Question about iRiver H10 MP3 Player
How do I take it appart
Hey, How are you doing? I need to replace my battery. How do I get the back off
    Problem Solver:
  • 20 Answers
Lately, they've been building disposable MP3 players. Mine has got a lithium/ polymer battery that "should" last for years. Once it's shot, the whole thing is shot- unless you run it off the charger. So much for portability.
Posted on Feb 07, 2008
Broken battery door
Un-screw the assembling screw, just enough to slightly lever the two piece housing appart. That should open sufficiently for you to align the tiny pins from the door with the recess in the housing. Press back the two-pieces housing and tighten the screw.
Jan 18, 2014 | Canon Cameras
Changed boot sequence in bios, now I cant access bios, and screen is blank. is there an easy way to reset the laptop back to factory?
The only way to reset the BIOS is to take the laptop appart, remove the CMOS battery and short the reset jumper on the motherboard. Unfortunately this is unrealistic unless you are handy with taking things appart and putting them back together.
Let me know if you have any questions.
Jun 29, 2011 | Averatec AV1050-EB1 PC Notebook
How do i replace the battery - take it appart
Unfortunately you can't. According to garmin it is not a user replaceable battery. It may be possible to send back to garmin to have it replaced.
Jul 27, 2010 | Garmin StreetPilot C330 GPS Receiver
The back doesn't seem to want to snap back in
Try a very small dab of a very light lubrican on the sealing edges.
If you haven't already tried it, press the edge of the watch back using two fingers and move them appart until they meet again.
Season with a lot of parience... good luck!
Apr 19, 2010 | Timex 27191 Wristwatch
How do I get this thing appart and put in new
First, you need to gently pry off the 'cap'on the bottom that surrounds the hole for the cord. Once removed, the side grips will simply pull away revealing 4 screws. Remove screws to take off back cover. Circuit board will then simply lift out.
You will find compatible batteries at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
Apr 18, 2010 | Braun Syncro 7526 Electric Shaver
Apperantly the battery went dead. How can I
you will need a number 5 torx screwdriver, remove the 4 screws in the back of the unit and then remove the back cover wich is now hold only by clips, be careful because the battery is glued to the back cover that give accsess to the battery! also you can check out this tutorial on youtube on how to take appart the TX!
Apr 06, 2010 | Palm TX Handheld
INEED TO REPLACE THE POWER ANTENNA IN MY 2000
Hello, i've just checked in the procedure (25 steps in all to take it out, that's a lot!!!) for a antenna replace for you're corvette and would recomand you to go to a dealer to get the antenna replace. You may think it will be caustly but those guys know how to take it appart and won't fool around like any other mecanic that won't have the procedure. I would not recomend you to do it you're self since the procedure requires you to take most of the back end of the car appart. But if you still feel corageous, send me a message and i'll post the procedure for you.
Oct 24, 2009 | 2000 Chevrolet Corvette
Does not rinse or completes washing
Hey I have mine appart right now and the pump is busted, with a sheared keys on the impeller shaft. If you get it appart and can pull the impeller shaft out of the armiture you have sheared keys; this shaft should be nearly impossible to remove if the keys are still good. Mine look to have been a bit rusted. Likely cause is inferior steel succoming to bleach; which we use all the time to rid the washer of the persistant mildew.
Al the robot guy
Nov 08, 2008 | Kenmore Elite 45986 Front Load Washer
Bios Battery
You need to separate the motherboard from the back of the touchscreen.Don't try to totally disassemble it, just get it to where you can remove the board with the battery.Then you can carefully remove the small board with the battery.
Mar 09, 2008 | Aqcess Qbe Altus Tablet PC
iRiver H10 MP3 Player Logo
125 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
