Furnace starts, but no heat nor fan operation.
Hi, my furnace went out yesterday. It responds to the thermostat, but starts up without any heat, nor the fan. I called a repair guy, he's amazed it still runs for it's age. But, for the ten years I've had. I've never had a problem with it. He believes the lies with what he called the "transformer". Black box, bottom left, bout 3" square x2.5". What do you think? And, is it possible to get parts for this model anymore? lol
Thanks,
Geraldine
  • motobaby Feb 07, 2008
    Ok, after reading my post and responses, I did not realize I was in air conditioners, and I don't know how to post to "Furnaces", although I'll try.
    Anyways, in respnse to Jimfl, I don't know how turn on the fan switch on the thermostat. But, what happens when I turn the thermostat on, is I can hear that the furnace "kicks" in. Sounds normal, as if starting up. The pilot is lit, but does not change from it's lit position. The flame does not get any bigger. I will try to learn and understand what you are suggesting. Thanks.
    In response to "thespark", It's a 1978 Intertherm Gas furnace, model 1378. Responds, meaning that when I turn up the thermostat, the furnace sounds as if in normal operation, except there is no heat, nor fan operation. The furnace does not blow any heat, and does not get hot itself.
  • motobaby Feb 08, 2008
    Hi, and thanks. i spoke with repair dude today and mentioned what you people are suggesting. Repair guy claims he's 100% percent it's the "transformer" as he claims to have troubleshot it and says it has power going to, but not (24V) coming out. I hope I got that right, but that's what I understood, (as this power is needed to open and close the gas valve?). He says that part is obsolete. I live in Northern Alberta, Canada, bout -25 now, -45 the night it went out. But he thinks he can build one, power module/transformer.
    Problem Solver:
  • 10 Answers
If youe burners fire off it's not the transformer. It suonds like the fan/limit control. Try to turn the fan switch on the thermostat to the on position and see if the fan comes on, if it does leave it on and turn the heat on and see if the heat works that way. If so it would be the combination fan/limit control.
Posted on Feb 07, 2008
  • 73 Answers
Please move this to furnaces..
When you say "responds" you mean what?
I hate doing this, but....
gas or oil, what do mean by respond? etc...
  • B Helling Feb 08, 2008
    Hmmmm... So it makes SOME kind of noise, but the fan does not turn, and the main burners do not come on.
    The "transformer" is undoubtedly a simple 24vac or 26vac one...
    Known in a previous life as a "doorbell transformer". Shouldnt cost that much. HOWEVER... you need someone with a voltmeter and patience to go over the furnace, carefully!
    (Ok Im guessing, the model # mean nadda to me.. if this is a 2 year old high efficiciency thing with circuit boards and whatnot, the xformerbox is gonna be mucho more,,,)
    HOWEVER
    Last time I ran into something like that, I was about to replace the xformer, until I tested to see if IT was getting 110V.. Nope...
    But it was hard wired in
    Traced wire back.. 10 feet away, inside a junction box on the ceiling, the twist-on connectors (marr connectors) had come loose and the connection was sparking...
    Ok.. no real fire hazard, was in a metal junction box (and thats why they should be), but could have ripped the whole furnace apart for a new xformer and still had no luck..
    So.. Its all very straightforward.. IF this is to work, its gotta have that..
    Make sure the xformer has power going into it, and nothing coming out before replacing it..
    If uncomfortable with voltage that can maim you, get someone you trust..
    Gluck
Can not get fan on to turn on. All else fine. heat only furnace. No air conditioning...only air circulation.I used to set it on "Cool" and "Fan On"and get air to circulate. Do I need new thermostat?
Since you have two thermostats that operate the heating unit and the fan, and the fact that neither will turn the blower on, I would suspect the furnace/ air handler. Turn the thermostat to heat and see if the heat and the fan comes on, if it does operate normally in heat, the fan relay or the high speed on the blower is most likely the culprit. (If the furnace is equipped with a circuit board, the fan relay is integral to the board, if it an older furnace it has a separate fan relay). If it does not operate normally in the heating mode, verify power to the furnace, see if the flame comes on, if it does: the fan motor, circuit board or the fan relay are most likely the cause. hope this helps!
Jul 20, 2015 | Heating & Cooling
Atwood 38591 Excalibur xt 1522 LP two stage furnace. Operates on high fan only
Hi Dave. I'm Roger. Its normal for a furnace to shut down completely when the set point on the thermostat is reached. The first and second stages are used when the temp. gets close to set point. The heat output drops to its low stage at around 3 degrees before set point. Check your owners manual for specifics on the fan though.
Mar 14, 2014 | Atwood 38591 Excalibur XT Furnace 1522 15K...
My furnace works on ac and blows on ac but on heat it does not blow but i hear a humming sound coming from the furnace
Most furnace operating on Oil or gas will heat the combustion chamber before starting fan to prevent cold air draft at start-up, can last a minute or two. Eiter the main flame does not come on or the chamber thermostat have fail. Try to modify fan option on room thermostat from auto to on. Cold air coming out: burner problem or no more oil or gas, warm air: burning chamber thermostat problem, leave room thermostat fan option to on until repair.
Jan 02, 2014 | Comfortmaker Heating & Cooling
I have a braeburn 3200 thermostat that has went blank on me yesterday. I have checked the fuse box, no tripped breaker, i have checked the switch on the furnace, its on, and there are no batteries. Im not...
If there are no batteries in the thermostat then the furnace was being used to power it. To make sure it is just a thermostat problem, you can jumper the power and heat wires that connect to the thermostat, usually red and white, or terminals R and W. If the furnace comes on, then you need a new thermostat. If that doesn't work, you have lost power at the furnace somehow. If the breakers are good, and the furnace switch is on, then you can have a bad door switch inside the furnace, a bad transformer in the furnace, or a bad circuit board if equipped. If there is a circuit board, they usually have fuses somewhere on them too that can blow. Just be sure to cut power off at the breakers before checking. Hope this helps and good luck!
Dec 11, 2010 | Honeywell Electronic Programmable...
The furnace send signal to the fan in about 30 seconds, now this fan is set in auto from my termostat, my problem is the fan is starting slowly and some time it don't start, but if I use the option manual...
Depending on the model of the furnace, the blower is either a 2 or 3 speed. When the furnace operates in heating mode with the thermostat in the auto position, the furnace starts the fan when the furnace reaches a specific temperature or after a set time delay, but it operates the fan in low or med low speed on heat mode, when you put the thermostat fan switch in the "ON" position, the furnace operates the fan in "HI" speed, the same speed used for cooling mode. You may have a blower moter that is starting to short. I would recommend having a professional replace the motor before now before it becomes an emergency in the middle of the night during a cold spell.
Oct 10, 2009 | Heating & Cooling
Looks like my humidistat calls for coil fan and for furnace heat
It sounds like the humidifier may be improperly wired.
It's hard to solve without checking the wiring, but it seems like the humidistat is wired so that as the dial is advanced, it incorrectly turns on the fan, or furnace, or both.  The contacts of the humidistat should be wired so that they turn on the solenoid only.  Also, the power to the humidistat, to turn on the solenoid, should come on only when the fan is on.
Hope this helps!
Jan 03, 2009 | Aprilaire 550 Humidifier
Fan on but no heat
I never liked the user un-friendliness of the Chromatherm, I would suggest finding a thermostat that you can understand and operate. Yes the Chromatherm is a good one, but so damned hard to figure out. Stay away from thermostats that still use mercury. Good Luck!
Oct 20, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
1,593 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
