Question about Krups Orchestro Dialog FNF2 Espresso Machine
Krups Orchestro Dialog coffee machine
The screen says Fill coffee beans which I have and still does not work - it makes the grinding sound but no coffee comes out - hope you can help
  • 1 more comment
  • Juff Feb 08, 2008
    Thanks - it worked - well done
  • gloppi Apr 03, 2008
    i have the same problem. I have tried to clean the grind using a brush, but nothing changed. What kind of brush should i use ? Might there be another cause for this problem ? Thank you a lot :-)
  • Anonymous Mar 17, 2014
    coffee beans don't grind
  • 2,039 Answers
That mean no coffee go through us if you dont use the machine often you might have coffee residue on the grinder teet remove the coffee bean in the hole were the coffee bean goes use a brush and clean the grinder teet very good with the residue of coffee gonna grind and gonna go through thanks for usig fixya pierre
Posted on Feb 08, 2008
Krups Orchestro FNF243 - there are plenty of coffee beans in the machine but it started to produce very weak coffee more dirty water than coffee. How can I fix it?
I had the same problem with a 8250. I had to throw it out as the grinder stopped accepting oily beans. I suggest that you take all the beans out and take a "keyboard cleaner air can" and spray the heck out of the area where the beans get ground up. It'll spray grounds all over so do it outside!
Oct 04, 2017 | Krups Coffee Makers & Espresso Machines
The hot water and steam commes inside the machine KRUPS FNF1
The mashine dont pull water from the water container and it ask us to press hot water , but nothing happend when we press , anyone knows how to sole this question ?
Allan
Dec 30, 2009 | Krups Orchestro Dialog FNF2 Espresso...
No coffee is coming out of the machine...
in our machine we wanted a stronger coffee so we adjusted the auto grinder (where the coffee beans are housed) to the finest setting thinking the finer the grind the stronger the coffee...after doing this the machine wouldnot make coffee...we sent it away while still under warranty and the tech said that the grind selection was too low so they just turned the grinder back up a notch and it worked fine ....dont know if this will help but it's worth a try!
Mar 26, 2009 | Krups Orchestro Dialog FNF2 Espresso...
My Krups iron only heats up slightly. HOw do I repair?
Your question is listed under espresso machines. Are you talking about a Krups Espresso Machine? Please clareify. Does it make Coffee and Steam?
Aug 02, 2008 | Krups Orchestro Dialog FNF2 Espresso...
I have a Krups Orchestro Model 889 which hasn't been used in a while. Now when I use it, the grinder works and the steamer works but nothing pours into the cup when I activate the machine. I think its an...
I had the same problem with my Krups Orchestro and today picked it up from service. There was nothing wrong except the internal filter was blocked and a manual clean by the technician fixed it. I think I exacerbated the problem by going to the finest grind over time the amount of liquid to the cup got less and less till it stopped.
Now I am using a courser grind - hopefully this will delay the onset of the problem. I was going to try a clean myself - but was deterred by the security oval head screws on the back. The repair centre told me they thought the Krups machine was a great product - and that I should expect many more years. It is essential though to perform maintenance (clean especially) as soon as prompted.
Jul 10, 2008 | Krups Orchestro 889 Espresso Machine
My krups coffee machine comes up with service 8, what does this mean
The Brew Unit needs to be repaired or replaced. We repair Krups
Go to www.hotncold.com Click on Jura Repair. Krups and Jura are made by the same company.
May 26, 2008 | Krups Orchestro Dialog FNF2 Espresso...
I have a Krup Orchestro Dialog Autocapuccino fully automatic espresso machine. When I try to use the machine, it warms up properly, rinces correctly, grinds the coffee, makes the usual noises, few drops...
Initially, have you tried a full hard reset? If not, pls unplug from the mains. Most current devices would reset and revert back to factory default settings (assuming no internal hardware fault) when unplugged for a considerable period of time (from a few minutes to a couple of hours). Of course doing a hard reset erases all glitches.
Pls post back for any development(s) or even the lack of it.
Hope this be of initial help/idea. Good luck and kind regards.
Thank you for using FixYa.
May 21, 2008 | Krups Orchestro Dialog FNF2 Espresso...
What does Service 8 mean?
The grinder needs to be either replaced or at least repaired.
Dec 09, 2007 | Krups Orchestro Dialog FNF2 Espresso...
Krups Orchestro Dialog FNF2 Espresso Machine Logo
342 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
