Question about Nakamichi SoundSpace 8 System
Need new 8 pin power source wire from receiver to subwoofer
Recently, my electrician spliced the power wire that travels from the receiver to the subwoofer.  It wasn't long enough and they were not able to regain power after splicing.  I have looked everywhere....where can I get a new wire that is at least 15 feet long? Preferably 25 feet long.
  • 979 Answers
Repair the Splice. Distance is not an issue with the lengths you describe. If the splice was done incorrectly and wires were crossed, you may very well have damage that needs to be addressed....accordianman
Posted on Feb 29, 2008
I recently had a new electric hot water cylinder installed, but am unhappy about the electric tubing which travels along the wall from the cylinder to the power box.
get the electrician back to make it comply with the power authority standards for wiring installations
If he objects have the wiring inspected by a power inspector , who will , if not satisfied , issue the electrician with a notice to conform or face a charge
Apr 21, 2018 | Water Water Heaters
I would like to connect my Philips subwoofer to my Pioneer multi channel receiver, but the subwoofer's input has only a 15 pin serial port connection. I need an inexpensive and easy solution?
Unfortunately, most subwoofers , like the one you're describing, need a separate amplifier. I don't know the model number of what you're working with but most Phlips subwoofers with that connection need an amp. Now, if you have the rest of the system that was originally with the sub then you can scavenge it's amp. But that's tricky if you don't know what you're looking at. Craigslist has tons of "powered" subwoofers that don't require a separate amp and u can therefore use your Sub Preout from the HT receiver.
Feb 13, 2016 | Pioneer Audio Players & Recorders
How do I remove alarm brain box from wiring on a
"I bypassed the immobilizer circuit only on my alarm module (which is really tedious). Bypassing the whole
module is possible (and little easier), but you will lose the use of the remotes and the ability to arm the alarm.
The alarm module in my '97 900 SETC is located under the carpet, below the driver's power seat switches (a
pain to get at).
If you want to bypass the module completely:
1. Disconnect the battery (make sure you know the radio code-if needed)
2. Unplug the connector from alarm module and remove module from car
3. Install a wire jumper between pin 8 and pin 20 in the connector
4. Install a wire jumper between pin 9 and pin 21 in the connector
5. Install a wire jumper between pin 10 and pin 22 in the connector
6. Wrap securely with electrical tape
If you want to bypass the immobilizer circuit only:
2. Unplug the connector from the alarm module
3. Cut the following wires from the back of the connector and splice together as follows (Don't cut the wires too
close to the connector, because someday down the road you may want install a new module, so you'll have to
reverse this process):
4. Cut the wires to pin 8 and pin 20 and splice together w/ wire nut
5. Cut the wires to pin 9 and pin 21 and splice together w/ wire nut
6. Cut the wires to pin 10 and pin 22 and splice together w/ wire nut
7. Secure all with electrical tape
8. Reconnect the connector to the module
Not knowing the details of your problem, please be aware that this may, or may not, solve it. Good luck and let
me know how you make out."
Oct 02, 2014 | 1997 Saab 900
I have a jvc th-m606 receiver and I don't have a subwoofer for it, is there a different way for me to get audio output or a different subwoofer I can use?
You would have to make a cable that goes from the 8 pin mini din of the jvc unit to each individual speaker. A wiring diagram can be found online each pin on your 8 pin goes to a speaker , and one is for power. Find a wiring diagram and find a cheap electric store that can make the cable for you. I had the same problem...
Aug 10, 2012 | JVC TH-M606 System
Splice Bose speaker to connect to receiver
Each speaker has two 4 Ohm drivers. Each speaker has a connector with 4 pins. From left to right they are + - - +. Say 1 2 3 4 . If you want a 8 Ohm speaker connect 2 and 4 together. Now 1 goes to your amplifier (+) and 3 to your amplifier (-). In yor case join black with blue. Now red goes to the amplifier red and green to the amplifier black.
Nov 27, 2011 | Bose Cinemate Digital Home Theater System...
I would like to connect my powered subwoofer (Atlantic Technology model 212 SB) to my Sherwood RX5502 receiver. Unfortunately, the receiver has no subwoofer outputs, only speaker outputs, and the...
Cables between sources and compatible units rarely need to be physically modified.
Register and download the manuals for free at retrevo.com
http://www.retrevo.com/support/Sherwood-RX-5502-Receivers-manual/id/3124dj384/t/2/
http://www.retrevo.com/support/Atlantic-Technology-212-SB-Subwoofers-manual/id/866dj197/t/2/
Splicing headphone outputs designed for nominal 8-ohm impedance speakers to a 47K-ohm (typical) RCA load is not a good idea but it might work on the Sherwood because this receiver does not automatically silence your other speakers when the headphone jack is installed.
There is NO other volume-controlled output to choose. Try it.
Mar 25, 2011 | Sherwood RX-5502 Receiver
I have an older Pioneer TS-LX100 powered car subwoofer. It is missing the power plug, which is used to connect the 12v+, remote, ground, and speaker level inputs. It is an 8-pin connector. I have a power...
You can splice one wire at a time instead of cutting them all at once. Just cut one wire, splice the same wire from the old connecter to the new one. You can identify which pin is which by using a multimeter to find 12 volts and use it set to continuity to see what pin is connected to the wire you just cut.
Oct 01, 2010 | Pioneer Car Audio & Video
No power to recently installed after market radio
Assuming that you checked the fuse, is there any wires in the area that are not connected and can you check them for power? If not, ground one side of your meter and take a wire and wrap around the other lead (set your meter for dc voltage) splice or wrap a straight pin onto that wire coming off the meter. Turn ignition on and stab wires until you get a voltage reading. The best wire would be the color wire coming from the radio fuse holder. But at this point you need power so which ever wire that gives you power splice it to power input of the radio.
Jan 13, 2009 | Pioneer DEH-P2900MP CD Receiver...
Wire kit for a Audiovox BA200 200 Watt base tube
There are 5 wires to connect to the BA-200 for proper operation. 1. Red Wire with Fuse: Connect this wire to a source of + 12 volts which does not turn off with the ignition key. It may also be connected directly to the po~itive (+) terminal of the battery. 2. Black Wire: Secure this wire using a screw or bolt on a grounded metal surface of the vehicle. Clean-away any rust, dirt, or paint from the surface to make sure a good connection is made. 3. Blue Wire: This wire activates the BA-200 when the stereo system is turned on. Connect it to the "Power .Antenna" lead from your car stereo. If your car stereo does not have or you cannot locate the Power Antenna lead, the blue wire can be connected to a source of + 12 volts which is turned on and off with the ignition switch. In this case, the BA-200 will be activated whenever the ignition switch is turned on, whether the car stereo is on or off. 4. Green Wire: Splice this wire to the wire going to the positive (+) terminal (sometimes indicated bya red dot) of the left speaker of your stereo system. 5. G ray Wire: Splice this wire to the wire going to the positive ( + ) terminal (sometimes indicated bya red dot) of the right speaker of your stereo system. You Need to order this piece trough the manufacturer, with out this piece the sub is useless, i am guessing around $20-$30 for it
Jun 06, 2007 | Audiovox BA200 Car Subwoofer
Nakamichi SoundSpace 8 System Logo
246 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
Rommel Balcita
Colin Stickland
Colin Stickland
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
