Please select last known good configuration from the black screen if this doesnt work select safemode from that screen and restore your computer to earlier time when it was working fine,. please follow the steps below to restore your computer.
Use System Restore
After you've decided to use System Restore to revert your system to a previous state, start the System Restore Wizard and follow the prompts. To use the System Restore Wizard, make sure you're logged on as an administrator, and then follow these steps:
1.
Click
Start, point to
All Programs, point to
Accessories, point to
System Tools, and then click
System Restore.
2.
On the Welcome screen, click
Restore my computer to an earlier time, and then click
Next.
3.
On the
Select a Restore Point page, select the date from the calendar that shows the point you'd like to restore to, as shown in Figure 2, and then click
Next.
Figure 2
4.
On the
Confirm Restore Point Selection page, verify that the correct restore point is chosen, and then close any open programs.
5.
Click
Next if you are ready to proceed or click Back to change the restore point.
6.
The computer will shut down automatically and reboot. On reboot, you'll see the
Restoration Complete page, and then click
OK.
After reviewing the stability of your system, you can choose another restore point or undo this restoration. Just open System Restore and make the appropriate choice. After you use System Restore, you'll have an additional task,
Undo my last restoration, on the System Restore Welcome page. Remember that you'll have to reinstall any programs that were installed after the restore point.
If System Restore doesn't work in Normal Mode, it might work in Safe Mode. To use System Restore in Safe Mode, press the F8 key during reboot and choose Safe Mode. When your computer starts in either Safe Mode or Normal Mode, System Restore can be used to capture a working previous state. System Restore can't be opened unless the system is bootable into one of these modes.
Top of page
Create Restore Points Manually
Only application installations that use a System Restore restorept.api-compliant installer will trigger the creation of a restore point. So it's a good idea to create a restore point manually before you install an application that you suspect won't have one a restorept.api-compliant installer. For example, before installing a screensaver you've downloaded from the Internet or a beta program from a software vendor, you should manually create a restore point. For more information, see the TechNet article,
Windows XP System Restore.
To manually create a restore point:
1.
Click
Start, point to
System Restore.
2.
On the Welcome page, click
Create a restore point.
3.
On the
Create a Restore Point page, enter a descriptive name for your restore point, as shown in Figure 3, and then click
Create.
Figure 3
The
Restore Point Created page confirms that the new restore point has been created. I think it's a good idea to manually create a restore point before you download and install any application from the Internet.
Top of page
Use Scheduled Tasks
You can use
Scheduled Tasks to create restore points at specified times. You might want to configure Scheduled Tasks to run System Restore at 6:00 P.M. daily, so that you always have a restore point available at the end of each working day.
To create a Scheduled Task, log on as an administrator, and then follow these steps:
1.
Click
Start, click
Control Panel, click
Performance and Maintenance, click
Scheduled Tasks, and then double-click
Add Scheduled Task.
2.
Click
Next on the first
Scheduled Task Wizard page.
3.
On the second page, click
System Restore in the list of applications, and then click
Next.
4.
Continue through the wizard, specifying the days and times to run System Restore.
5.
When prompted, type in the user name and password for an administrator of the system, and then click
Finish.
Scheduled Tasks starts each time you start Windows XP and runs in the background.
If you need any help you can reach me on my email
[email protected] or you can call me at +919291521716 or you can chat with me at
[email protected]
Regards,
MOhammed
