Question about Mitsubishi WD-62827 62" Television
TV suddenly shuts off and lamp light comes on, but lamp is OK
A few days ago I tried to turn wd-62827 set on and it acted like it would turn on, but instead it went dead and the red lamp light came on. Assuming it was the lamp (after two years of use) I ordered a new lamp and installed it. I of course happened to unplug the main power to replace the lamp and when I had it back together it started up just fine. The next day I was watching it and it shutoff again and the red lamp light came back on and the tv would not turn back on. On a hunch I unplugged the unit and plugged it back in and waited for the green light to stop flashing. I turned it on and it works great. Anyone know what is causing this? Thanks!
  • 1 more comment
  • Anonymous Mar 12, 2008
    sskellen - so the technician came back out and replaced the balast, but it did not fix the problem. However, when he continued to trouble shoot he pulled out the main power board and discovered an errant wire on the board that had not been trimmed down during production and had bent over and shorted the output to the balast. He bent the wire up, trimmed it and the TV works reliably again! I hope this helps some of you as I can imagine this QA/QC problem being more wide spread.
  • mrakes Apr 01, 2008
    I am having the same problem right after installing a new lamp
    HELP
    I have a samsung
  • Anonymous Apr 15, 2009
    I HAVE THE SAME PROBLEM I REPLACE THE LAMP 20 DAYS AFTER IT WOULD NOT TURN ON SO I REPLACE THE BALLAST AND IT TURN ON FOR A COUPLE OF DAYS BUT IM BACK TO THE TV NOT TURNING ON . AT FIRST I COULD CUT IT ON AND OFF AND IT WOULD TURN ON AFTER A WHILE IT DIDNT TURN ON JUST BLINK RED ANY IDEAS
  • 116 Answers
There are 6 capacitors in the power supply that fail on this tv. Two are 3300@16v, and four are 1000@16v. They should be replaced with hi temp capacitors.
Posted on Mar 08, 2008
I did reset the lamp timer, but same problem. It will usually come back on for a period of a few hours or days and then shutoff. Thanks.
Posted on Feb 17, 2008
    Genius:
  • 1,030 Answers
Did you reset the lamp timer? just a guess
Posted on Feb 08, 2008
Hl72a650
color wheel issues replace light engine
Jul 07, 2013 | Televison & Video
I have a mitsubishi wd-62827 tv. How do I access the bulb to replace it? Do I take the back of the tv off or the front?
on the back bottom right corner there are 2 Phillips screws holding a vent cover remove that, should have a small tunnel the lamp screws you can turn by hand pull handle to remove your lamp
Jul 03, 2011 | Mitsubishi WD-62827 62" Television
WD-62827 62 in. HDTV Television: mY LAMP WENT OUT ND NEEDS TO BE REPLACED, IS THIS ...
yeah ive had this tv for 4 years replaced lamp when i got it then about a year ago there was a but power surge that ruined 2 pc monitors and that lamp just google WD-62827 replacement lamp pick a place to buy from the only tool you'll need is a phillips screwdriver
May 17, 2010 | Mitsubishi WD-62827 62" Television
Tv tries to turn on but then turns off with a red
Lamp light on again?must replaced the lamp again,the lamp hours it up.
Mar 30, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Green Flashing Light - TV Powers Down (WS 62827)
Initialize the settings by pressing "menu, 2, 4, 7, 0, enter". After settings have been initialized, press the system reset button on the front of the TV.
Aug 08, 2009 | Mitsubishi WD-62827 62" Television
TV shuts itself off after a couple minutes of being on.
One must be very careful of the quality of the replacement lamp. Many of the cheap 'deals' on the web for replacement lamps are substandard. I always recommend that replacement bulbs be the original manufacturers bulb.
Apr 30, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi WD 62827 pictures flashes colors
TAKE THE BACK OFF AND LEAVE IT OFF . NOW TRY IT. IT WORKED FOR ME STRANGE BUT IT WORKED
Apr 27, 2009 | Mitsubishi WD-62827 62" Television
When turned on, my Mitsubishi TV shuts off after a few seconds.
the lamp is simple; yet you can run into problems with this tv. be very careful replacing lamp. the plug in the tv can be damaged. (due to the design)
lamp part #
915P028010
Mar 13, 2009 | Mitsubishi WD-62526 Projection TV
Mitsubishi DLP overheating
Mitsubishi has problems with the thermal sensor going bad. They extended the warranty for several sets. The sensor is right by the lamp. Call mitsubishi and insist they do something for you. If you keep playing your set, the bulb could also be at risk. I would think your set is covered being a 62" set. Good-luck and be sure to act ASAP.
Dec 07, 2008 | Mitsubishi WD-52725 52". Rear Projection...
WD-52525 Shuts off, shows red lamp light even after replacing lamp
maybe your problem is in the power supply circuit of your tv,but then try to replace the flyback first maybe there is no high voltage coming out on the cap.
Jul 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62827 62" Television Logo
1,548 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
