Question about HP Pavilion dv6000z Notebook
Power button doesn't respond
At first The button just need to be pressed a little harder for some reason,but now the power button just doesn't respond at all until about 5-10 minutes of pressing, with the back of a writing pen. What could be the source of this annoying problem?
  • Andrew Thompson
    Andrew Thompson Feb 07, 2008
    so you're saying its the actually battery that needs replacing ?
  • Andrew Thompson
    Andrew Thompson Feb 13, 2008
    nope i tired it with a different battery
    Problem Solver:
  • 12 Answers
Is not the power swich, it could be lithium batt.
you need to replace.
and you say that about 5-10 minutes of pressing, with the back of a writing pen it work.
is cause the lit batt is charge all ready. But not enough.
Posted on Feb 07, 2008
Laptop is a sleep
press any key to wake it up, if that doesn't work for some reason press the power button once. it should wake up. if all else fails hold the power button down for 5 seconds until it shuts off and reboot it.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
May 05, 2012 | IBM ThinkPad T30 2366 Notebook
Power but not printing
Hi Linda,
Did you check if the printer is able to scan or does it makes photocopy? if the printer doesn't respond to any input follow below steps.
  • Power Drain:
  1. Turn the printer OFF using the power button.
  2. Disconnect the power and USB cable from the back side of the printer.
  3. Press and hold the Power button for 30 seconds and release the button.
  4. Connect the power cable and try printing.
  5. If the above steps didn't work try below.
  • Partial Reset: Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the button. If you still see the issue try next level of reset.
  • Semi Full Reset:- Remove the ink cartridges; Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the button.
Feb 07, 2012 | HP PSC Photosmart 2355 All-in-One Printer
My Technika LCD32-229 is just over 12 months old and has suddenly decided not to respond to the remote or on/off control on the TV. If I turn of the power at the mains for 30 seconds or so, it will then...
HERE'S THE ANSWER TO YOUR PROBLEM:
The possible reason why your TV doesn't respond to your remote is probably the battery of your remote. Maybe it has been used up to it's fullest capacity, so try checking it up. In case, it has been used up, try to buy a new one.
The possible reason why your TV doesn't stay on is still your remote control. Maybe you have accidentally set it to "sleep mode." When it is set into sleep mode, it turns on just for a shorter time. It cannot stay on longer.
So, here's what you've got to do. Check your remote. When the remote works already, press the sleep button remote again. I hope it works for you.
Thanks.
Jul 23, 2011 | Televison & Video
Remote doesn't work even with new batteries
make sure the remote batteries are in the correct + and - way. It could also be that the remote is broken. If nothing comes on when you press the power button and the tv doesn't respond, then the remote is broken and you should buy another one.
May 28, 2011 | GPX Televison & Video
My Sony vaio pcg 3c2l has locked up. The keyboard stopped responding and now the screen is black, but the power light is still on. The power button doesn't respond when I push it. What should I do?
Try pressing the power button for several seconds (10-15). It should power off the laptop.
If not, unplug the charger and remove the battery for a few minutes. Then try to start it up again.
May 05, 2011 | Sony Computers & Internet
Hi, I have a Canon i9950 that is marking all it's prints with black littles lines every 1cm down the left side of the page. Does it need service?
Hello you can try this may do it
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Oct 12, 2009 | Canon i9950 InkJet Printer
Power pack is orange and system won't turn on?
try to unplug the power from the back of the console and let it sit for 5 minutes. somtimes i had this happen and press the button a lil harder and it woked. also try to remove the faceplate and use a little screwdriver or something to press the button in there. you're faceplates button might be broken(replace faceplate)
Feb 21, 2009 | Microsoft Xbox 360 Console
No boot of laptop
Dnot press gently try a little harder if still problem persist contact ur nearest service station.........................Sameerayan
Jan 13, 2009 | Compaq Presario Notebook
HP Pavilion dv6000z Notebook Logo
127 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
