Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washing machine won't stop filling
My Frigidaire front load washing machine will fill, agitate, fill, agitate then continue filling. I physically need to turn the timer to start the drain sequence. The washing machine will go through the cycles until the last fill where I'm required to turn the timer again to the final spin. I've replaced the timer thinking that may be the problem, but it hasn't solved anything. I've also replaced the water level switch, but that didn't help either. Any help you can provide would be greatly appreciated.
  • 3 more comments
  • Anonymous Feb 14, 2008
    Frigidare front loading washer mod# CRTF120ASO purchased 3/04 - water filled up tub until the door burst open (the dial indicated that it was at the end of the White cycle). Pushing in the on/off knob did not stop flow of water to tub so I had to turn off the supply line. After cleaning up mess and checking the waste line I tried to run a new batch of laundry. Dark setting seems to work fine (well, one load did). The White setting does not work properly - tub continues to fill unless you turn off the supply line to the washer (water was at the TOP of the door and still filling when I manually turned off the water supply line at the spigot). Simply pushing in the dial stops the machine from agitating but it does not turn off the flow of water to the tub. You then need to turn the dial (with the water supply still off) to the 'drain' portion of the cycle.
  • mkazins Feb 16, 2008
    hose from pressure switch had a crack....solved problem
  • msbabe63 Mar 26, 2008
    I have a 8 cycle topload Frigidaire Washer that will not stop filling up or not agitate on all cycles. However it will spin dry and empty the water ONLY if I manually advance it to the spin cycle. I've seen so many possible solutions that I am a little overwhelmed now.
    I'm tring to decide if I shud bypass the little door lock thingy or replace water level hose or replace coupler or replace timer or maybe all of the above.
    Anxiously awaiting your expert advice....I dont have the model number at hand but will get it when I get home if necessary.
    Thanx in advance
  • Anonymous Mar 19, 2014
    Machine turns on and timer counts down, Partially fills then stops and timer keeps going
  • Anonymous Mar 22, 2014
    Timer won't finish cycle and keeps reverting back intermittently to different times and then continues the cycle again
  • 57 Answers
It sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
Posted on Feb 16, 2008
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
Kenmore washer 90 series continue to fill w/water. Load size won't stop the fill... had to shut off water source. won't get to agitate phase... just want to stay at fill stage... can drain, spin,...
Sounds like the fill switch needs to be replaced. A good way to test it is to set your machine on low fill and see if it fills past 3/4. If it does, it's the fill switch.
Aug 20, 2011 | Washing Machines
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Doesnot stop filling water
To javed_iqb904, does the drum actually fill or does it seem like that water is draining out as it's filling?
To neonllama19, if it fills with the tap on and the machine off, it sounds like a defective water valve. If it never stopped filling it sounds like a defective pressure switch or hose to the pressure switch is loose or diconnected.
Jan 08, 2009 | Frigidaire GLTF1670A Front Load Washer
Frigidaire washer won't agitate
hi Cinebar.
this is what i found from the internet so not sure if this will be off help to you.
There could be several reasons why your Frigidaire washer will not agitate, including problems with the power supply, the wash cycle or the way in which the appliance was loaded. It is a good idea to try to resolve the problem with your washer yourself first since unnecessary repair call-outs can potentially be expensive if your appliance is outside its warranty period. Troubleshooting your Frigidaire washing machine will take about 15 minutes.
Confirm the water shutoff valves are open. If your Frigidaire washer cannot draw water from the pipes, it will not fill or agitate. The shutoff valves are usually located behind the washing machine where the water pipes meet the wall. Allow the washing machine to cool down for 30 minutes. Frigidaire appliances automatically shut off if the motor starts to overheat. The cool-down period lasts for half an hour if the appliance has not been switched off manually.
Verify that the detergent draw is tightly closed. If the dispenser is left open, the washer will not start or agitate its load. Push the draw so it sits flush with the front of the washing machine.
Ensure that the washing machine door is closed. As with the detergent door, the appliance will not start if the door is left slightly open, to prevent water from spilling onto the floor. Push the door closed until it clicks, and try your load again.
Confirm that your Frigidaire dryer is set to a spin cycle. If your dryer is set to a soak cycle or is currently in the soak portion of a longer cycle, it will not spin or agitate the wash. Make sure the appliance is set to a spin load and try again.
Contact Frigidaire if problems continue. You may be entitled to free service if your washing machine is within its warranty period. See Resources for Frigidaire's contact information.
or read up more at this link.
Frigidaire washer won agitate Google Search
Dec 11, 2017 | Frigidaire GLWS1649A Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
379 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
