Question about Dryers
Whirlpool duet sport gas dryer
Two months old and stopped drying. I took the panel off the front and could feel air blowing around in there. Went outside and there was a strong stream of air coming out (the 38 foot long vent pipe with three 90 degree elbows plus the flexible pipe between the dryer and the wall!) and comfirmed it wasn't clogged. Then I took the vent pipe off the back of the dryer and the air blowing around inside the bottom of the dryer stopped. It definately had more air pressure at that point than at the end of all that pipe. Also there seemed to be too much lent built up down there for a two month old dryer so I'm guessing the length of the pipe is creating too much back pressure so it is leaking out inside the bottom of the dryer. What am I supposed to do if my laundry room is in the middle of my house and there is no other way to vent it? I am using rigid pipe but it already has a quarter inch of lint built up on the inside of the pipe. Is this just a mistake of the remodeler of the house and laundry rooms are supposed to be located on an outside wall?
For the last ten years I had just let the old dryer vent into the four foot tall crawl space under the house but I was trying to set it up correctly when I got a new dryer. Could the back pressure or lint build up be the reason the gas stopped coming on? I realize this dryer is under warranty but I want to make sure it is installed correctly before calling for a repair person.
  • eevielehr Jul 27, 2008
    I have an new gas dryer which my husband installed in our attic. The gas comes on (I can hear the pilot light ) but then shuts off. Why is this happening?
Cerfer39
  • 709 Answers
SOURCE: Question about Whirlpool Dryer venting
http://groups.msn.com/Appliantology/dryers.msnw?action=ShowPhoto&PhotoID=79
Posted on Nov 07, 2007
  • 1314 Answers
SOURCE: Whirlpool Duet Dryer getting very hot, tripping breaker
what size is your breaker how many amps it should say on breaker are you cleaning the lint screen with it on top if the drier is getting too hot there is a device in it that's called a thermal limiter that would blow before the breaker would trip what kind or you in a house or apt. now on high heat can you hold your hand on the side of the drier.or cant touch it look at the vent under your house and tell me 1is it hanging down under the house then coming up to the hood 2whats its diameter3whats it made of we will go from there ok.there are three thermostats in that drier the first one runs at about 150 160 max second is a safety in case the first one fails it cycles at about 250 third is a safety if the drier exceeds 300 it will shut the heater down and wont rest it has to be replaced
Posted on Jan 10, 2008
SOURCE: Smell Gas.
you need to clean out you venting ...it is most likely clogged or filling up
Posted on Feb 16, 2008
  • 91 Answers
SOURCE: Duet Gas Dryer- burning smell
first is first ,,, disconnect dryer from plug,, now open bottom panel 2 screws ,, now go and get youre vaccum,shop vac, anything ,, reason for burning smell ,, usually catching on fire ,, we recommend do this 1 as year,,, after cleaning , put about 2-3 fabric sheets inside dryer and let it runn for about 30 minutes to remive smoke from drum,,, thank you
Posted on Jan 04, 2009
  • 8 Answers
SOURCE: Hi, My maytag bravos dryer is one year and 2
Sounds like the exhaust fan is not working. There's an electric blower at the back of the unit that forces air out through the exhaust vent. Unplug the unit, pull the vent off the back, and see if you can reach in and touch the fan blades and make them move. If it won't move something is probably caught in there. You may need to take off the back of the unit and remove the housing cover to the fan assembly in order to really tell what's going on, but it sounds like your fan has an obstruction. It could also be that the fan motor is fried but that seems less likely. Remember to have the unit unplugged, there's some dangerous voltage inside.
Posted on Jan 03, 2011
Testimonial: "Wow super fast response and easy to understand, thank you!"
Gas dryer heating element won't come on.
There is a controller problem to turn on the gas manifold to produce heat. Since you have it only one week old, let's take the advantage of the warranty to have a new controller unit replaced.
Jan 03, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Doesn't dry clothes. New Just installed 11/16. Took 2 hours to dry a load of towels. It is a gas dryer. WGW 9450
Check vent out is clear blowing air / check clean all filters, the fact thats its new should not be anything too serious..Good luck
Nov 17, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer keeps drying and getting too hot
Check the dryer vent .The vent is stopped up,in the vent,or in the inside of dryer,in the lint hopper.Clean it out and unstop the dryer,and the vent.
Oct 10, 2009 | Whirlpool LER5636P Electric Dryer
Trips breaker: Whirlpool Duet Sport front load dryer
could be a faulty stat or element,get an engineer to test the dyer, he will check insulation on the element, could try replacing the element that just might sort it
Sep 21, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Converting from natural gas to propane
you need to change your orfice or you will have a big problem with flame
Jun 01, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Maytag Gas Dryer MDG308DAWW doesn't blow hot air, no clicks heard
Look at the bottom of your front panel and see if you can see a screw on either side about 2-3 inches from the very bottom edge of the front panel. If so take them out and pull the bottom away far enough to disengage the top of the front panel from the top panel. If this works for ya. then now you have it openened, if not repost me.
Apr 13, 2009 | Whirlpool GGW9250PL Gas Dryer
Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
Dec 16, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Sport Gas Dryer - Works fine but makes loud noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
yriur
Nov 24, 2008 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Dryers Logo
134 people viewed this question
Top Dryers Experts
