Question about Toshiba e-Studio162 Copier
Problem with canon irc3200
Error code E000001-0004
  • joshipravin1 Feb 07, 2008
    please give me a solution for
    on my canon machine irc3200
  • Ric Seyler Jul 24, 2008
    I have the same code. E000001-0004
    Is it kosher for someone to tell or show me where
    the thermisters are located and any special procedures
    for replacing?
  • 287 Answers
Hello Josh. I can tell you "bulletproof verbatum" from the service manual what this error code means.But for me to merely try to help you{as I am} , I will be penalized by this website "FIXYA" since unless you are a trained Canon technician the info I provide will not truly "fixya".But I would rather lose my rating than let you potentially be screwed by a the local copier dude.Just please give me a decent rating/vote when you get a chance to comment on thr quality of my help for you. This code has to do with the fusing unit, a common component on all copiers. The fusing unit is responsible for providing extreme heat and pressure to to the paper and potential image as it reaches the exit of the copier. The heat and pressure "bond" the toner to the paper. The temperature can approach 380* F and therefore must be controlled in redundant ways to insure safety. Your machine has among the redundant systems two "active" temperature sensing devices called thermistors.They each monitor the temperature of the "fusing "unit, and are located in different areas to better monitor the temp. They also compare each other's temp to once again insure safety. Your code means that the "non contact" thermistor and the end {contact} thermistor had a difference of temperature readings of 80*c for more than 500 milliseconds.This is abnormal and not possible if all is well. One or both are bad. The code can be reset, but if the problem is genuine and not a fluke then it will return. To reset the code. Press "additional functions" then the 2&8 simaltaneaously, the additional functions again. New screen. Press "function'. Press clear.....ERR. THen ok at the bottom. Power off an dhope for the best.Good luck.
Posted on Feb 07, 2008
  • 3 Answers
Do you get this fault after a jam in the fuser?if so you may have a dirty senser behind the veritical path assembly or miss adjusted.as you open the fuser assembly ther are to switches on 1 senser.first is door open second is shut down fuser.if this is dirty or miss set the fuser will shut down first.if this dont work try anew fuser[ebay canon will have your eyes out]2 screew to change
Posted on Apr 14, 2009
  • 818 Answers
E002 Fuser thermistor, thermal fuse or triac
Posted on Jan 13, 2009
What is causing on my canon irc3200 error code E000020-0481
this code is for a bad OHP sensor, wich detects transprerencies.if you need canon support call now canon expert technician
Canon Printer Support
May 06, 2014 | Canon Office Equipment & Supplies
Canon ir c3200 error code e0100-110
get manual here
http://www.scribd.com/doc/61327440/Canon-Irc3200-Service-Manual
Mar 23, 2014 | Canon iR C3200-C1 PS Ver1.0
How do one enter to Service Mode level 3 of Canon irc3200
That level 3 mode is only for Canon engineers. What counter are you looking to reset? The counters for most maintenance items are reset in service mode level 1. The total counter for the machine cannot be reset without replacing the main controller pcb & the counter pcb.
Jul 25, 2012 | Office Equipment & Supplies
Canon ir c3200error codes
There are many error codes which the iRC3200 has, please be more specific.
i.e. copy the exact error code displayed.
Sep 23, 2010 | Canon imageRUNNER C3200 Copier
Error E000020-03a2 canon c6800
pls check the cyan deverloper if it irc6800.drum unit if it is irc3200
Mar 04, 2010 | Canon imageRUNNER C3200 Copier
Irc3200 will not boot up
A E0000-001 is a fuser error code.... You may be able to reset it. Press the "Additional Funcation" botton, then the numbers "2" & "8" at the same time, then press the "Additional Funt." botton. The display will change. To reset the code press Funcation, then CLR. then ERR , then press the "OK" on the display. Then turn the Main power "OFF" then back "ON". If this code shows up alot, you may have a power problem, if the code reset. If it will not clear you have a problem with the fixing unit. Good Luck...
May 26, 2009 | Canon imageRUNNER C3200 Copier
Canon imagerunner c3220
Were the heaters at fault. It is more like a thermister problem. Replace the thermisters, both. And I would also change the thermostat as well. When you are sure thatyou have removed the faulty unit reset by doing the following.. service mode/copier/function/clear/error followed byswitching the machine off and turn on again.
Oct 31, 2008 | Canon imageRUNNER C3220 Color Copier
Canon irc 3200 error code E000001-004
Want to print a Microsoft Office Publisher document to Canon iR C3200 and it gives'
me this message: Cannot continue to print as the disk is full. I have plenty of room on
my drive and so does the copier. Please advise
Oct 08, 2008 | Office Equipment & Supplies
Error code Canon IRC3200
change the black drum reached end of its life
Canon Tech
Jul 22, 2008 | Canon imageRUNNER C3200 Copier
Toshiba e-Studio162 Copier Logo
417 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
