Question about Sony Ericsson W200i Cellular Phone
Device not found
I am unable to open my cell phone file using a data cable for a few days before that the file disk used to open when we press right click and open now if i do the same procedure it comes as "open with" with a list of progrms like firefox and explorer wat do i do in this case
I am unable to open my phone
Posted on Feb 07, 2008
I want to dwn load music from my comp to my phnes mp3 playe
Hi.- Does your phone have a data cable? memory card?
- If so, Power the phone
- Use the data cable and connect the phone to your PC using one of the USB ports.
- On your phone pops a list of options for the connection type.
- Select data storage by scrolling to the option.
- The PC accesses your phone as a data storage device and lists contained folders.
- Select desired folder [A] to store your music [e.g.memory card] and double click to open it.
- Minimise it
- Open the folder [B] containing your mp3 files on your computer.
- Right click on one of the files and select copy
- Maximise the folder [A] right click inside and select paste
- The file copy's.
- Copy,paste all desired files and then close folders.
- Right click the usb device icon on the taskbar and select safely remove hardware.
Browse your phone for the new files and try playing them.
GOOD LUCK
Sep 05, 2011 | Computers & Internet
My htc mozart is unable to connect other bluetooth devices it is saying not supported.how to connect my bluetooth to others to transfer data or music.
Unfortunately, your phone doesn't have File Transfer Profile (FTP) in bluetooth, you'll need to use its USB cable to transfer files between PC and phone, it's a standard micro-USB (5-pin micro-USB 2.0) cable.
Mar 04, 2011 | HTC 7 Mozart Cell Phone
How to transfer a picture taken & stored with a v9 motorola phone to a computer ?
Using your phone's USB Connection as 'Memory Card' or Using Motorola Phone Tools.
1. Install the Motorola Phone tools to your PC.
2. Connect the USB cable to your phone and to your computer. Your computer will recognize your phone as a "Removable Disk" icon
3.On a PC, this icon can be found in the "My Computer" window under "Devices with Removable Storage".
4. Open the "Removable Disk" icon to access the memory card.
5. Drag and drop the desired files to the folder in your PC.
using Motorola Phone Tools
1. Connect the USB cable to your phone and to your computer.
2. click Transfer Pictures from the welcome screen
3. In the Mobile Phone View select the file/folder you want to copy.
4. click the arrow key to transfer the files from your device to PC and vice versa or you can simply drag and drop
hope this help
Sep 08, 2010 | Cell Phones
Problem with my nokia 5230 data cable
first and foremost formate ur device to correct any corrupted file disturbing the function of your phone, then try using ur data cable again..
Jun 27, 2010 | Nokia 5230 Cell Phone
From where I get samsung sgh-t459 usb driver software
They do not make one for your phone, and they do not have you phone setup to work with the samsung pc studio.
So the only thing you can do is this, and maybe pictures.
  1. Insert a microSD memory card into the memory card slot located on the left side
  2. From standby press the Menu key
  3. Select Settings (9)
  4. Select Phone Settings (3)
  5. Select USB Mode (5)
  6. Highlight Mass Storage and press the Save key
  7. Plug one end of the data cable into the handset's power/data port located on the right side and the other end into a USB port on the PC
  8. On the PC, open My Computer and double-click on Removable Disk (Hint: it will be assigned a drive letter and, depending on system configuration, may not be the only Removable Disk present)
  9. Using Windows Explorer, copy and paste (or drag and drop) MP3 files from your PC to the Music folder seen under Removable Disk
Feb 14, 2010 | Samsung Gravity SGH-T459 Cell Phone
I forget my orig. phon setting...so i can't restore..ples help
Tools Required :
• Nemesis Service suite (NSS)
• Nokia PC Suite
• Data cable
Steps :
1. Connect your phone in PC Suite mode
2. Open Nemesis Service suite (NSS)
3. Then click on scan for new devices button (top right hand side)
4. Click on phone info button.
5. Now Click on Scan.
6. Select Permanent Memory.
7. Click on Read.
8. It will read the permanent memory file and save it on the disk at following path.
C:\Program Files\NSS\Backup\pm\<IMEI>.pm
9. Open the .pm file using Notepad.
10. Now scroll until field [308], and on the 5th Record (5=) your security code is saved at there.
11. Like 5=31313131310000000000
12. Remove all “3” digit and it will be 31313131310000000000
13. 11111 is your security code.
14. Done!!
Once you find the security code you can restore the settings by "Restore factory settings" option. Rate me if it is helpfull!!
Aug 19, 2009 | Nokia 7610
How to break the security code of nokia 2626 mobile phone . . .
Use the following at your own risk, i don't bear any responsibility for any kind of loss.
Tools Required :
Nokia PC Suite
Data cable
Steps :
7. Click on Read.
Mar 23, 2009 | Cell Phones
Unable to install Java games on P520
we can transfer the java games by using the data cable. following are the steps 1. connect the mobile with the PC by using the data cable 2. transfer both jad and jar files to the "MTP" folder in the memory card of the device. 3. disconnect the data cable 4. go to "my files" menu 5. go to  the "memory card"  5. move both the JAD and JAR files to the "phone"  6. get back from memory card to my files
device will ask for the installation of the game. if not, follow the steps below.
7. select the "other files" folder
8. select the JAD file.
the installation prompt will be displayed
        Ranil S.        SIPL
Dec 22, 2008 | Samsung SGH-D900 Cellular Phone
How to install games on my samsung d600??? i have lots of jad files to install....
Hai,
Connect the phone to the computer using the data cable.
If any selection needed in the phone, select data storage.
if ur connecting for the first time, system will install the phone device driver, wait for that to happen.
Open my computer, there u will find the new Removable Disk
Open it and make a directory there, Games, for example.
Then copy your game jad files in the directory(presume ur phone supports jad files)
After copying remove the phone safely from the data cable.
From the phone brows to the games folder and select ur games.
and enjoy
good luck
Rabby
Jun 16, 2008 | Samsung SGH-D600 Cellular Phone
Unable to fix com port for lg u8330 camera phone
Plug in the USB cable. Use the LG Installation disk to install the driver.
if you do not have the driver search Google with these words " LG U8330 Driver Installation disk" and you will find it or you can download the driver here:
http://www.nodevice.com/driver/download.html
Remember after you install the driver open the LG Phone Manager
and click on open COM port. The correct COM port has a little * beside it.
E.G. *11 or *03 etc., etc. then click on CONNECT.
Feb 09, 2008 | Cell Phones
Sony Ericsson W200i Cellular Phone Logo
49 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
