Question about GoVideo Go Video DVD/VCR Combo
DVD will not play, door opens,,go video 4940
How do you clean the dvd lens?
  • cars 087 Mar 25, 2008
    go video 4940 -will record or play already recorded dvds-blank dvds the 4940 will just display reading-already recorded displays reading then not
    recognizable-then ejects the dvd-this all started when the 4940 would not
    eject the dvd or shut it down- had to unplug the dvd &then plug it backup-
    then it would eject.
    Guru:
  • 1,463 Answers
There are dvd discs that you can buy for this and will do the job.
google -dvd disc cleaners .
riz.
Posted on Feb 07, 2008
Lg mini home theatre model FB 162 dvd door will not open dvd's will not play will not play
look for a tiny hole in the dvd door; insert a straightened paperclip into the hole; push in; the door will open then clean the laser lens with a dvd cleaning disk by running the disk in the machine
Feb 18, 2013 | Audio Players & Recorders
What dvd laser lens cleaner should I use for my Samsung p241 dvd/cd player?
You can use any branded DVD-lens cleaner. I recommend Sony. It is just like a normal DVD except that brushes will pop out to clean the lens when you play it. After the cleaning is complete the sample video file on the DVD will be played indicating that it has been cleaned. Otherwise clean again.
Apr 04, 2011 | Samsung P241
Panasonic SC-DP1. Sometimes plays a dvd, sometimes doesn't (same dvd!). same dvd plays on my other dvd player (toshiba). Any answers please? Rob - uk
hi!!can i help you?
did you already tried to open your dvd?do have somes skills in electronic let me teach you some basic,open your dvd player y\using philips screw,,then try to look for the lens,,get some pc. of cotton and clean the lens carefully,reminder pls dont touch directly the lens,,after cleaning your dvd player close it and try it,,,before playing the disk clean it first,hope this steps will turn your dvd player in a good condition,,,
Feb 04, 2011 | Panasonic DVD-RV31 DVD Player
RCA RTD315 Theater System The DVD Player recently
My identical system has exactly the same problem as the one described by dipaola, above. When I insert a DVD, the DVD carriage pops back open after a few seconds. In fact, mine won't stay closed even without a DVD in it, as long as the system is set to play a DVD. I'd like an answer to the big Q - Is there anything I can do about this, or should I just find another DVD player to hook into the system?
Nov 05, 2010 | RCA RTD315 Theater System
Só le cd audio naum le dvd msg bad disc
Hi its look that you need to clean the laser lens
manualy open the cover press eject unplug the dvd leave the door open and with a qtips and alcool wipe gently the lens
and its done put the cover back and try it its should works
and make shure that you have a clean disk before try to play it
hope that will help you
regards Alan.
Oct 13, 2010 | Philips DVP3040 DVD Player
I have a Toshiba DVD Video Player Model SD 260. I
Hello, The problem could be dirt on the surface of the lens, you can clean this by removing the cover of the dvd player . Gently use a dry cotton bud to clean the lens because the lens is fragile. Insert the disc plate into the dvd player and press play, if it does not play try the second method. Ensure the cover of the player is open, connect the power plug to the mains socket and observe the lens if it beam a red light, Also check the ribbon cable use to connect the lens to the printed circuit board, then gently clean the lens with a dry cotton bud , insert the disc plate and press play to see if it play. If it does not play the disc, then this require a change of the lens
May 20, 2010 | Televison & Video
Door and dvd
remove the player from ur car and if you are good at opening the player then just follow this steps...
1.take of the screws
2.remove the cover
3.take off the rubber belt connecting the dc motor
4. now you can take the door out by sliding one white coloured clip
5.now clean the obstacles in the door way and every where
use dry clothes..
6.clean the lens also by using the white petrol or spirit....
then reassemble just put the cd r dvd and play...
if you are not good at opening then contact the technician........
Feb 08, 2008 | Car Audio & Video
Proscan dvd player
the manual may be available in some of these following website....
www.allamericandirect.com/TOSHIBA_PRO_SCAN_DVD_VCR_COMBO_Player_NO_TUNER_p/sdv295.htm
www.usersmanualguide.com/funai/dvd_player
just open your dvd player with the door ejected and then just clean the dust particles and obstacles in the door way and especially clean the lens... use only dry clothes for cleaning ... after that just give a try..
if problem persists or if you are afraid of opening it or if you dont have any idea about it then contact the near by technician and tell your problem...
he will clean the lens with the white petrol or spirit...
then your problem will be solved ...
he will not charge much for cleaning lens he may charge 100 bugs or 150 bugs that s all ...
and if there is any other problem just like the lens is out something like that he may charge more...
Feb 08, 2008 | Televison & Video
Go-video combo dvd player vr4940
try to clean your laser lens then try to play new movies you can get a DVD laser lens cleaner cheap at walgreens,walmart or target
Jan 09, 2008 | GoVideo Go Video DVD/VCR Combo
GoVideo Go Video DVD/VCR Combo Logo
Top GoVideo Televison & Video Experts
Marvin
Marvin
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
