Question about Samsung SF-560 All-In-One Laser Printer
Displays toner empty but have replaced cartridge
We have replaced the cartridge, checked the fuse and turned it, as suggested, its still displaying it, the manual is no help. please someone its driving me mad!!
  • aimeecornell Feb 07, 2008
    how the heck do you do that?????
    Genius:
  • 3,587 Answers
Well..believe it or not, the software that 'reads' the ink levels, CAN sometimes corrupt. You might need to re-install that software set, to get a good reading. IT's one of those 'features' that looks good on paper, yet MAY not always be accurate(like a gas gauge in older cars, that would 'stick' in one position, and leave you stranded on side of road.
Got backup?
Posted on Feb 07, 2008
  • Patrick Michaels
    Patrick Michaels Feb 08, 2008
    the drivers are either on your CD or at the website, under support.
The printer samsung scx-452f cannot print out fax in,it shown on screen as memory receive
you have received faxes, but they can't be print until you replace toner because probably you have TONER EMPTY message also on the display.
You can buy only fuse for toner cartridge (25mm, 250V/ 0,063A or 0,1A and maximum 0,125A)
When you pull out toner cartridge you will see the glass fuse on the front left side of the cartridge.
The new fuse will reset toner empty condition
pifonski
Feb 28, 2011 | Samsung SCX 4521F All-In-One Laser Printer
I PUT A NEW TONER AND IT IS SAYING THERE IS EMPTY
Are you sure it was a full NEW toner cartridge?? Not an old one you had lying around.
If it was a new one the next question line goes as follows.... the machine will say in the display to "Rplace toner soon"...that dosn't mean its empty and to replace it..that means itsLOW and you should have a new toner cartridge "on-hand" because it will soon stop printing and say "REPLACE TONER". At that time the toner cartridge should be replaced, when it is installed a "fuse" on the cartridge blows and resets the toner light on the display. If you installed the toner cartridge when the display was saying "replace toner soon" you have blown the fuse in the new cartridge, now the machine has run about another 100 copies and says "replace toner"....but you now can't reset the light because the fuse is already blown because you may have replaced the cartridge too early!!! WHAT CAN YOU DO if that is the case...you can replace the fuse on the cartridge..its pretty easy to see, just replace it with another mini-fuse of the same rating written on the existing fuse..then put the cartridge in again..the fuse will blow, reset the light and away you will go. When all else fails read the operators manual.
Jan 23, 2011 | Muratec MFX-1430 Copier
Error code"toner exhausted" what to do?in samsung scx 4300
toner exhausted = the toner has been used all up, buy a new one.
It's something like
http://www.tronix.ro/toner-samsung-scx4300-p-9783.html
May 27, 2010 | Samsung SCX-4300 Monochrome Laser...
How to solve CRU Fuse error ?
Check the TONER Cartridge and Reinstall it
CRU Fuse Error
Means : The toner cartridge is not installed correctly
You can set the machine to ignore the “[Toner Empty]”
message and to continue printing incoming faxes.
Ignoring the Toner Empty Message
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button < or > until “Ignore Toner”
appears on the bottom line and press Enter.
3 Press the Scroll button < or > to select “On” or “Off”.
Select “On” to ignore the [Toner Empty] message.
Select “Off” to stop printing incoming faxes when the
message appears. This is the default setting.
4 Press Enter to save the selection.
5 To return to Standby mode, press Stop/Clear.
Jan 21, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Muratec mfx 1600 drum replaced alarm will not reset
When the toner cartridge is empty, the machine shows a “Toner Empty”
message and stops printing.
You can set the machine to ignore the message when it displays and to
continue printing the pages.
2 Press the scroll button (�� or ��) until “Ignore Toner” appears on the
3 Press the Scroll button (�� or ��) to select “On” or “Off.”
Select “On” to ignore the Toner Empty message.
Select “Off” to stop printing when the message appears. This is the
default setting.
Jun 18, 2009 | Muratec F320 Plain Paper LED Fax
Can't receive fax but can send fax
I have a feeling that it is a re-manufactured or compatible cartridge??
There is a fuse that needs to be replaced on this unit. it blows when the cartridge is installed to reset the machine. If the fuse has not been replaced or is defective the machine will not recognize the new unit.
Feb 12, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Error message: invalid toner yellow
If the toner is empty it will display this message and the only way I know of getting rid of it is to replace the cartridge. They do make refill kits with extra chips so you can cut the old one out and sticky tape another on. As for a clearing code I am unaware of one for this unit as the information is store in the toner cartridge.
Sorry
Jan 06, 2009 | Samsung CLP-600N Laser Printer
Replaced Toner and Still Wants it to be replaced
You need to manually reset the CRU counter in the service menu to reset the toner count. This is designed so the xerox tech can come in and get paid for work. What you do is the following:
Enter the service mode by turning the machine off....then hold the (i) button and (<) arrow button simultaniously while turning the machine on. Then go down to nvram access enter menu, then go to CRU menu. Then go to the Toner CRU count menu, then select the toner you wish to reset and allow the machine to reset.
IF you need any parts feel free to come to my store
Andrew www.Getthatpart.com
Apr 23, 2008 | Xerox Phaser 7300DN Laser Printer
"toner empty" problem
The samsung sf 5100 toner cartridge has a .05 Amps fuse in it. This gets blowed when you switch on the machine.This is used to reset the page counter and also to inform the machine that you have inserted a new toner. Now this recycled cartriges will not have this fuse and this is the reason why your machine shows TONER EMTY message! If you dont get the same rating fuse, put any fuse of the same size, insert the toner, close the door and just switch on the power and switch off immediately. Then take out the Toner cartridge and remove the fuse. Now your cartridge is ready for use.
Dec 06, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Samsung SF-560 All-In-One Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
