Question about Intel Motherboard
How do i uninstall microsoft active x control on my pc?
Please help---how do i uninstall microsoft active x control on my pc?
Many thanks !
  • 1 more comment
  • rcmurray59 Jul 07, 2008
    how do complety delete active X control from my sytem. I abosluty hate. that piece of junk. HELP
  • Anonymous Sep 09, 2008
    i want the damn thing off!!
  • minorca Feb 06, 2009
    my computer is frezzing much and want to change the window
  • 118 Answers
Internet Explorer 3.0, 3.01, and 3.02 loadTOCNode(2, 'moreinformation'); 1. Click Start, point to Settings, click Control Panel, double-click Add/Remove Programs, and then click the Install/Uninstall tab. 2. If the ActiveX control you want to remove appears in the list of installed programs, click the ActiveX control, click Add/Remove, and then follow the instructions on the screen. If the ActiveX control does not appear in the list of installed programs, continue with the next step. 3. Click Start, click Run, type the following line in the Open box, and then click OK: regsvr32 drive:\windows\occache\filename.ocx /uNOTE: drive is the drive letter on which the Windows folder is located, windows is the name of the folder in which Windows is installed, and filename.ocx is the ActiveX control you want to remove.
NOTE: If you do not know the file name of the ActiveX control (.ocx) you want to remove, you may be able to determine the file name by viewing the Hypertext Markup Language (HTML) source of a Web page that installs or uses the ActiveX control. To view the HTML source of a Web page, right-click an empty area of the Web page, and then click View Source. 4. In Windows Explorer or Windows NT Explorer, click the .ocx file in the Windows\Occache folder, and then click Delete on the File menu.Occache is the name of the folder where ActiveX controls are installed in all versions of Internet Explorer 3.x. The Regsvr32.exe file is installed by Internet Explorer and can be used to register and remove registry entries for ActiveX controls.
Internet Explorer 4.x or Later (All Platforms) loadTOCNode(2, 'moreinformation'); Internet Explorer 4.x or later, include the Occache.dll file, which is used to enumerate, update, and safely uninstall ActiveX controls using a "shell folder." 1. Click Start, point to Settings, click Control Panel, double-click Add/Remove Programs, and then click the Install/Uninstall tab. 2. If the ActiveX control you want to remove appears in the list of installed programs, click the ActiveX control, click Add/Remove, and then follow the instructions on the screen. If the ActiveX control does not appear in the list of installed programs, continue with the next step. 3. In Windows Explorer or Windows NT Explorer, double-click the Windows\Downloaded Program Files folder or the Winnt\Downloaded Program Files folder, right-click the ActiveX control you want to remove, and then click Remove. 4. When you are prompted to remove the ActiveX control, click Yes.IMPORTANT: The following ActiveX controls should not be removed if you are running Internet Explorer 4.0: • DirectAnimation Java Classes • Internet Explorer Classes for Java • Microsoft XML Parser for Java • Win32 ClassesInternet Explorer 5.0 or later does not require these components in the Downloaded Program Files files.
Error Messages Removing ActiveX Controls loadTOCNode(2, 'moreinformation'); When you attempt to remove an ActiveX control using an Occache shell folder, you may receive one of the following messages: • Share Violation These program files are currently being used by one or more programs. Please close some programs, and try again. You may need to restart Windows. • Component Removal About to remove a Windows system DLL: (<path\filename>). Okay to delete?Share Violation:
This message occurs if the ActiveX control you are trying to remove is currently loaded in memory by Internet Explorer or the Active Desktop component.
To resolve this error message, follow these steps: 1. Close all open Internet Explorer windows. 2. Disable the Active Desktop. To do so, right-click an empty area on the desktop, point to Active Desktop, and then click View As Web Page to clear the check mark. 3. Remove the ActiveX control by following the steps in the "Internet Explorer 4.0 or Later" section earlier in this article.
NOTE: You may need to restart Windows before you remove the ActiveX Control.Component Removal:
This message occurs only in versions of Internet Explorer 4 prior to 4.01 Service Pack 1 (SP1) when the ActiveX control you are removing installed files into a folder other than a registered Occache folder (for example, Windows\System or Winnt\System32). Occache cannot always determine if those files are shared by their programs.
If you are certain the file or files displayed in the message are not being used by Windows or another program, click Yes. Otherwise, click No.
NOTE: In Internet Explorer 4.01 SP1 and later, Occache does not remove (or prompt you to remove) dependent files outside of a registered Occache folder.
Support for Multiple Occache Folders loadTOCNode(2, 'moreinformation'); Internet Explorer 4.0 and later supports multiple Occache folders. The list of Occache folders is located in the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ActiveX CacheBy default, Internet Explorer 4.0 and later uses the Windows\Downloaded Program Files or Winnt\Downloaded Program Files folder. If you upgraded from Internet Explorer 3.x, both an Occache and Downloaded Program Files folder may exist. In this case, all new ActiveX controls are installed in the Downloaded Program Files folder, but previously installed ActiveX controls still work in the Occache folder. When you open the Occache or Downloaded Program Files folder in Windows Explorer, Windows NT Explorer, or My Computer, all ActiveX controls are displayed regardless of the folder in which the ActiveX control's files are located. In this case, the following string values appear in the registry key: "0"="C:\\WINDOWS\\OCCACHE" "1"="C:\\WINDOWS\\Downloaded Program Files" For additional information about ActiveX controls, please see the following article in the Microsoft Knowledge Base: 154544 (http://support.microsoft.com/kb/154544/EN-US/) Description of ActiveX Technologies For information about how Internet Explorer downloads ActiveX controls if a conflict occurs (for example, if the file already exists), please see the following article in the Microsoft Knowledge Base:
HOPE THIS HELPS
Good Luck
Posted on Feb 07, 2008
Cannot open programs in control panel. 4 days premium techs have been working on the issue, no success. Can control panel be uninstalled and reinstalled?
Hi!
Sadly, the Control Panel cannot be removed and then re-installed. Typically I see this issue if Windows is not genuine or hasn't passed activation.
If you go into Start > then type in sysdm.cpl (provided your system is Windows 7), this should get you into the System section of your Control Panel. Near the bottom of this window, does it say Windows is activated?
I've provided a list of accessing all the applets inside of the control panel for your reference, below (again, assuming you're running Windows 7):
http://support.microsoft.com/kb/192806
Hope this helps!
Mar 01, 2015 | Computers & Internet
Office 2010 Starter edition - click to run failure
Hi Amanda,
I assume you've tried uninstalling 2010 from the Control Panel> Programs and Features.
I've had the same issue before and this video from Microsoft did the trick.
How to manually uninstall MS Office Products.
Hope this helps!
Please Rate
Thanks,
Gary
Jul 18, 2013 | Microsoft Office 2010
How to activate microsoft word2007 of this pc
Just uninstall word since you don't use it. It is just a 30 day demo anyway...
To uninstall or change a program
  1. Open Programs and Features by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, clicking Control Panel, clicking Programs, and then clicking Programs and Features.
  2. Select a program, and then click Uninstall. Some programs include the option to change or repair the program in addition to uninstalling it, but many simply offer the option to uninstall. To change a program, click Change or Repair. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
Aug 18, 2012 | Toshiba Computers & Internet
I tried to uninstall microsoft office after the trial expired, i didnt and now i can not run my office or install.how do i fix this?
Hi, You need to activate it with a purchased license or uninstall and install a newer version such as Office 2010. I suggest you either buy a license and activate or uninstall through Windows Control Panel.
Icom1
Dec 15, 2010 | Microsoft Office Word 2007 Full Version...
I tried to use one of the product keys listed below but it didn't work. Every time I tried to activate the software it tells me that the product key I used is not valid. Please uninstall the software and...
Click Start
Click Control Panel
Click Switch to Classic View
Click Add/Remove Programs
Click to select Microsoft Office Professional
Click Uninstall
When the uninstaller completes, restart your computer.
Take the original Microsoft product CD-ROM, and insert it into your CD-drive. It should "auto-run" to start the "installer" program.
Take the product-key that was supplied with the CD-ROM, and use that key to activate the software.
Be sure to be careful:
* ZERO versus OH
* ONE versus ELL
* FIVE versus ESS
* EIGHT versus BEE
when typing the product-key.
Oct 04, 2010 | Microsoft Office Professional 2007 Full...
I want to remove Genuine Microsoft Software from my desktop
To uninstall the Office suite do the following:
  • Click Start
  • Go to Control Panel
  • Open Add/Remove Programs or Programs and Features (for Windows 7)
  • Choose Microsoft Office in the list and click on uninstall
The uninstaller will then run. Just follow the instructions. When the uninstaller is finished your Office suite will be uninstalled.
Hope this helps!!!
Jan 05, 2010 | Microsoft Office Professional 2007 Full...
Hallo,after update windows xp my volume control will not open simply because is says there is not active mixer devices available. and then it talls me that i need to install the mixer device at the add...
If you are intrested in uninstalling the update the you have 2 options.
I aint sure about what the active mixer is. Must be a driver malfunction or something.
You can go to the laptop manufacturer website and download the driver for the sound card and check if it works otherwise
Go to Control Panel -> Add/ Remove programs -> In the top you wil have an option which says show updates. It will show all the updates and you can uninstall the latest windows XP update.
else
Go to Start->All Programs -> Accesories -> System tools -> System restore and restore to a date earlier than 1 week.
This should help
Aug 08, 2009 | Microsoft Windows XP Professional Upgrade...
I have windows XP media center, I can't install IE 8
IE 8 is beta version not recommended for home use. its still in research. So go to control panel and uninstall ie8. you will get ie7 back.
Thanks, PREM
Mar 30, 2009 | Dell Computers & Internet
Hi having problems with adobe reader V9, Microsoft browser failed to activate, a window appears that it needs adobe reader V9 not able to activate to the browser Please Help Its fustrating
Adobe Reader does this somfimes, all you have to do is reinstall it.
Go to start->control panel->add remove programs. Find Adobe REader. Uninstall it.
Then go to adobe's download site and reinstall it. All problems solved.
Dec 06, 2008 | Computers & Internet
Intel Motherboard Logo
1,946 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
