Question about HP StorageWorks ESL712e Ultrium (AA934B) LTO 2 Tape Drive
Ultrium LTO 3 Tape Autoloader Error
Hi. Our HP Proliant RedHat EL3.4 server is hanging after we make a backup with the HP Ultrium Tape autoloader. The server has been running backups for a year without any problems. The tape loader shows error code :13 00 *R*, but i cant find any error code descriptions.
Can any one help?
  • 30 Answers
What software are you using? try not backing up the system state to see if that changes anything?
Posted on Jul 24, 2009
How do I remove a tape cleaning System Storage TS2900?
how to remove a cleaning tape????
Just export it from the tape drive to the mail slots...
Sep 26, 2014 | IBM System Storage TS2900 LTO Ultrium 3...
Power supply issue. Would like to know procedure to replace power supply on dell powervault 122t autoloader.
these units have 2 different possible power supplies. KM88 or KM 86 KM88 are more rectangular, km86 have an angle cut in it. you could send it in to a repar facility like Top Ten USA, or try to solder the fuse yourself.
Aug 11, 2011 | Dell PowerVault 122T LTO (pv122tlto)...
I am getting a DRV PREV REMOVAL TYPE (46) message on display, every time I try and Inventory a tape or run Lable Media.
I have two of these Quantum SuperLoader 3 (with LTO3 drives) and one does keep giving me the same hassle. I haven't figured out how to fix this, but I've gotten past the error: disconnect the autoloader from the host computer (i.e. or stop rsm, mtx, or whatever controlling sofware you use), reboot the autoloader, get the tape out of the drive (e.g. move command from the autoloader's console or web interface), insert a cleaning tape (a few times), reconnect everything (i.e. start back up your controlling service).
Nov 29, 2010 | Quantum SuperLoader 3 LTO-3 Tape Drive
I have a Quantum CL1105 8 slot autoloader (LTO3) and using Bakbone Netvault backup software. I can use HP or Tandberg brand cartridges successfully but if I use Imation or Sony brand cartridges the backups...
Mixing brands can be an issue because different brands might use different lubricants on the tape it self.  I would check with the vendor - are are you positive you are using the excact same LTO version?
Jan 21, 2010 | Quantum (CL1105-SSE) (CL1105SSE) LTO-3...
Pc Freezes when attempting to access HP SSL-1016 Ultrium 460 Tape
I have to admit this is a tough one. You seem to have tried most things i would try 1st.
I would suggest trying to download an eval coy of another backup program such as backup exec 12.5 from the symantec website and trying that.
This enables you to eliminate the backup software from your enquiries and if you also enable BUEX to use its own drivers (rather than the standard windows drivers) then that is another thing eliminated.
http://www.trilan-it.com/ are pretty good near the Berkshire area if you need a field call to help sort the issue but i would try BUEX 1st as that will help diagnose the problem even if you dont wish to continue with their software
Apr 16, 2009 | HP StorageWorks 18 Ultrium 460 Autoloader...
I am unable to get IBM UlTrium TD4 SCSI device drivers for windows 2000 server
if you "have not" using Backup Software (e.g. Symantec Backup Exec, CA), you can try this IBM LTO-4 driver for Win2K.
IBM LTO-4 Device Driver for Windows 2000
Ned Huang
Tandberg Data Taiwan
Technical Support.
Oct 15, 2008 | Computers & Internet
HP LTO Drive Firmware Revs For Veritas 9.1
The problem you described is not a driver problem. So long as you are using the Veritas drivers you should be good to go.
SCSI time-outs and disconnects are hardware problems.
Sometimes they can be resolved by changing the throughput settings on the SCSI controller connected to the drive. Controllers usually default to very high speeds because they are used for hard drives. Lowering the speeds to support the slower throughput of tape drives can sometimes help.
During the POST there should be a key combination you can press to access the setup for the controller and modify the throughput settings.
Aside from that you have to replace the SCSI controller or tape drive until you figure out which one is causing the problem. Maybe the SCSI card is not seated properly.
I hope this helps.
Nov 18, 2007 | Veritas Backup Executive V9.1...
Adic faststor2
Try changing the autoloader SCSI ID and the tape drive SCSI ID at the front panel:
Use this option to view or change the SCSI IDs used by the autoloader. The autoloader occupies two SCSI
IDs, one ID is assigned to the autoloader and the second ID is assigned to the tape drive.
The default SCSI ID for the autoloader's SCSI controller is 0. The default SCSI ID for the tape drive is 5.
You only need to change a SCSI ID if there is another device, or devices, already assigned to these IDs.
NOTE: This option is primarily used if the autoloader is in an error state. However, any
backups that have not been verified as complete should be considered lost.
NOTE: If you changed the SCSI ID, you may also need to cycle power on the host
system and reconfigure your backup software before you can use the
autoloader. Consult your hardware and software manuals for more information.
Dec 27, 2006 | ADIC FastStor2 LTO (90024202)
HP StorageWorks ESL712e Ultrium (AA934B) LTO 2 Tape Drive Logo
1,038 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
