Question about Hitachi 53SWX10B 53" Rear Projection Television
Color is warped and wrong
Hello, I know next to nothing in terms of TV tech. Today I saw this Hitachi 53SWX10B in a driveway with a sign saying it was free. I talked to the owners and they said it just needed a part, and if I knew someone who can fix TVs I would be set. So I took it and now am trying to do some homework before I go to a local repair shop. It appears in good condition, sound is good, and picture is better than I was expecting being that they were just giving it away. The first pic is the Hitachi, the second is another TV showing the same screen, showing how it should look.
I would greatly appreciate: A) if someone can tell what is wrong with the TV from the pic, and/or B) what I should expect to pay for quality repair. Anything you think I would benefit from knowing, I would also appreciate. Thanks much!
  • Joseph
    Joseph Feb 08, 2008
    Thanks alot!
  • davebb1210 Apr 07, 2008
    hey i was driving down my street and saw a Hitachi 53swx10b on the curb i went up to it and saw that it was in pretty decent shape but knew that there had to be a pretty big problem for someone to just throw away a tv like that, so when i got it to my house and plugged it in i saw that the colors were of and the letters and picture were bowed can anyone tell me what part must be replace and how much it will cost.
  • Hitachi Master
  • 3,459 Answers
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
  • Screen looks 3D
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Posted on Jan 29, 2009
  • 579 Answers
A convergence amp has failed. Very common. Plan on just replacing both STK modules (big flat circuit modules mounted on a big heat sink) with upgraded parts. Good ones cost about $40 each. Then readjust the convergence. Total cost at a shop is $250-$400.
Hope Ya Fix It.
Posted on Feb 07, 2008
I have a Hitachi 53swx10b. The sound is starting to go out. It will work and then goes silent. I turn the tv off and back on and it will work. What is the easy fix?
There is not an easy fix for this problem with this model.
This set uses a surround sound audio board that processes all audio. Our shop no longer repairs the boards as it can be very time consuming and usually we send the board out to a national company for rebuild.
Problem is solder connections on tiny flat pack parts on both sides of the board break and I saw several where set was only months old, at that time Hitachi sold the board but it is no longer available from them
The Rebuilders (last time I used them) charged about 200 including shipping as you have to remove the board and send it in. Removal of the board is not hard and I can tell you where to look for it.
Sorry if this is bad news but it is what your problem is.
Let me know if you have questions as I am here to help.
SD TECH
Oct 11, 2011 | Hitachi 53SWX10B 53" Rear Projection...
Hi, I have a Hitachi 53swx10b projection tv. the colors are bleeding and sort of glowing. any idea what this tv needs? thx, John
Ur tv convergence are dead.U know how to solders?Must replaced 2 STK convergence ICS,and some or all the resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost $300-350 for parts and labors.
Apr 03, 2010 | Hitachi 53SWX10B 53" Rear Projection...
I have a Hitachi Projection TV 51G500A 2004 ,
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2010 | Hitachi 51G500 51" Rear Projection...
Color on Panasonic 2004 is off and appears to be warped
It sounds like a convergence problem; most of these sets use two convergence IC chips that both need to be replaced; usually this can be done right in your home.
Aug 16, 2009 | Hitachi 53SWX10B 53" Rear Projection...
50 inch Hitachi Ultravision LCD Rear Projection Television
Hitachi has had problems with their light engines. Very expensive. Contact Hitachi as they may give you consideration even if this is out of warranty.
Apr 15, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 53SWX10B has picture but no sound
Hi, not good news, you have a bad surround module and this is a VERY difficult repair job, most techs send it to PTS and then they don`t get it right about 10% of the time either, Have a tech pull the board and send it out theres nothing you can do to repair it, sorry for the bad news, video-tek
Jan 30, 2009 | Hitachi 53SWX10B 53" Rear Projection...
Red Halo Hitachi 53FDX20B (2002) model year
You can get the replacement Convergence ICs at this website I am posting. Just order the same STK numbers that are on your Convergence ICs. They provide instalation instructions and free on line tech support with every purchase. Heres the link.
http://servicemanuals.vstore.ca/
Apr 11, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Wavy lines
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 10, 2007 | Hitachi 53SWX10B 53" Rear Projection...
Hitachi 53swx10b 53 in. rear projection
best to bring in a find a ISF tech to do the calibrating of the set, when you call in for repair make sure he's ISF
Oct 22, 2007 | Hitachi 53SWX10B 53" Rear Projection...
Hitachi 53SWX10B 53" Rear Projection Television Logo
362 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
