Question about HP LaserJet 5p Printer
Paper jam i keep getting the paper jam message then the red light comes on so ive looked thru to see if i can find a jam any where and there really isnt one! got any ideas ? thanx
  • paper jammer Feb 07, 2008
    wow thanx for the idea, yes the printer did start at the ready status then to the jam message. awesome job thank you very much for the help.
I've got similar problem but I noticed torn paper jammed. It can be seen between small black weel when you turn it upisde down
Posted on Feb 14, 2008
  • 168 Answers
When you turn the machine on, does it get to READY status or does it go into a jam message right away?
If it gets to READY status, and you get a jam code after you try to print, then your feed rollers might be either dirty or worn. Try cleaning the rollers with with Goo-Gone which is a pretroleum based cleaner that wont dry out the rollers.
If it never gets to the Ready status, then you either have a stuck or broken sensor in your printer. This would be harder to troubleshoot. 1st you would have to know where the sensors are located, and then would have to be able to clean/check and or replace it.
Hope its the easier solution.
Good luck
Posted on Feb 07, 2008
I had a paper jam , now i have a loud clicking noise left , red light screen says door open . ive checked all doors taken toner out and put back in removed paper drawer and replaced still nothing
THE LOAD CLICKING NOISE COULD BE THE CARRAGE JUMPING IN AND OUT, DUE TO THE CARRIAGE BEING JAMMED,SWITCH OFF POWER AND TRY MOVING CARRAGE ALONG SLIDE, REASON FOR THIS ANSWER IT HAPEND TO MY PRINTER AND I CLEARED IT BUY DOING AS ABOVE
GOOD LUCK
Sep 22, 2016 | Samsung ML-1910/SEE ML-1910 Mono A4 Laser...
Epson Photo RX510
Hi when you switch it on have you tried holding down the on off button for about 10 seconds as this often resets most printers.
Also when you sya thier is no paper jammed in printer are you absolutely sure their is not even i tiny bit of paper still stuck as it only takes a tiny bit of paper to make this message appear.
If you are confident in removing the paper feed witch is difficult to do as you need to make sure it goes back perfect as if it isnt the paper wont feed.
Alot of people say their is no paper jammedand they call somebody out to repair the printer and they get charged a fortune for removing a tiny bit of paper.
If holding the button down dont work then try switching the plug on whilst holding down the on off button let me know how you get on ok
Dec 10, 2007 | Epson RX620 All-In-One InkJet Photo...
My epson xp-312 will not print on photo paper.it keeps saying paper jam.how can i load when the back tray only allows one sheet of normal paper?
When a printer indicated paper jam, it means one of its sensors does not indicate a movement of paper, where it expects it. In only rare occasions the sensor is defect, but most of the time here is really a jam. This must not be a complete sheet of paper. Can be a little scrap left somewhere in the printer. Sometimes a paperclip fell in or just a paper tray was not put in place. Please open the printer and look careful using a flash light, to see if you can find anything that does not belong in the printer. Then switch it off and really unplug it for a few seconds. Reinsert the plug and switch on. If the error keeps coming back you should call a service centre, although ig you have to send it in for repairs, a new printer is probably cheaper, unless it is still under warranty.
Jan 13, 2015 | Epson Office Equipment & Supplies
Sx218,keeps sayin paper jam when there isnt any paper jammed
It sounds like a sensor is stuck. Sometimes a very tiny piece of paper is stuck near the sensr. I use a flash light to check. Have you tried turning off and on? Sometimes that will clear the error message.
Sep 06, 2011 | Office Equipment & Supplies
Both the ink light and the paper light on my printer keep flashing when i turn it on and the computer tells me to remove a foregin objecct but there isnt any. i have turned it on and off. Thanks
try re-installing the drivers
if that doesnt work, take apart the rear panel of the printer and really look for any sign of paper jam in the printer rollers.
May 02, 2011 | Computers & Internet
Pixma mp480 jams paper!!! It occurs on the left side Ive tried different paper and it continues to do the same thing I really disappointing because I just bought 4 months ago and I thought canon was a good...
Please try this and also try cleaning the printer and the paper rollers that it has.
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Canon Pixma MP480 All-In-One InkJet...
Car wont start
IS THE RED LIGHT THAT IS STAYING ON THE BATTERY LIGHT? IF SO IT COULD BE AN ELECTRICAL FAULT, AND IS NOT FIRING UP THE ELECTRIC FUEL PUMP
Mar 13, 2009 | Acura CL Cars & Trucks
'paper jam' error on canon pixma ip4300
ring canon support on 0844 369 0100
or try
support.canon-europe.com
they suggested i do a roller cleaning - but i cant find this option ?
Jun 24, 2008 | Office Equipment & Supplies
Error message "paper jam"
u need to remove the fuser and remove the paper in it, put fuser back in the reverse
Jun 04, 2008 | Brother MFC-8440 All-In-One Laser Printer
RED LIGHT BROTHER 2040
light explain link check first!.... paper jam light indicates a few things ie paper mismatch.
possible dirty feed roller, confirm by using bypass slot.
slightly damp rag on rubber feed roller to clean if the issue
Dec 22, 2007 | Brother HL-2040 Laser Printer
HP LaserJet 5p Printer Logo
136 people viewed this question
Ben Johnson
