Question about Kenwood DDX7015 RB DVD Receiver With 6.5" Touch Screen Monitor (Factory Refurbished) Car Video Player
Dubble den kenwood dvd player
It is hard to get it to take a dvd or cd some times and it says micaical errer and displays a number beside it like the number 9 how do i fix it
    Scholar:
  • 67 Answers
There is a bulletin on the mech which requires 2 springs to be replaced. When you install disc the cd pushes on two sliders that push on switches to detect the position of the sliders the springs pull sliders back to original position. Sometimes the slider may stick due to not enough spring tension and possible restriction due to dust dirt etc. This would be a possible problem for your symptom . kstahl65@att.net
Posted on Feb 15, 2008
Looking for a Kenwood KDC X397 owner’s manual? .
Yes of course. See the link
hard copy of this Google Search
KDC-MP238/CR KDC-MP208 KDC-138/CR - Kenwood
manual.kenwood.com/files/B64-3898-00_00_KW.pdf
Translate this page
2 ' KDC-MP238/CR/KDC-MP208/KDC-138/CR. Contents. Before use. 3. Basic Operation. 4. General functions. Tuner functions. Disc play functions. General ... Menu Operation. 10. Menu System. Activating Security Code. Deactivating Security Code. Manual Clock Adjustment. Auxiliary Input Display Setting. Receive mode ...
Kenwood KDC-138 CD Player User Manual - ManualsOnline.com
www.manualsonline.com > ... > Home Audio Kenwood > Kenwood CD Player Record the serial number, found on the back of the unit, in the spaces designated on the. warranty card, and in the space provided below. Refer to the model and serial numbers. whenever you call upon your Kenwood dealer for information or service on the product. Model KDC-MP238/CR/MP208/138/CR Serial number.
KENWOOD KDC-138 INSTRUCTION MANUAL Pdf Download.
https://www.manualslib.com > Brands > Kenwood Manuals > Car Receiver > KDC-138 View and Download Kenwood KDC-138 instruction manual online. Kenwood CD-RECEIVER INSTRUCTION MANUAL. KDC-138 Car Receiver pdf manual download. KDC-MP238/CR KDC-MP208 KDC-138/CR CD-RECEIVER INSTRUCTION MANUAL AMPLI-TUNER LECTEUR DE CD MODE D'EMPLOI REPRODUCTOR ...
Connecting Wires To Terminals - Kenwood KDC-138 Instruction ...
https://www.manualslib.com > ... > Car Receiver > KDC-138 > Instruction manual
Kenwood KDC-138 Manual Online: Connecting Wires To Terminals. To Kenwood disc changer/ External optional accessory (KDC-MP238 only) Fuse (10A) Wiring harness (Accessory1) Power control/Motor antenna control wire (Blue/White) TEL mute wire (Brown) Not Used (Blue) White/Black White...
Kenwood Car Stereo Head Unit Replacement Wiring Harness Plug ...
https://www.amazon.ca/Kenwood-Stereo...Wiring-Harness/dp/B005X273W8 Rating: 4.7 - ‎15 reviews
Kenwood Replacement Stereo 16 Pin Wire harness; Top quality all copper 18 gauge leads. Perfect Fit.Molex type 6 inch long black color; KDC KRC DPX KTS models see the descrition for model compatibility; Kenwood power harness plug 16 pin indash radio and video units; Allows for installation of an aftermarket radio ...
Mar 23, 2018 | The Computers & Internet
Kenwood car stereo is displaying Protect and wont come on
If ur kenwood stereo is going into protect mode, it is because one of ur speaker wires is shorting out. Make sure all of ur speaker wire connections are good, and then wrap them so they aren't grounding out against the chassis. This should solve ur problem.
Oct 09, 2011 | Kenwood Excelon DDX-7015 Double Din Car...
Try to eject cd and it displays 'demostration
hit the little reset button next to the kenwood logo on the bottom of the screen. Or go here...http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/DDX8017.pdf
Oct 29, 2009 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
How do you unlock region codes in a kenwood KVT-7039
There are no known hacks for your model, however you ca try the following:
Try here:
Unlock Kenwood DVD players
or
"These codes are applicable for all Kenwood radios that do not have DVD or DVD screens located on unit.
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds
(so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio
stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key on the remote
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key on the remote
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key on the remote
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key on the remote
The security is canceled and the set enters the TUNER mode!"
From
Kenwood CD Unlock Code
Aug 30, 2008 | Kenwood Televison & Video
My kenwood amp keeps cutting off on dvd mode but is fine on stereo mode???
Without knowing the model number of the kenwood reciever and what DVD input (analog or digital) you are using, I can only give you my best guess at what is causing this.
If you are using analog input (RCA cable), try connecting another analog source into the DVD input and see if that cuts out. if so, the problem is in the reciever and may just be a broken solder connection on the RCA input jack, if not the problem is in the DVD player.
If you are using the digital input you may have a problem on the DSP board. This is a very hard problem to troubleshoot to a componet level and many times the entire DSP board must be replaced (if it is available, which is rarely with Kenwood).
DSP board repairs are all very difficult repairs for any service center.
The only way to really know what the problem is, if you have eliminated the DVD player as the problem is to take it to a service center to get checked out.
I will be happy to help you more if you can get me the model number of the receiver and also try to check the DVD player for this problem.
Jun 18, 2008 | Kenwood Audio Players & Recorders
Kenwood car CD player not working
This means that some one has entered the wrong security code more than 3 times. time to take it to a dealer
Mar 19, 2008 | Kenwood KDC-MP5032 - Car Audio CD MP3...
Disk error with Kenwood DV-605 multi-disc DVD player
Try the following
when the error is on the screen, press the number 1 key on the remote, this should take you to the fist chapter of your DVD no matter which region it is
Miguel
Jan 03, 2008 | Kenwood DV-605 Multi-disc DVD Player
Kenwood MP4029 4 code reset
KENWOOD SECURITY CODE CLEAR procedure
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Type 2
Type 3
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Oct 13, 2007 | Kenwood KDC-MP228 CD Player
Errer-12
this is a serious error in your player, take it to the Pionner service.
Sep 20, 2007 | Pioneer DEH-2800MP CD Player
THE UNLOCK CODE
1)TURN ON YOUR UNIT 2)DISPLAY WILL REQUEST TO ENTER THE SECURITY CODE 3)USING THE REMOTE CONTROL POIN IT TO THE UNIT AND PRESS 55222277 THAT WILL CLEAR THE CODE. NOTE:"YOU WILL NOT SEE ANY NUMBER ON THE DISPLY WHILE YOU PRESSIN THE NUMBER ON THE REMOTE CONTROL
Aug 18, 2007 | Kenwood KVT-715DVD Car DVD Player
Car Audio & Video Logo
76 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
