Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
Akai PDP4294 - Snowy, pink & green picture
Anyone point me in the right direction on this TV
Main menu and source menu look good, sound ok, channels ok, except picture has a rolling diagonal pattern, seems to need possibly horizontal and/or vertical alignment / adjustment at the same time went kinda pink / green / snowy , hard to make out picture very well.
Any ideas or opinions would be much appreciated !
LB
  • LanceB Feb 07, 2008
    Thank you coleslaw424.
    I also hooked up a DVD player and tried switching source to Video and S-Video with same picture.
    Does that still sound like tuner problem ?
    If so is there any sources for the parts, maybe used ?
    Mahalo !
  • 43 Answers
It is most likely a problem with the tuner, I would contact the place you purchased it or your nearest repair shop.
Posted on Feb 07, 2008
  • Carl Sizemore
    Carl Sizemore Feb 08, 2008
    Yes it still sounds like a tuner problem because the tuner converts the signal from your antenna or cable provider into a picture, so it would stand to reason that no matter what output you were to use if the tuner is malfunctioning it would not make a difference. as far as parts go unless you had some great luck and ran into someone with a broken screen or something you will be hard pressed to find used parts, your best bet is to contact the manufactuer, if you are able to do this sort of soder work yourself they may sell you the parts. Glad I could provide some insight, sorry it wasn't better news.
    best wishes
    Carl
SOURCE:
You have to turn up the volume to 38+ in order to hear the TV, when you use to be able to hear it at 10, is there a control board that goes out and what Is the name of it?
Hi Geoff, I hope I can help you with this. If you are using an accessory device (DVD, DVR) check cables to see that they are secure and if device has audio out option that it is set correctly. Also check to see that Video and Audio cables are connected to matching inputs on your set.
If you are using DVI to HDMI you will need to use a separate digital audio cable. DVI cables do not carry audio signal. After attaching the audio cable if you still do not hear sound you may need to set Digital Audio In. To do so:
  1. Press Menu Button on remote.
  2. Press the cursor ring down to highlight SETUP.
  3. Press the cursor ring left to enter SETUP menu.
  4. Press the cursor ring down to highlight SOURCE.
  5. Press the cursor ring left to enter SOURCE menu.
  6. Press the cursor ring down to highlight DIGITAL AUDIO IN.
  7. Press the cursor ring down to select the source you want to associate Digital Audio with. HDMI 1 or HDMI 2 in this case. You might need a software update also.
    The latest software solves the issues below:
    1. TV (Plasma 42" and 50") will not turn ON/shut off itself and Red LED blinks 4- times. Recover if main switch on/off.
    2. 37" LCD full white screen appear when upgrade software.
    3. Some channels not available after turn ON.
    4. Delta volume changes, not remembered.
    5. Preferred channel changes, not remembered.
    6. Green or yellow static (sometime snowy) on HDMI picture.
    7. Picture and sound loss for 5 to 10 sec (green LED is still ON) and back to normal.
    8. Audio loss in all inputs and can be recovered when main switch ON and OFF.
    9. TV set turn ON by itself/ green LED light up and goes off when set is ON.
    10. Intermittent audio loss in NTSC RF channel.
    11. Crack sound with high input signal.
    12. Include the possibility to download the rating table (RRT5 capability) for digital programs.
    13. No video/ no picture with sound.
    14. Intermittent On-Screen Menu pop up by itself and can be removed by pressing the 'MENU' button.
    15. Channel information display too long.
    16. Improvement on scramble channel.
    How to check the current software version on my TV set?
    1. Press 'MENU' button on remote control to display the on-screen menu.
    2. Select TV MENU and press the cursor right.
    3. Select INSTALLATION and press the cursor right.
    4. Select SOFTWARE UPGRADE and press cursor right.
    5. Select CURRENT SOFTWARE INFO to display the current software version on your TV set.
    6. If the TV software version is lower than the version posted on the website means your TV set needs to be upgraded.
    7. Follow the instruction in the user manual or Firmware Upgrade Readme file on how to upgrade your software.
    Where can I find the latest software for my TV set?
    The Firmware Upgrade Software and Readme File documents can be found on the Philips support website. Refer to the SOFTWARE section.
Feb 04, 2016 | Televison & Video
Defective Picture, Sound ok
You will most likely need both convergence IC's in your TV. Need a service call.
Oct 30, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
I have a samsung lcd tv that powers on has sound but the picture is fuzzy and has no colour . What would be the component that needs replacing for this ??
Hello. Before you start replacing parts, make sure your connections are correct. It sounds like you have connected a composite source to a component input. Composite is three RCA plugs, a yellow for all of the video, and a red and white for audio left and right channels. Component is five RCA cables, green, red and blue for video, and red and white for audio. if composite is connected to a component input, the picture will be black and white with squiggly lines all through it.
Mar 31, 2015 | Samsung LN40A550 LCD TV
Akai PDP4294 has pic, but no sound.
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
May 20, 2014 | Akai Televison & Video
My tv has sound but no picture its an akai model pdp4206em1
Try unplugging it for an hour or so or try change sources , if the computer ever fell asleep while it was plugged in it is possible it triggered a sleep mode in the tv. Most will do such a thing. It is doubtful that the computer caused any damage to it but i would advise against using a plasma tv as a computer monitor because burn in WILL eventually occur with a static image left on the screen constantly.
Dec 26, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai pdp 4294 wont turn on
The power supply board needs to be replaced or repair. No other quick fix is available. Thanks
Nov 26, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Almost same symptom
Probably what happend to mine. It's all the same problem. It's actually fixable. I repaired mine.
Jun 04, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
1996 RCA Color TV model G27720tn
If you are on cable, first run the cable wire from the wall directly to the TV, eliminating any cable box and/or VCR. If channel 2 is snowy but the rest (especially 3-6) are clear, it is most certainly a cable problem and not a TV problem. The TV uses the exact same circuits for channel 2 to 6 (VHF-LOW) so if the tuner was bad and 2 was snowy, 3, 4, 5 and 6 would be snowy too. Bring a second TV into that room, disconnect the cable wire from the RCA and connect it to the second TV. Is channel 2 on the second TV as snowy as it was on the RCA?
Aug 18, 2007 | RCA 24V511T 24" TV
Akai Plasma model PDP4294
SOME TIME IT IS THE CABLE TV BAD CONNECTION, CHECK THAT.
Apr 22, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Screen went out
I had the same problem, but I had no sound at all. The power indicator light was flashing green. I tried to unplug the unit and plug it back in, but the light then was red briefly, turned orange then flashing green. What I did to solve the problem was to unplug the set and leave it for a few minutes then plug it back in and hit the front power switch at the same time. Voila! It started working again. Good luck solving this.
Aug 18, 2006 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
138 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
