Coffee and Espresso Makers
Problem for Coffee and Espresso Makers
Generic problem for all Coffee and Espresso Makers
Coffee machine
By della25 on Feb 07, 2008
I have a sunbeam intuitive that keeps telling me to clean brewing unit even after i have cleaned it can anyone help please.
Same Problem
Nov 17, 2008
-   I have a sunbean intuitive too, and have read about other people having the problem. I think the problem is that when the brewer feels resistance as it compresses the coffee, it decides it must to too dirty and needs a clean. I'm getting it only on the two cup setting (which loads in more coffee grounds causing more resistance). One cup setting works fine. I think the problem is the coffee grounds are too fine, or the sensor is too sensative when it detects the resistance. I suspect mine will be a warranty claim.-   rcheli32
Solution #1
posted on Feb 11, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Thank you for your suggestion i will give it a go and see if that helps. thanks.
Solution #2
posted on Feb 10, 2008
Not Rated)
pierre235
Rank: Guru
Rating: 87%, 828 votes
lot of time you got to wiggle back in there not in properly lot of time when you remove the brew unit when you put it back all the way in it suppose to reset itself thanks for using fixya pierre
Was this helpful?
Yes
No
Popular Solutions for Coffee and Espresso Makers
Questions and Unsolved Problems for Coffee and Espresso Makers
Answer
which style of the bodum french press' is best, the chombard, brazil, or kenya?
Answer
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop... (More)
Answer
Is there a way to make the b60 coffee maker run more water to fill cups fuller? mine only fills a... (More)
Answer
i cant get any pressure threw the handle part you put the coffee in
Answer
How do I clean my braun coffee pot. It came with a spring of some sort to clean it but I cant figure... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Coffee and... Experts
Top Small Appliance Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
