Question about Motorola Mobility RAZR V3i Cellular Phone
Charging problem!!! PLEASE READ!
My friend had gotten a new phone, therefore he didn't need his old razor so he gave it to me. When he had it, it worked great! Unfortunately it did not come with a SIM card so I had to go out and buy one. I put the SIM card into the phone and I could access all of the phones features for a day or two... Eventually the battery died, and I realized he had not given me the charger, so I went out and bought a charger for this specific phone. I plugged it into the phone, and the only thing that happened was the backlight flashed blue, and the screen flashed white every 10-15 seconds. I unplugged the phone from the charger the next day and pressed the power button and the backlight flashed blue at a very fast speed, then slowed down and dimmed, then eventually stopped flashing and turned off. I tried charging it from the computer through the Motorola phone tools program, but my phone never connects because it always turns off before the program can detect the phone. Sometimes If I hold down the power button until the Motorola screen pops up it will say "Charging", then turn off immediately and go through the whole flashing white and blue cycle again... DO I NEED A NEW BATTERY OR A NEW CHARGER? The phone worked perfectly fine before the battery died so I don't think its the phone.
ANY INFORMATION WOULD BE EXTREMELY HELPFUL! THANKS!
  • 6 more comments
  • Exibis Feb 07, 2008
    I bought a Motorola charger, it says:
    INPUT: 100-240V ~ 50/60Hz 0.2A
    OUTPUT: 5.0V - - - 550mA
  • nslater7897 Feb 09, 2008
    I have a similar problem with by Motorola V3 cell...the battery that won't quit charging.
    When I take the battery out, like suggested here, I get msg: 'unable to charge'. My charger says CH-MOTO V3/L7.
    Also, sometimes(3x) out of 20 attempts to power it up, cell turns off by itself while its doing: 'searching for network'. Other times, it just turns off before then.
  • Anonymous May 09, 2008
    charging problem
  • Anonymous Jul 30, 2008
    Same problem but the phone heats up, I bought a new battery and carged it (or so I thought and it has just gone the same way.
  • Anonymous Oct 09, 2008
    same problem as yours,even the adapter is dead:
    motorola is the worst,within one year my screen was gone and now this problem has arrived.
    WHAT THE HECK
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Ok, that is the right voltage. Can you take the battery out and try to run the phone right off the charger and see it the phone work then?
    - Jim
  • SHARCNET-USA
    Have you tried removing the battery and running the phone right off of the charger adapter? Does it work then? I would think a dead battery would just make the phone go dark (dead).
    I have a RAZR and that's what happens when my battery dies, although you'll get a battery low indicator and an audible warning that the battery is going before it completely goes.
    What was the brand of charger that your purchased? Was it RAZR compatible? What's the output voltage of it?
    - Jim
  • james a cloud May 03, 2013
    does not help it had charged before whith the same charger in use nom
What if the motorola razor charger voltage is a bit too high? Does the phone reject the voltage or charge anyway?
Posted on Mar 05, 2008
  • 983 Answers
As i think that charger was not compatible to your phone so when you tried charging it the battery is dead bcoz of excess voltage than it normally bears with the compatible charger of ur phone ...
so this excess voltage has made the battery to be short circuited due to this may be the charging ic or the capacitor is gone ...
so i suggest you to take the cell to the near by technician and just have a check...
the only problem with all motorola phones is that it only charges with the charger with the desired voltage ... if the voltage of the charger is low then it will not show any response(i mean it will not charge but it will not cause any thing to battery as it is of less voltage than the desired voltage )
so i think the charger you buyed provides more than the desired voltage so the battery is dead .....
Posted on Feb 09, 2008
SIM card in Motorola V3C
thats right,older terlus razor phones are cdma,not gsm,therefore .no sim card.so you will have to switch to telus,or get another phone
Nov 24, 2012 | Motorola Mobility RAZR V3
Low battery backup
Have a read of the trouble shooting guide here,
http://www.razorama.com/razor-installation-guides.html
It sounds like a fault with the charger. Test the charger output with a voltmeter to confirm correct operation. IF OK then check the wiring , fuse, switch conections between the charger and the battery.
wiring diagram is here http://manuals.monsterscooterparts.com/recreational/Razor/Wiring/
Jun 08, 2012 | Razor MX350 DIRT ROCKET - BLUE
Razor Phone wouldn't charge...battery dead, so I replace with new battery. It still will not indicate that battery is charging. I tried several outlets to plug in charger. Still no charging. Phone...
Sounds like you may have a connection problem where the charging cable plugs into the phone. Not much can be done except to get a new phone. Those micro USB/USB style connections last a long time, but once a pin is bent up it is game over. Sorry!
Mar 03, 2011 | Motorola Mobility RAZR V3
How to transfer Motorola Razor V default ringtones
you can transfer it from your computer with the ring tones saved on the system,or via mms message sending ring tone form razor to your lg phone aso you can use blue tooyh to transfer ring tones
Dec 18, 2009 | Motorola Mobility RAZR V3
I have a verizon razor but the ear speker went out
This is a common issue with the Moto Razor and can only be fixed by replacing a part. This phone uses different speakers for speaker phone and talk modes.....If you have an old razor laying around that is the same model, you can use its speaker if you believe or can prove it works......otherwise you can buy one for a few bucks. Here is a randomly selected site that sells these parts.
1. Remove the 4 plugs over the screws on the flip top and the screws themselves. 2. pop the top apart and up at the top you sill see where the speaker just sits in there. 3. Replace it the way you saw it in there 4.put it back together Now you can hear your friends without speaker phone!!!
Good Luck!!!! ANd pls rate this post
Oct 13, 2009 | AT&T LG CU720 Cell Phone - Silver
Invalid battery
Even though the batteries look the same and will fit does not mean they are compatible. I just saw this again at my cell shop today. My razor uses a BR 50. This guys razor needed a BK-70. A BR-50 my partner put in fit, but gave the same message. Your eyes do not deceive you. Make sure the battery model is the same and you are in business. Motorolla batteries have nice big model numbers. I don't have to put my specs on to read it! Happy charging :)
Aug 06, 2009 | Motorola Mobility RAZR V3
SIM Card Location
If its a service like Verizon, Cricket, they are what called CDMA phones, these does not come with SIM cards and therefor does not accept sim cards, there will be a slot, for it but it will locked. so better find another phone
Dec 23, 2008 | Verizon Communications Samsung SCH-u410...
Charging?
Your battery may have a low voltage, you need to rejuvenat is unfortunatly you cant do that if you dont have tools to do it, but that will be your problem (Battery)
Jan 10, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3i Cellular Phone Logo
738 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
