Question about Samsung HLR5667W 56" Rear Projection HDTV
Won't turn on
Had a Samsung DLP television given to me by a customer of mine because he couldn't get a replacement color wheel for it. I waited 2 months for the replacement color wheel to come in the mail before I could work on replacing it. I pulled the Rear panel off, slid everything out and pulled the old color wheel out. The color wheel was indeed shattered and I had to vacuum the broken glass out. I put the new color wheel in and pushed everything back in. Crossed my fingers and turned it on the lamp light blinks a few times, it makes a little noise im sure everyone is familiar with then the standby/temp light flashes and then repeats it self 2 more times before all three timer/Lamp/stanby lights blink together. The customer gave me a replacement lamp so I tried that too but same thing, Any suggestions?
  • kahrnage Feb 11, 2008
    I flipped the orange cable around but no change, I'm pretty sure I had it in there right the first place though. I'm not sure what a ballast is or how to measure it, not sure still what to do from here.
  • Anonymous Jun 17, 2008
    oooll
  • 113 Answers
Make sure that you have the orange flat cable turned the right way when you plugged it in. I accidentally turned one the wrong way and that was the response I got. Hope this is all it was if this does not fix it I would measure the ballast and make sure the 200 or so volts is coming across.
Posted on Feb 07, 2008
Samsung DLP R&R Color wheel Model #HLR5078w
Samsung's digital light projection (DLP) televisions use a spinning color wheel to create the colors that are seen on the screen. If the color wheel becomes misaligned during use, it will become damaged and have to be replaced. Replacing the color wheel on a Samsung DLP television can be done at home, once a compatible-sized color wheel has been bought from a TV supply store.Replacing the color wheel yourself will void any Samsung warranty that might be in place, but is the only solution for getting the TV working again in as short a time as possible.
Put on the anti-static grounding strap to keep static electricity from damaging the internal components of the Samsung DLP TV. Turn the Samsung around so that the back is facing you. Make sure the Samsung is unplugged from the AC socket.
Use the Phillips screwdriver to remove all of the screws from the back panel. Put the screws aside. Pull off the back panel.
Loosen the two screws from each side of the projection bulb's case. Pull the projection bulb out. Put the projection bulb aside. Use the Phillips screwdriver to remove the two screws from the left side panel. Pull the side panel and the circuit board attached to it out carefully and put it down so that the cables attached to it have not been pulled out.
Take a picture of the power cable's position with the digital camera so that you can put it back correctly later. Pull the power cable out from inside of the Samsung's case so that the center panel is free to be pulled out. Remove the two large headed screws from the center panel with the Phillips screwdriver. Remove the top two screws holding the panel to the plastic case using the Phillips screwdriver.
5
Slowly slide the center unit out a few inches. Take a picture of the projector lens' positioning with the digital camera so that you can put it back correctly later. Unplug the two cables from the left side of the center panel. Unscrew the sensor switch using the Phillips screwdriver. Slide the center panel completely out of the Samsung and put it down on the clean cloth. Blow off the color wheel assembly with the compressed air.
6
Use the tweezers to remove the green plug from the top of the color wheel cover. Use the tweezers to remove the two cables at the side that are coming from the color wheel. Use the Phillips jeweler's screwdriver to remove the screws from the top, front and back of the color wheel cover. Slide the color wheel cover straight up to expose the color wheel.
7
Use the Phillips screwdriver to remove the three screws holding the color wheel to the color wheel assembly. Lift the color wheel up and out of the color wheel assembly and discard it.
8
Position the replacement color wheel in the color wheel assembly. Reassemble the color wheel and reassemble the color wheel assembly. Put the color wheel assembly back into position in the rear of the Samsung DLP TV. Reassemble the Samsung DLP TV. Plug the Samsung DLP TV back in for power. Turn the Samsung on and enjoy seeing the colors displayed properly again now that you have replaced the color wheel.
May 02, 2010 | Samsung HLR5064W DLP Projection TV
My Samsung 56 DLP picture lost is color and is making a buzzing noise which I suspect is the color wheel. The picture is now black
you need to change the color wheel
5
6
7
8
Feb 07, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
I have a samsung dlp that makes a horrible buzzing sound and it turns off, all the lights blink and the color flashes in and out.
The problem is likely the color wheel paste the link attached for more info
Samsung Color Wheel
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Sep 28, 2009 | Samsung DLP HL-P5663W 56" TV
Color wheel for Samsung HLR5688WX DLP TV
5
6
7
8
Jun 30, 2009 | Samsung HLR5688W 56" Rear Projection HDTV
Humming noise
Its the color wheel These Samsung are known MIne was doing same thing ,,i had a extended warantee took care of it,, but i hear you can get it fixed like 125.00 heres a web site if u brave enough try on your own http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Mar 07, 2009 | Samsung HCN5527W 55" Rear Projection...
My 61" Samsung DLP has loud Buzzing sound - Everything else ok
There are only 2 moving parts on a dlp tv the color wheel and the fan. The color wheel needs to be replaced about every 4 to 5 years. Some start to make noise and others like mine blow up with a bang. Go to utube to get instructions on how to replace it only cost me for part $100 good luck
Dec 14, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung dlp replaced color wheel
Need to get in the service menu.
That is not for customer for only autherized samsung service man konws about that.
Please contact samsung service center with phone.
Aug 16, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP R-4664_W
stll have picture?....is colors distored.. sound like a color wheel problem.. the colorwheel is a motor anything that moves eventally wears out.
Nov 17, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HLR5667W 56" Rear Projection HDTV Logo
125 people viewed this question
Jerry Greenberg
Jerry Greenberg
