Question about Microsoft Windows XP Professional for PC
Driver installation after installation of windows Xp , i tried to install the drivers. But it shows "process timed out"
  • 5 more comments
  • sarada Feb 07, 2008
    audio and video, USB drivers
    After farmatting my Pc with windows Xp, i tried to install the sound, video, Usb andother drivers, it shows the error that Windows installer not found and some files are missed. what to do?
  • sarada Feb 08, 2008
    my mother board is intel 845
  • sarada Feb 14, 2008
    i have installed two operating systems in my pc.
    1.windows xp
    2.windows xp media center edition
    while i tried to login using windows xp , it displays an error "hal.dll" may be not existed or it is corrupted. re-install it.
    what to do now?
    when i logged in using media center edition, i tried to install nero s/w, it gives an error as"windows are ruuning in safe mode or windows installer not properly installed. plese give me the solution.
    i tried to install nero for writing cd/dvd, office xp, and other softwares are not installed.
    for the first time, i was installling windows xp using bootable cd, it accepted the id on the cd. but now, it is giving an error as ivalid product id. what should i do?
  • Carl Sizemore
    Carl Sizemore May 11, 2010
    What device or program are you trying to install drivers for?
    Problem Solver:
  • 8 Answers
You are using the original mother board so when you are installing the cd, instead of autorun it is giving the message processed timed out. Now do one thing go into the cd through explorer then go into each directory of the drivers you want to install (eg. for sound go to sound directory and so on.... ) and I know that your all the problems will be solved. 100 % guaranteed
Posted on Feb 07, 2008
  • Dipanjan Roy Feb 07, 2008
    will u give me the model of the motherboard ( 845 or .... ) u r using I will give u the total solution for it and the result will be positive.
  • Dipanjan Roy Feb 08, 2008
    In your cd there is a directory by name SOFTWARE and in that by the name DRIVERS an in that you will get AUDIO, USB2.0, VIDEO, from that you install the softwares which should work for you.
What driver do you want to install? for what use?
Can't install audio driver
Hi!
Please try several things:
1. Try to delete your device from device manager if it exists there: right click on "My Computer" -> Manage -> device manager. Then - right click -> Scan for hardware changes, insert media with your driver software and/or let windows automatically search for driver.
2. Try to reboot in Save mode (reboot, press F8 until booting mode selection appears and choose save mode) and install driver in save mode.
3. If none of above helps - try to update your Windows XP and then try to install driver.
4. Try to change audio adapter physical slot - open your PC and just insert it to other PCI slot (also - de-dust your slots before :) ).
5. Try to unpack driver and manually select it during windows driver installation process (choose not to connect to internet when wizard asks -> Install from a specific location -> Don't search I will choose the driver to install -> Have disk -> browse -> select .inf file and click ok).
Hope this will help. Good luck!
Jul 02, 2010 | Intel ESS ES1868F Sound Card
We install windows xp prodesional on this motherboard, but it shows absence of audio driver. what is the reason?
If you got new motherboard you should have got new driver of driver which is the need of your motherboard.
Install your driver inside the CD-ROM or DVD-RW to run your disc on computer.
Add your driver by following the instructions of the installation process.
If you have not the same driver then find it by right clicking on the my computer>device manager
And then find your audio driver.
Feb 27, 2010 | EliteGroup P6STP-FL Motherboard
I bought lenovo G550 last week. It came with Windows Vista. I want to install Windows XP on it. I have found that lenovo has driver for windows XP so that will make my life easy :-) But when I try to...
you are most likely getting a BSOD with a stop error code of 0x0000007B which is caused by the Windows XP CD that you are using doesn't have the SATA Hard Drive controller driver needed to recognize and utilize the hard drive. If Lenovo has XP drivers for this model then they should have a SATA driver (roughly 394k) that will need to be loaded FROM A FLOPPY DISKETTE during the boot to XP. (XP Requires the driver to either be slipstreamed into the CD or loaded from a floppy diskette. Trying to load the controller driver USB or a different CD will not work)
http://www.digitgeek.com/how-to-slipstream-sata-drivers-into-xp-cd/
Jan 11, 2010 | Computers & Internet
My aspire is installed with windows xp no drivers but CPU running
Within TASK MANAGER, click the "Processes" tab.
Click the 'CPU' column-heading.
Click it a second time.
Now, each process will be listed in order,
with the TOP-MOST lines showing the processes that are consuming the largest share of the CPU.
Nov 06, 2009 | Acer Aspire 3050-1733 Notebook
VGA problem
plz dont use vista !
use xp for game performance ...ur vga driver may not have the ability to install
so use xp
thank u.....
Aug 06, 2009 | Viper Diamond ATI X1600 PRO AGP 512MB...
Installation problems SamSung ML 2510 printer with Windows XP
Why no updates? No windows validation? That could be your problem if that's the case.
If not, I suggest going to Windows update and at least installing all critical updates, if not SP3 as well, and try again
May 18, 2009 | Samsung ML-2510 Laser Printer
Bluetooth driver (bluetooth hands-free audio) wont install, access denied
me too have that problem, i updated me XP SP2 to SP3 and failed to install bluetooth, then i removed SP3 and re install bluetooth, it worked fine, as my comment, reinstall ur OS to windows XP SP2 and try.
May 03, 2009 | Computers & Internet
Acer Aspire M1640 shows a blue screen while installing windows xp pro
Mar 05, 2009 | Computers & Internet
Hanging on detection of drive when installing Windows XP
Installing Windows XP on a SATA hard drive is not a straight-forward task as Windows XP does not recognize the SATA drive. In order to install operating systems such as Windows XP on SATA drives, the latest SATA drivers are required.Download SATA drivers for the motherboard from the website and integrate them with the XP installation CD using software such as nLite. SATA drivers can also be installed as third party drivers; you will be prompted during the installation process. Without proper SATA drivers, installing Windows XP on a SATA hard drive is not possible as SATA mode would have to be disabled in the BIOS to continue with the installation.
Installing Windows XP on a Serial ATA hard drive is not an easy task, because the system does not recognize SATA drivers at startup. Windows XP Pro SP2 fares a little better with SATA drivers, but here is what can be done in cases where the driver is not recognized.
Mar 31, 2017 | Excelstor Technology J880 Hard Drive
Acer laptop aspire 4710z config my notebook have problem
There could be an issue with the user accounts logins. This could be corruption in the OS when you installed it or a clashing driver . I would recommend you reinstall the Operating System with the Disks and before you start installing the drivers try to shut down and see if it shuts down properly . If it does then you know the Operating system and hardware is all fine and can continue installing one driver at a time and shutdown and restarting, continue doing this until you see which driver is causing a confict with your system. I have had a problem similar to this but it was some windows updates pack that I had done one time and had to reinstall windows too and do one by one. Hope my answer gets you closer to a solution.
Aug 07, 2008 | Acer Aspire 5500 5570-2609 Laptop
Microsoft Windows XP Professional for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
