the rear hatch. After hours of research on my computer nothing seemed to fix the problem. I eventually figured it out myself. You must pull the screws out of the molding on the inside of the rear door. You can now pull the molding toward you and look down at the actuator and latch. You can pull on the molding quite a bit if necessary. I never broke mine and I was pretty agressive with it. Now, on top of the whole mechanism is the lock actuator. There should be a white plastic lever sticking out towards the driver side. If you can slide it from back to forward "forward is front of vehicle", the lock should be working. If not your door is not unlocking. My durango had 3 Torx screws on top of the actuator. Remove them. This will take the actuator off of the latch. Now that the actuator is not binding or holding the lock from moving, again try to move the white plastic lever towards front of vehicle. It should click and you should be able to open the door.
Oct 12, 2011 | 2005 Dodge Durango
My door opener is a Searcraftmans 1/2 hp. The door opens about 2 feet and stops. Press the button and it closes. Door moves freely when disengaged. Any suggestions
You most likely have a stripped drive gear. Remove the cover from the motor unit and it will be obvious if this is the case. It is a white nylon gear just in front of the motor.
Jan 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
My Liftmaster pro motor runs but won't move on terack even with the door disconnected and track lubed. Chain does not appear to be out of adjustment either.
Take off end panel with light bulb (4 screws). See lots of white "powder" inside. Yes. Gears are shot. Replace gears or whole unit.
Dec 28, 2009 | liftmaster Chamberlain Garage Door Opener...
Door stopped opening!?!?!?!
Remove the cover of the motor unit and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad.
Dec 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Shimano 70gs rear derailleur won't shift. The thumb levers move but don't engage. Can I fix it or will it have to be replaced.
I just had the same problem with my wife's old bike. After removing the cover (as explained in answer #2), I saw that the pawl (the part that engages the ratchet)was stuck in the open position because the grease had dried up. A shot of pbblaster (or WD40) freed it up and everything is now working fine.
Jul 26, 2009 | Cycling
2005 dodge durango rear hatch is down and will not open
Feb 08, 2009 | 1995 Subaru Legacy
Motor sounds like it is running but sprocket doesnt move
how old is unit. sounds like gears are shot, takes $25 of parts and 2-3 hours to fix if you are handy. Take cover off, If it has white powder (Not ****), gears are shot.
Jan 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will not open or close
I had the same problem, mine was just the white Sprocket assembly, it stands straight up, there is another one which is the Worm gear, mine was fine. I read on some other post, when you take off the panel, and if you see a lot of white dust (shredded white plastic) then its the gear. Went to Sears warehouse, had the part in stock and replaced it myself. Had to just unbolt the Sprocket assembly from inside (3 bolts), pull out from the top, a little hassel, but got it done. Follow the instructions and you will be fine. Remember after greasing up the sprocket like it says too, take the time to use some silcone spray on the springs and rollers, a lot of people forget to do this, even me...
Dec 20, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
143 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
