Question about Sony STR-DE545 Receiver
The Output Volume Is Extremely Low!
The receiver used to be extremely loud at like half way or less and now its extremely quiet out of nowhere.  I can turn it up all the way and still not as loud as it used to be.  It gets louder but still very quiet.  What could be the problem?
Thanks!
  • 2 more comments
  • juicestain Feb 07, 2008
    I am using JBL HLS610 speakers and they are the same speakers i have been using.  How do you know if you speakers are hooked up in 2nd Zone?  I dont see a 2nd Zone.  Also how do you change the volume in the menu screen?  Thanks!
  • juicestain Feb 17, 2008
    Ok!  I have tried the things you have said.  I greatly appreciate you helping me but the problem still there.  I did some more research and could the problem be the Output Transformer?  Please let me know and also im not a tech at all but i do have equipment to test it.  How would i test to see if it is the output transformer?  Let me know.
    Thanks Again!!
  • rally2 Mar 22, 2009
    I have the same problem. I found that if I use A.F.D. mode with a digital input everything works great. If I try and use any of the surround modes only the center has any volume. On 2CH I have to max it out to hear anything.
  • Jay Henderson
    Jay Henderson May 11, 2010
    What kind of speakers are hooked up? Also are they the same ones u were using? Also make sure you don't have speakers hooked to 2nd Zone and the volume is turned down there in the menu... Let me know. Cheers... GURU JAY
    Sergeant:
  • 261 Answers
Sometimes the rear channels can be used as a 2nd zone. Does the unit have A&B speaker selection on front panel? Usually if it has a 2nd zone it will say in owerns manual or on back of unit or on front panel as well. That is when you have the option to adjust the volume in the menu on the 2nd zone. GURU JAY
Posted on Feb 07, 2008
  • Jay Henderson
    Jay Henderson Feb 18, 2008
    I doubt that all channels would be at a lowered level if one or two of the transistors were bad. Usually if a transistor is bad, it would be shorted to ground and give u a protect indication on the front panel. Usually,but not always!! Also the easiest check to do is to make sure you don't have the "TAPE 2 MONITOR" button activated or on. This would cause what you describe as well. If that isn't it try using DVM...(Digital Volt Meter) and check output transistors using the diode test and see if any of the outputs are shorted or bad. Simply check between ground (Black) and (Red) of the speaker output terminals located on the back. IF ANY OF THEM READ SHORTED ON DIODE TEST THAN you most likely have a bad transistor inside unit. Let me know how these test pan out and then we can proceed from there...Good luck on your tests and don't hesitate to ask as many questions as you need to to resolve your issue.. Also don't forget to give feed back as this is how i keep my ratings up and my ranking position. Cheers and good luck....GURU JAY
Why is answering machine volume too low?
Panasonic Cordless Phone - quiet volume - Phones - Gadgets - Whirlpool
forums.whirlpool.net.au > Gadgets > Phones
WhirlpoolJan 4, 2011 - We've just got a Panasonic KX-TG4393 Cordless phone ...objectID=4555), but the volume is extremely low and it's very. ... have a problem hearing messages on the answering machine. ... Looking for any suggestions too.
Panasonic Dect 6.0 4-Handset Cordless Phone with ...
www.amazon.com/Panasonic...Answering.../B001RTU...
Amazon.com, Inc.Panasonic Dect 6.0 4-Handset Cordless Phone with Answering Machine .... I do not mind the low ring volume because too loud rings bother me but I am listing ...
Panasonic KX-TG6445T DECT 6.0 Cordless Phone with ...
www.amazon.com/Panasonic...Answering.../B001P80...
Amazon.com, I
Jan 07, 2016 | Panasonic Lands Phones
My laptop is incredibly loud. I have the volume at 1 of 100 and it's still extremely loud. Is there a way to lower the volume?
use the fn key and look for the key with the volume labels..if i new the type of laptop you have id tell you what keys
Jun 13, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
I have surrond sound speakers thats loud but wend
I had an issue like that with one of my dell desktops too. The speakers were very quiet. I turned up the volume on the speakers, turned up the volume in windows. Unisntalled and Reinstalled audio drivers, I eventually assumed that the speakers were just junk. After buying a soundcard (I was originally using onboard sound), I discovered that the speakers were much louder through the soundcard than through the onboard audio.
Feb 28, 2011 | Dell Computers & Internet
My xm plays extremely loud thru my car stereo.no matter what i set the volume at.it is either off when volume is set to zero or loud at any other setting.changing the output level on the xm receiver does...
Are you playing it directly thru your FM antenna connection, or using the RCA jacks? You have to set the FM modulator level. It is also possible that you have a new FM radio with a type of ALC that will raise the lever regardless, but your regular car radio volume control should work. do not wire this directly to a power amp, as you won't have the control that you need. Good luck, let me know more.
Apr 01, 2010 | Terk XM Commander Satellite Radio Receiver
Low volume from my thorens td-145 record player
Have you checked the cartridge in the turntable arm?Also check to make sure receiver/tuner is switched to Phono or Aux..Also check to see if there is a speaker switch on receiver.
Mar 07, 2010 | Thorens TD-170 Turntable
Listeners say when I'm speaking to them on phone, it's too LOUD
If it is just the one phone you are calling, the problem might be with their volume contol...ask them to check the volume on their phone.
Jun 03, 2009 | Comdial Impact 8024S-PT Corded Phone
75-822 cb that has extremely low audio output
Hello..if you can try to connect a external speaker or phones..if the volume is ok..than i think it is time to replace your internal speaker..pse tll me....good luck...Ron
Mar 14, 2008 | Midland 75-822 40-Channels Handheld CB...
Volume loud and quiet when tv is first turned on
your set must have cold solder joints,this means once set gets hot enough that connections are then made correctly,this will not stop untill you have someone solder all cold solder points.
Jan 25, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Default volume too high
You can download the manual from the link below: http://www.intl.onkyo.com/downloads/manuals/pdf/tx-ds787_manual_e.pdf c. Power On Volume This sets a designated volume setting for the TX-DS787 to be set every time that the power is turned on. This prevents the TXDS787 from being turned on while it is set to an extremely high volume and suddenly output very loud sounds. For the absolute volume display method, this can be set between min and max. For the relative volume display method, this can be set between ?? and 18 decibels. If you do not mind having the TX-DS787 turned on with its current volume setting, set this to "Last." Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 03, 2007 | Onkyo TX-DS787 Receiver
Sony STR-DE545 Receiver Logo
306 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
