E005 error My copier is Canon GP 335. When I open the copier , E 005 error occur I have already replaced the cleaning web. I opent the front cover and find a small hole to call the "$" sign. But I cannot find . If you have other method to call "$" sign , please show me.
  • 3 Answers
Push *28* then copier>counter>misc-fix-web set to 0.
Posted on Feb 07, 2008
Done shown as 005
A E005 error code means the fuser cleaning web needs to be replaced. It cleans & lubricates the upper fuser unit. It is the white web that rest above the upper fusing roller. There is also a web counter in service mode that will need to be reset as well. You can just rest the counter, but if the web runs out > the upper fixing roller will be damaged. Good Luck
Oct 04, 2011 | Canon imageRUNNER 400S Copier
How to resset the E005 error code in cannon GP335
I'm not familiar with the GP-335 but it may be similar to the GP-30 for America. This is an error for the deplecition of the fixing web. That will have to be replaced ( P/N FY1-1046-000 ). The nget into service maod and reset the web counter in COUNTER section.
Jun 17, 2011 | Canon Office Equipment & Supplies
Errors codes E677 & E005 trying to find a total usage counter for all copies done on the machine
e677 might just be a bad drum. E005 is the cleaning web that needs replaced. The counter is in the upper left side behind the front cover!
Dec 20, 2010 | Canon imageRUNNER 400S Copier
Main power switch off on, E005, canon gp 335
E005 means that the cleaning web needs to be replaced.
May 29, 2010 | Canon imageRUNNER 400S Copier
I have a canon 6551 which is giving me an error E-005 turn switch off and on, but nothing happens. How to resolve?
The E005 error code means that the machine needs to have its Fixing Web replaced. After replacing the web, the error code will need to be reset. The part number for the Fixing Web is FY1-1046-000 . To reset the E005 code, you will need to access service mode by opening the front cover of the copier, insert a straightened paper clip into the small hole (located on the left, front side of the upper inner cover), press button with paper clip. Press the Additional Functions (*) button. A " $ " will appear in the display. Press *, 4, *, then you will need to navigate to web counter, select and then enter all 00000 to reset, press ok.
Jan 27, 2010 | Canon NP 6551 Black and White Copier
Error code 005 for canon GP 335 CONTINUES TO APPEAR
press additional function button once and press 2,8 buttons at a time & press additional function button again & execute the following
select <copier> <counter> <misc> <fix web> then press clear button on the display.
automatically the web counter will be zero , the proble also cleared.
Jan 27, 2009 | Canon imageRUNNER 210S Copier
E 005
A E005 is saying the cleaning web needs to be replaced or the web counter needs to be reset...If the cleaning web is out it will cause more damage to your upper fixing roller
Jul 28, 2008 | Canon NP 6050 Copier
Error E005
Are you looking for the service mode. A E005 is the fuser cleaning web counter. Have you replaced the cleaning web? If so, open the front door and look above the fusing knobe for a small hole above it. Insert a sraighted out paper clip in to the hole and you will see a "$" sing show up in the display pannel. Touch the "*" botton the the numbers "2 & 8 " at the same time then the '*' botton the display will change to service mode. Hit the #6 for counters and scroll till you hi-light web next hold the "clear" botton and reinsert the paper clip in the hole from before and the counter should reset to all zeros. Then turn the main power switch off the on and that is it, done
Feb 04, 2008 | Office Equipment & Supplies
CANON GP 335 E005 problem
We have fiqured out that the cleaning web needs to be changed therefore we have successfully done this but the error code E005 still appears.
Oct 04, 2007 | Office Equipment & Supplies
Error code E005
if your machine is giving E-005 that means your fixing assembly (fuser cleaning web is not detecting) is bad.
go in service mode by pressing additional fuction + 2 & 8 + again press addtional function
If you find that the E005 code won't reset after replacing the Web, and clearing both web counters in service mode, <COPIER>COUNTER>MISC>FIX-WEB> and <COPIER>COUNTER>DRBL-1>FIX-WEB> perform a Error Clear in service mode <COPIER>FUNCTION>CLEAR>ERR>.
enjoy
Sep 28, 2007 | Canon imageRUNNER 400S Copier
367 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
