Kenmore 80 series washer not completly spinning clothes dry
Machine spins but never seems to reach previous speeds and leaves clothes wet on the bottom of load
  • 4 more comments
  • Anonymous Feb 27, 2008
    my kenmore 80 is only 3yrs old and suddenly the spin cycle isn't as fast as before and leaving the clothes ringing wet. I am having a repair man look at it tomorrow...what should I expect cost wise???
  • Anonymous Mar 02, 2008
    This washing machine doesn't appear to have a belt... direct drive. This is from an observation at the bottom of the machine when lain on it's side.
  • tj fix Jun 09, 2008
    My Kenmore 80 Series does not always spin through both the rise and spin cycle. Is it worth fixing and how difficult is it?
  • Anonymous Mar 12, 2014
    leaves clothes wet
  • Anonymous Mar 24, 2014
    washer won't completely spin dry at end of rinse cycle. The machine spins slowly and sounds like it is trying to speed up but can't. Sounds like higher speed is trying to engage. Eventually it will stop still in rinse cycle and the clothes are still wringing wet. Any suggestions for the fix to this problem?
  • Anonymous Mar 26, 2014
    how old is this washer
    sometimes does not spin out leaves clothes wet
  • 73 Answers
Belt going..
A bit of a pain to replace, but doable..
Belt dressing will keep it going for a while..
Dont get your fingers caught in it..
Serious injury is possible, unplug the machine
and stand on the plug while moving the
belt to goop it..
(why? that way it cant get plugged in!)
Posted on Feb 07, 2008
Clothes still wet after spin
it is normal for clothes to be a bit wet after spin.approximately about 80 percent of your clothes will be dry after spin. you may hang your clothes to completely dry or place it inside a drier machine
Sep 03, 2015 | Maytag Bravos 3.8 Cu. Ft. Washer
Kenmore Series 80 washer NO High Speed Spin
It could be a timer, motor or wiring problem. You would need to check for 110 volts at the timer or motor when in the higher spin mode. If you are getting 110v you have a bad motor. No or low volts you have a bad timer. The motor is either a 2 or 3 speed motor and you would have to determine which winding to check for the 110v. The schematic is usually glued to the inside rear cabinet. Please rate this post.
Dec 14, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
80 Model will spin sometimes -with help- but never fast
Likely the out of balance sensor is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 11, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore Series 80 washer model 23832100 spins slowly
It probably is your clutch. You will need to remove transmission to repair this.
May 12, 2009 | Kenmore 22422 Top Load Washer
Wet clothes
the reason the clothes are wet is the washer is not shifting to high spin,does the washer have a speed switch(normal wash spin,high wash spin)if its not the speed switch than the clutch is bad,how old is the washer?mike
Apr 19, 2009 | Kenmore 24032\24036 Top Load Washer
Series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Mar 20, 2008 | Kenmore 24622 Top Load Washer
Broken washer/dryer
This sounds like a motor control board is faulty. Please load a couple of towels in the machine run it. Watch the machine as it goes through its' cycles.
1. Do the towels tumble when the machine is washing ?
2. When it begins to spin, does it spin one way at a fast pace or does it spin one way and then the other ?
Answering these two questions will help in troubleshooting your problem.
Jan 07, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 90 Series, clothes wet after spin
First thing you need to check is the speed of the spin cycle. As long as you are not overloading the machine, it should spin the clothes pretty dry. the basket drive may need to be replaced. If it is spinning very fast, then check the drain hose, make sure the water is coming out nice and fast. If not you may have a water pump problem even lint clogged inside it.
Nov 29, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
953 people viewed this question
Top Washing Machines Experts
