Question about Sony DCR-HC21E Mini DV Digital Camcorder
LCD Side Screen Display Not Displaying
All functions are working 100% except the LCD Display lights up White and not blue. The LCD does not display anything. However the touch screen keys function perfectly but the play, stop ,rewind, etc., buttons on the display also does not show up but I can work the unit by feel and watch the viewfinder or external tv monitor.
All other functions are 100% OK.
I will appreciate some help.
Thanks
Aslam Seedat, Durban South Africa
aslamseedat@webmail.co.za
  • 1 more comment
  • Seedata Feb 17, 2008
    The main feed flat-tape cable is fractured/damaged due to normal opening and closing of LCD Sidescreen especially by turning the screen 180* degrees. PROBLEM SOLVED by fitting new feed cable.
  • taruna05 Sep 26, 2008
    i have sony HC21E..LCD scrren is blank..i can see in viewfinder but nothing is visible on LCD screen
  • Kathy B1 Apr 07, 2009
    I have the same problem with my LCD screen. How much will it cost to have a new speed cable fitted and where would I go to have it fixed> I live in Brisbane.
    President:
  • 4,402 Answers
The problem is a bad CCD inside the camera. I Sony was providing free service for some of their other models but failed to provide service (recall) on these models. contact Sony at 1-866-703-7669
Posted on Feb 07, 2008
A friends laptop is only showing a white screen
Step 1:
Fix a White Screen on an LCD Monitor
b>When an LCD screen has turned completely white, there are three normal causes: the screen is defective, the video cable is not connected correctly, or the graphics card on the motherboard of the computer is faulty. You will need to troubleshoot these possibilities to determine which problem you have. If you are not experienced in working on computer equipment, you should not attempt to disassemble your LCD screen because you could easily damage it. Seek professional assistance unless you have experience working on computer hardware.
Disconnect the white LCD screen from the computer by unscrewing the blue monitor cable. Connect the working LCD screen to your computer by attaching its blue monitor cable to the same slot. If your computer display does not show on the functioning LCD screen, try rebooting your computer. If it still does not display, the problem is with your computer's graphic card on the motherboard. Seek professional repair assistance. If your computer display shows normally on the working LCD screen, proceed to Step 2. Unplug the LCD monitor with the white screen. Disassemble the rear panel of the monitor with the small screwdriver. Carefully separate the screws into piles so that you can keep track of how to reassemble the monitor. Locate the internal video cable, a gray cable with a plug on the end that connects to the main components of the screen. See the References section for photos of the video cable for assistance. http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/ Unplug the cable, checking for any debris or blockage. Reconnect the cable firmly. Reassemble the LCD screen. Plug it in and connect it to your computer. If the screen is still white, you have a defective LCD screen. You will need to replace it or take it to a professional repair service for assistance.
b> b> b> Without this test you'll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You'll have to disconnect the video cable from the LCD screen (connector 2) and the inverter board (connectors 3 and 1). After that you connect another working screen and test video. For this purpose I'm using one of my test LCD screens. My test screen is cracked and because of that you see a wide white band in the center but it still works fine for this test.
The original screen is white but my test screen works normal (except the crack of course) and I can see the image. After this test I can tell that the problem must be related to the screen. After I assembled everything back together and connected the original LCD, it's still white. CONCLUSION. In my case this problem is related to the LCD screen and it has to be replaced. b> b>
Feb 06, 2013 | Toshiba 16" Satellite A665S6095 Intel Core...
My pc is showing a white screen when iys on
Is it an LCD monitor ?
Disconnect the white LCD screen from the computer by unscrewing the blue monitor cable. Connect the working LCD screen to your computer by attaching its blue monitor cable to the same slot. If your computer display does not show on the functioning LCD screen, try rebooting your computer. If it still does not display, the problem is with your computer's graphic card on the motherboard. Seek professional repair assistance. If your computer display shows normally on the working LCD screen, proceed to Step 2. Unplug the LCD monitor with the white screen. Disassemble the rear panel of the monitor with the small screwdriver. Carefully separate the screws into piles so that you can keep track of how to reassemble the monitor. Locate the internal video cable, a gray cable with a plug on the end that connects to the main components of the screen. See Below for the References section for photos of the video cable for assistance. http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/ Unplug the cable, checking for any debris or blockage. Reconnect the cable firmly. Reassemble the LCD screen. Plug it in and connect it to your computer. If the screen is still white, you have a defective LCD screen. You will need to replace it or take it to a professional repair service for assistance. Hope this helps.
Dec 30, 2012 | Compaq Computers & Internet
My Acer Aspire 5551-2036 wont turn on blue light turns on screen remains black
Does it sound like the laptop booted up except the screen is black? Do you hear the fan running and the hard drive spinning? If so try the steps below.
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 06, 2012 | Computers & Internet
My Nokia N70-1 phone has displaying it's Graphics wrongly?
So if you have a blank display or just a white one, replacing the lcd screen should fix the problem.
See the link below for a guide on replacing the N70 lcd screen and links to buy a new one from ebay.
How to Replace the LCD Display Screen on Nokia N70
Oct 13, 2009 | Nokia N70 Cellular Phone
Display problem
If formatting your phone doesnt help there are three possible problems in order of priority (1) your screen is gone and needs replaced (2) your ribbon cable is gone and needs replaced (3) phone needs flashed, I have repaired the first two above on many samsungs with this fault! Not an easy job! Hope this helps.
Jul 09, 2009 | Samsung SGH-D500 Cellular Phone
Nokia 3230 screen goes blank after a few minutes of turning on.
hello !
replace the LCD theres a posibilty of it being foulty , the IC on the lcd is damaged and please check the lcd socket on the MB .
Thank you
May 28, 2009 | Nokia 3230 Cellular Phone
LCD Display behaving badly
It sounds like the ribbon connector or flexible connector is not seated quite right. I would open up the unit again and carefully inspect this or any other cable that you had unplugged.  Reseat these properly and power it up again.
These cables can be very easy to damage if not replaced properly. Take special care.
Mike
Oct 09, 2007 | Dell Inspiron 8500 Notebook
Sony DCR-HC21E Mini DV Digital Camcorder Logo
397 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
