No one seems to have an answer
Hi there. My problem is this; at the VERY TOP of the tv screen, there are white-broken horizonal flashing lines[ across the top of the picture ], not across the entire tv screen. Here's what I mean. It only does it in [full screen] HD format,with the black bars on the side. [never wide screen HD format]. MITSUBISHI says the problem in in my directv hd receiver. Wrong!! I replaced the hd receiver with a new one. --SAME DAMN PROBLEM!! So it is oviously the TV. Whats wrong with it. Thankyou,--- Tom K.
  • 49 Answers
Problem with the vertical linearity..some electronic component in vertical circuit gone bad..probably, a dried up electrolytic capacitor..usually 100uf/50v.u need a serviceman to fix that.thanks,hope this help u
Posted on Feb 07, 2008
  • 113 Answers
Sorry this was my solution I forgot to sign in hope this helps you : If the lines dip down enough this could be true what was said by MARR. Although in your case it seems as though you are talking about the white line you can barley see at the top when the tv is showing hd in 4:3 format. This is caused by the hd signal is underscanned and nothing inside the tv will fix this problem this is a signal issue. The way to get rid of this is with your tv remote you need to change the Aspect to "Just" this will not cut off any picture and will take care of that line. You are free to zoom etc...with your sat remote. Make sure you make the aspect change I talked about on the tv itself this should get you set up. See this all the time now...all models all diffrent type of signals all brands/
Monitor flashes different colors
Monitor has been successfully broken with fall.
Aug 31, 2017 | Samsung P2370HD 23 in. TV
I have a Samsung LN46A650 LCD TV and recently I started getting a white line across the top of the screen. Sometimes the white line is thicker on the left side of the screen. Sometimes after the white...
Yes, it's the t-con board, a well know problem in this tv. Here it is
http://www.partstore.com/Part/Samsung/Samsung/LN46A650/Samsung/Samsung/BN8101697A/New.aspx
Sep 13, 2011 | Samsung LN46A650 46 in. LCD HDTV
White flickering line across top of screen
Set the screen format using your TV's menu. Do not set the format of the screen using your provider's receiver. I had this prob with a few channels with a dish provider when I set the format with the remote from the dish provider. I picked up the TV's remote, went into the menu, set the format, problem fixed.
May 15, 2010 | Vizio GV42L 42 in. LCD Television
Picture vertical output has reduced
TV has no cathode 200 volts supply.
If you have experience of CRT TV repair then let me know to guide you further or get help of near by TV tech person.
Nov 30, 2008 | Sony FD Trinitron WEGA KV-24FV300 24" TV
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
No one has been able to give me an answer
Sounds like insufficient vertical sweep and the top lines are getting out of control.
Check all the electrolytic caps in the vertical circuit for testing dry (sorry - takes a special meter to do it in circuit) or just replace them. Look the I.C. up in the free NTE crossreference at nteinc.com get a diagram of its pinout to find what pins the power and outputs are on.
Hope ya fix it!
Aug 28, 2008 | Mitsubishi WD-62827 62" Television
Westinghouse 32" LCD TV
It seems your pixelsare burning out. contact the NY Service Center for Westinghouse. web is www.asnyonine.com
Jun 24, 2008 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Thin horizonal line in middle on dark screen
The several thin white lines at the top of the screen is the warning that the vertical output IC is not getting the boost voltage it needs to run correctly. The IC cannot operate for long like that and shorts out inside, which is when the vertical collapses altogether and you get the thin white line through the center of the screen. The good news for your son is that he had nothing to do with that, and it has nothing to do with the cable F connector. The set needs to be serviced by an experienced tech who will restore the boost supply and replace the vertical output IC, and when I do that I charge $75 but techs in your area will vary, so be sure to ask around.
Jul 26, 2007 | GE 24GP653 24" TV
Televison & Video Logo
153 people viewed this question
Top Televison & Video Experts
Electro Med Services...
