The wast ink absorber full, if you want to clean the ink absorber at home without wast money, i will provide you the example in Canon printer,how clean you ink absorber follow the mention below instruction and remove the error of ink absorber.
Before the waste ink absorber becomes completely full, contact a Canon service representative. (You will need to replace a particular part of the printer.) Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing cannot be performed until the Waste ink tank is replaced.
On Canon machines it's not a tank, it's an absorbent pad that covers the entire bottom of the printer case. You need a shop to replace it and reset the counter.
it is not possible for you it is the problem mantainence wast tank full it mean when we print then chack cartridge is automacily clean then some ink fall under pad this pad is full ink then machine say ink absorber tank is full
you go to aservice centre only support printer canon. Thy clean wast tank and reset your printer
Call Canon at 732-521-7230 and they will sell you a new ink absorber pad.
You will need the reset code for your model printer. Find this by searching for canon used ink tank. One of the results should match your machine.
You can also take out the pad(It can be messy so wear gloves), wash with water hose, let it dry completely, and reinstall it in the printer.
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
You have to send it to your nearest service centre. The WASTE INK ABSORBER KIT is approx. USD10/pcs
