Hello there:
The water doesn't drain from the machine
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap
Pump
Drain valve and/or solenoid
Belt
Motor
Timer
Drain line/air gap
Aclog in the drain line or air gap (if there is one) is the usual reasonthat a dishwasher won't drain. Often the problem is at the point wherethe drain line attaches to the garbage disposer or household drainline. If you remove this line, you can clear any debris from the hoseor hose connection. Be sure to reattach the hose before starting thedishwasher again.
Pump
Yourdishwasher pump ejects the water. The pump is usually mounted directlyto the motor, then attached to the bottom of the dishwasher. You canreach the pump from inside the dishwasher, but first you need to removethe lower rack, the spray arm, and the spray arm support.
Lookfor an impeller--a round plastic fan blade-type of device that spinsaround. This is the wash impeller, which forces the water through thespray arm. Beneath the wash impeller is the drain impeller, which issimilar in size and shape to the wash impeller. The drain impellerpushes the water toward the drain port. These components make up thepump. If any of the pump components are defective, you need to replacethem.
Manydishwashers use a drain valve with an electric solenoid. Whenelectricity flows to the solenoid, the valve opens and diverts thewater to the drain. Sometimes the solenoid, or the diverting lever,sticks and prevents the dishwasher from draining or filling properly.Try to free up the solenoid to lubricate the lever. Otherwise, you mayhave to replace the solenoid or pump assembly. With these systems, themotor always rotates in one direction. When it's energized, the drainvalve diverts the water.
Partof what the timer does is control the motor and drain valve. If thetimer doesn't work properly, the water may not drain and you need toreplace the timer. This problem is uncommon.
