Question about Astar LTV-3001 TV
ASTAR LTV-3001 TV HAS AUDIO BUT NO PICTURE
  • 2,336 Answers
I found some info here:
http://www.fixya.com/support/t281034-astar_ltv_3001_30_inch
If you have some electronics knowledge you can fix this problem yourself.
Good Luck.
Posted on Feb 07, 2008
    Brigadier General:
  • 6,966 Answers
It is possible that there is video/picture, only that you can't see them because it is dark.
Your Astar LTV-3001 is an LCD TV and makes use of backlights. They are CCF Lamps powered by an inverter. Normally there would be several CCF Lamps and very rarely do all go out at the same time. What then could possibly have happened is that the inverter powering these lamps is defective since it is common to all.
A way to check is to run the TV AS IF everything is alright (albeit nothing you can see). With the use of a flashlight, shine the light obliquely to the screen. Press your remote's volume control up or down and try to see if there would be a semblance of the sound level indicator. If you can see something no matter how dim or dark, then you have just confirmed that it is the CCF Lamp inverter that is at fault.
If you have confirmed that there is really nothing even with the use of the flashlight, then it has something to do with the LCD panel or the video interface internal to the TV.
Unfortunately, either fault would require that you be familiar with electronic components and circuitry, the use of a DVM and a soldering iron. Should you not be comfortable going this route, you may need to seek the services of a qualified professional or an authorized service center.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
  • Louie  Role
    Louie Role Feb 07, 2008
    Hi again,
    Another thing that might be worth trying is to do a full/hard reset, that is unplug the TV from the mains for a couple of hours.
    Cheers.
No sound when tv switched to dvi Astar model LTV 3001
There is no audio in DVI connector, you need to run separet cable for audio signal.
Dec 30, 2009 | Astar LTV-3001 Television
Power supply burned
These power supplies are not longer being manufactured and very hard to find. The defective power supply can be repair.
If you need further assistance, write to jah2mil@hotmail.com
May 28, 2009 | Astar LTV-3001 TV
Astar ltv-3001 powers up with sound no picture
If your TV has more then 1500 to 2000 of use, chances are that the power supply is starting to fail if you have to unplug the TV to be able to turn it ON. There are about 23 capacitors that might need to be replace to fix it.
I repair them, let me know if you need further assistance.
Feb 08, 2009 | Astar LTV-3201 32 in. LCD Television
I have a Astar LTV-3001 and can't turn on. and I have other LTV-30MA This one have sound , no picture, can you please guive me sam help, I use to repair, Tvs. a time a go
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Jan 03, 2009 | Astar LTV-3001 TV
Astar LTV-3001 just shut off and I can smell something. Any ideas?
The power supply most likely failed on your LCD.
How old is your LCD?
If it is under a year old, can be fix under manufacturers warranty. If not, you can write to jah2mil@hotmail.com
Aug 01, 2008 | Astar LTV-3001 TV
Astar ltv 2601
Try call my friend Ivan at 323-767-6030 he know where to get the original Astar parts.
Apr 10, 2008 | Astar LTV-3001 TV
NO PICTURE OR SOUND.
Have you guy check the power supply for your TV?
Call me 323-767-6030 and I will go through with you.
Feb 06, 2008 | Astar LTV-3001 Television
Astar Plasma
try to contact my friend Ivan 323-767-6030. He had working for the astar company as electronic tech maybe he can help you and answer all the problem of your astar tv.
Thank you.
Jan 25, 2008 | Astar LTV-2701 27 in. HD-Ready LCD...
Astar Plasma
I had the same problem... Astar 30" LTV 3001 ....These TV's have a cooling problem that causes premature electrolytic capacitor failure. De-solder and Test all the 2200uF-25v, 3300uF-35v and 1000uF-10v caps in the power supply (center board, back of TV). Use a good LCR meter that will read 3300uF or better, Replace all bad caps with 105c rated caps. If you don't have an LCR meter, replace all the mentioned caps on the PS. If fuse on board is blown, also replace the F9222L regulator IC chip. Mounting a small cooling fan on rear of TV over the PS will help keep your new caps from failing again. This requires holes in the stand bracket and the rear of the TV, power can be supplied from a 14V source near the bottom of the PS board.
Jan 13, 2008 | Astar LTV-3001 TV
Astar LTV-3001 TV Logo
100 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
