Question about Nokia N70 Cellular Phone
Unable to charge
My charger is not working. Is there any other way i could charge my phone Eg: using a computer code. Or can i use a normal nokia charger to charge my N70 phone
If the input fix's with your phone u can charge it but it is strongly recomanded to buy a new charger...is not very expensiv and it's more safety...
Posted on Feb 07, 2008
I forgotan my security code
Your chances are up (3 chances) so now your phone SHOULD say "Enter PUK code" which then, you have to contact/ go to their shop of YOUR PHONE PROVIDER [eg orange vodafone, tmobile, etc] and then they will TELLyou the PUK code (free of charge), type it in AND your phone will be back to normal .
May 29, 2010 | Nokia 1600 Cellular Phone
Charging problem
Buy a new charger. If your computer charger works, and either your house or car charger are not working it is whichever is not charging the phone that is the issue. .
May 06, 2010 | Motorola Mobility SLVR L7 Cellular Phone
Hi,my nokia n95 wont hold charge i have a new battery and new software,do you know what the problem could be,also when it charges it doenst cut out when it is charging it just keeps charging,thank you
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Dear user,
Such issue may appear when Nokia charger adapter CA-146C is used with incompatible charger to charge Nokia N97. Currently compatible chargers for N97 with CA-146C are Nokia Travel Charger AC-4 and Nokia Compact Travel Charger AC-5.
Spangley, just plug it into your PC. If your battery needs charging, it will charge slowly simply while being connected to your computer. Nothing else to do!
Goodluck :)
Dec 11, 2009 | Nokia N95 Cellular Phone
When charging nokia E71, it randomly stop, then continuing?
If you are having these problem with your nokia, there are two possible reasons why this should be happening;
1. You could be charging it with a faulty charger, and you should get another e71 charger for it. You can probably use this same presumed faulty charger on another nokia phone and if it does work well then it implies that the charger is fit and well. So please don't replace the charger.
2. This therefore leaves us with the last option which is the battery, please replace the battery you've got and your phone would charge normally.
Hope this helps as i presume that your charging port is very much ok.
Regards
Aug 05, 2009 | Nokia E71 Smartphone
Nokia N73 Music Edition Charges Forever
try factory reset ...... if that does not work get it checked with the nokia service center
Mar 07, 2009 | Nokia N73 Music Edition Smartphone
Nokia 6600 bluetooth promblem
Please restore the factory settings by pressing *#7370# it will ask for your security code (default 12345) enter it and proceed. Phone will restart. It will take a while to restore settings so please be patient. Once restored your phone's bluetooth should work just fine.
Important: Make sure phone's battery is fully charged (or keep the charger plugged in) before performing the above operation.
Feb 09, 2009 | Nokia 6600
Phone wont charge!!!
Do you have a way of reading the output voltage of the charger?
Normally, the phone will protect itself first. So, its must be your charger that's bad. These aren't warrantied very long so you'll have to go to the phone store and see if you can beg another out of them. Otherwise your normal cost is under thirty dollars.
Sorry for the bad news, but your phone should be okay.
Any other questions just ask using the comment box below.
Regards,
Worldvet
Jul 21, 2008 | Motorola Mobility RAZR V3
Nokia 6234 Charging circuit
No, take the battery out and bring it to an auto part store and they can test it.
Jun 18, 2008 | Nokia 6230
Mobile Phone - Flip
"unable to charge", "insert sim". is your phone been dropped or got wet? if unable to charge, when using a wall charger, try different outlets. if using onl one charger, tr different chargers. if it won't work, try other compatible batteries if you would get a charging message. if does not work, have your phone checked with a service center
Sep 01, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Wont charge!
1. The charger may be damaged To check if the charger is damaged, use another functioning charger. The charger cable has a tiny wire that easily breaks when used without proper care. If the phone still does not charge with a functioning charger, try next step. 2. The battery may be damaged Change the battery and try charging again. If the phone still does not charge with a functioning battery, try next step. 3. The battery terminals may not connect properly with the battery connectors Check the battery connector to see if the battery and the connector connects well. The phone will indicate charging only when there?s enough power supply from the battery. click here Solution Procedure: If problem is confirmed, adjust the battery connector using tweezers to reach the battery terminal and establish connection. Or try next step. 4. The charging pin may be damaged or does not connect well with the board's interface Check the charging pins to see if they are well connected to the mother board. Sometimes the charging pins wear out or loosens from its connection with the mother board. Solution Procedure: Check if the pin is bent. Straighten the pin using tweezers. Make sure the board interface is also clean otherwise, you will need to clean it by rubbing its surface using an eraser or brushing it with a board solution. Or replace with a new charging pin. Make sure the charging pin touches with the board interface to establish connection. The CCONT IC for DCT3 or UEM for DCT4 or the "K" resister for non-Nokia models may be damaged If the phone still does not charge after adjustments are made, the problem is CCONT IC for DCT3 or UEM for DCT4 or ?K? resister for non-Nokia models.
Aug 19, 2007 | Nokia 6300 Cellular Phone
Nokia N70 Cellular Phone Logo
61 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
