2001 Daewoo Nubira Logo
Anonymous Posted on Jan 10, 2010
2001 Daewoo Nubria heater stopped working and is now overheating
My heater worked perfectly fine one day and then the next night when I got in it the heater just blowing out cold air. Thne once car warmed up it started to over heat. In the warmer months I was low on antifreeze and I added water, and didn't think nothing of it until it became colder. When I started to have these problems my husband drained my radiator and put anitfreeze in it. It still did not work, next thing he done was replaced my thermastat. Needless to say that did not fix my problem. At the moment he is not working and I do not have the money to put it in a garage. My husband dosen't know a whole lot about vehicles but if we can get a general idea as to what may be the problem then he can figure out how to fix it.Any help would be greatly apreciated thank you very very much
Jonah Oneal
Level 3:
  • Daewoo Master 14,092 Answers
  • Posted on Jan 10, 2010
Jonah Oneal
Daewoo Master
Level 3:
Answers
14092
Questions
0
Helped
7241576
Points
44533
CHECK COOLANT AGAIN IF IT GET LOW HEATER WILL STOP BLOWING HEAT.
Where is the fuel reset button on a nubria deawoo
Remove the passenger side front rocker trim panel. Remove the lower B--pillar trim panel. Reposition the carpet. There is the fuel cutoff inertia switch with reset button.
2001 daewoo nubria overheating
The Daewoo range of cars have two main problems with cooling system the thermo switch under the coilpack (2 pin) very rarely ever works properly over 20 c this means that your fans do not switch on when the car is hot, easiest way to check switch aircon on and the fans should work , if they don't .replace with an after market switch and relay can be bought from parts accessories stores , the radiators are by far too small they can be replaced with minor fabrication ( sheetmetal) by a Vt-Vy radiator v8 is best in all cars for overseas the Pontiac 2001-2006 check your measurement and with a couple of new hoses and a extension to the bottom hose the over heating disappears if there is milk coloured oil under your oil fill cap your head or possibly motor may need to be replace the best engine out of these engines is either the c20 sel or the c22sel
2helpful
My heater stopped working on my 2001 daewoo leganza.The air conditioning works fine but it dispense no heat at all.It is a used car so I am not sure if that has anything to do with the problem.Can someone...
Your heater core is probably clogged or bad. It is usually on the passengers side under the glove box. You may also want to check the heater valve on the hoses. Its a control valve that hooks by one of two hoses running to the fire wall. They also go bad. A much simpler fix the replacing the heater core.
I need a turn signal flasher for my 2001 Deawoo Nubria or an idea what other make will work
Take the part # of the old one and a parts dealer should beable to cross referance one for u. Hope this helps.
My 2991 Daewoo Nubira is overheating. I drive about 10 miles to work. Sometimes I can go days without it overheating. I put water in it before I leave for work and again before comibg home. When the...
Check for the cooling fans working or not,also the thermostat,it can be stuck,and the coolant level maybe dropping and getting air in the system.
8helpful
TIMING MARKS FOR TIMING BELT ON A 2001 DAEWOO NUBRIA
CLICK on the following LINK. It has the Timing Belt and Mark Diagrams you will need.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/2001/make/daewoo/model/nubira/2001_daewoo_nubira_timing_belt_diagram_marks.htm
Car overheated one day the fine the next but no
your heat is not working becuase the coolant level is too low meaning your heater core is full of air. the reason your car overheated is because the water pump impeller splines are gone and you need to replace the water pump. it is driven by the timing belt so replace that too. and the tensioner. this is the number one cause of vw overheating, especially on a diesel. i have replaced about 50 water pumps on this engine because of this.
Top Daewoo Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Daewoo Expert? Answer questions, earn points and help others
