Question about Ricoh Aficio 1035 Copier
Ricoh aficio 1035
I am getting error sc990 .
I want to fix it so wht is the fastest.
thanks
  • 2 more comments
  • faldo Mar 29, 2008
    I have a 1050 and when I pwer it up it just keeps resetting itself over and over for 5 minutes or so...then it finally alows me to scan, but it only does
    about 7 sheets then locks up...any thoughts?
  • Anonymous May 28, 2008
    error sc 990
  • jorgecruzfot Oct 19, 2008
    I am getting also sc 990 two or tree times a day apparently for no reason I think this problem needs firmware update. What do you think?
  • mariam ies
    mariam ies May 11, 2010
    my transfer belt produces loud sound how can i fix it ???
    New Friend:
  • 34 Answers
It needs a firmware update or re -write.
Posted on Feb 18, 2008
  • 4 Answers
Sc 990 is a software problem try to update the firmware and software it will solve your problem or replace your drum that works for me
Posted on Mar 01, 2008
  • Ricoh Expert
  • 1,326 Answers
Hi, does the problem show up all the time or every 20 to 40 copies or will it code out when the copy job is done printting? Also, do you have a finisher on it. If so try to unplug the finisher and see if problem shows up. If it dose you may have a bad Hard Drive. I chased my tail for awhile on it and it turned out to be the HD. If so, save your self some money and buy a new 40G HD drive from a computer store. The OEM one is about $175.00. There is nothing on it, it just stores sortting jobs. Get one just like the one in the copier.I beleave it is a Seagate brand It is also possible that it is the boot chip, it is on the PCB under the HD.
Posted on Feb 08, 2008
Hi, the SC 990 is a communication error between the BICU board and the IOB, check the connections, cables, switches, sensors of the IOB and make sure that has a good connection to the BICU.
Posted on Feb 07, 2008
My ricoh aficio shows sc990 how can i fix this problem?
first you check pm life of drum kit if finished than replace it
second clean laser unit (ld) you will discover that this code will never shows again.
Aug 12, 2012 | Ricoh Aficio 1035 Copier
Sc990
sc990 is the software problem. replace the HDD of the machine and it should be fine. don't format the hard drive as it might result in laser error code.
Oct 22, 2010 | Ricoh Aficio 1035 Copier
Sc990
Software performance error
The software attempted to perform an unexpected operation.
Best solution is probably to update firmware.
Oct 12, 2010 | Ricoh Aficio 1035 Copier
I have A problem of SC990 in the ricoh aficio 2035/45 and also I get light copies and over tonning problem.
The light copies and overtoning is probably caused by the developer going bad. Do you have a service contract on your copier? It's likely time for a whole PM (preventive maintenance) procedure.
The sc990 is probably caused by the copier's condition as well. Once you have the PM done (or at least replace the developer, rebuild the photoconductor unit, and clean or rebuild the transfer unit) the sc990 codes should go away along with the poor copy quality.
Jun 19, 2010 | Ricoh Aficio 1035 Copier
I have ricoh 1035 & eror sc990. without hdd ,i can print and copy one side and by hdd i have error. i do . & # toghter for 10 second for soft reset and nothing happend. in code menu: 5801 - 2109 -...
If you use Katun OPC drum in your machine and is work more 80000 copies you need to replace the OPC drum and the drum cleaning blade.After replace the drum perform the process comtrol and the SC990 disipaire.Whenever use other genuine parts and not original Ricoh parts appair SC codes to refer HDD parts.100% this method is working.
Nov 21, 2009 | Ricoh Aficio 1035 Copier
Ricoh 1045 sc990
Generally changing the cylinder (blade and developer) Initialize td and id sensor usually it is solved. If it is not thus it proves the following thing: press point and numeral (enter) simultaneously for more than 10 seconds until this clear the service call. If the problem persists can be the hard disk, change.
Jul 31, 2009 | Ricoh Aficio 1035 Copier
Ricoh aficio 1035 error code SC121
sc 121 is related to optics section of your machine.check the lamp is glowing .if so check the connection from optics to main board.
Jun 15, 2009 | Ricoh Aficio 1035 Copier
Af2045 always shows sc 990
if you are getting the sc990 code, you will need to have someone come out and do preventative maintenance (PM) on the machine. the 990 code has to do with the drum quality, and the only way to fix it is to, at least, have the drum unit rebulit.
Apr 02, 2009 | Ricoh Aficio 1035 Copier
Aficio 1035
Not sure what SC818 is as not in my manuals please try the following.
Entering and Exiting SP mode
1. Press the Clear Mode key.
2. Use the keypad to enter “107”.
3. Hold down Clear/Stop for at least 3 seconds.
4. Enter the Service Mode.
To enter the Normal Service Mode:
Copy SP On the touch-panel, press Copy SP.
Once in the service mode turn the main switch off located on the left hand side of the machine wait 5-10 seconds then switch back on. This should get the machine working. Hope this helps
PLEASE DO NOT ADJUST ANYTHING ELSE WITHIN SERVICE MODE AS CAN DAMAGE MACHINE OPERATION)
Thanks J
Dec 24, 2007 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1035 Copier Logo
533 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
