Question about Lexmark X6170 All-In-One InkJet Printer
Can not scan at all the system say it is ok but it does't do any thing
  • 1 more comment
  • osiris73 Apr 21, 2008
    I get the same problem. I have the latest drivers for my OS (Vista Home Basic), installed correctly (reinstalled a few times now just in case) and I tried your solution as well, I'm also having the same problem with the print queue not clearing. It says its deleting, but never does. I need to turn off the printer, manually delete the print queue, then turn the printer back on to be able to print anything else.
    Normally, when I hit the scan start button, the Lexmark software pops up and asks where it wants me to save. Now, the scanner does nothing and the LCD screen on theprinter goes back to the selection screen. Nada. Any ideas? I find it odd that so many people have just recently, in the last coupe of months, have started having this problem. This has to be from a Vista update, wouldn't you think?
  • ayam03 May 08, 2008
    I have the problem where it says where to scan but then nothing happens.........i tried ressting and unplugging and reinsatlling again n again..nothing helps........
  • alpha5 May 31, 2008
    Recently bought a new computer with Vista installed. Downloaded Lexmark x6170 driver from mfr website. Can print, but will not scan, the printer says it is scanning but nothing happens.
    Sergeant:
  • 390 Answers
Try resetting it by turning it off and unplugging it, reverse steps and try again. If no go, try claering print queue, if this fails, get your driver disc and uninstall the cheeky beggar and reinstall it. cheers lilacgerry xxx
Posted on Feb 10, 2008
Engine malfunction light comes on it says acceleration needed or sometimes says acceleration low car still seems to drive ok
1st thing you do is have the engine control system scanned for the fault code that was set when the light came on.
Jun 13, 2018 | Cars & Trucks
2005 saturn relay check gas cap, transmission slip, temperature high, running rough. All this started wed morning. after 22 min of driving with one stop at the store in the middle. What should I do?
Having it checked for DTC's - diagnostic trouble codes should be the first step. And viewing scan data , do you know what this is ? Do you have a scan tool ? Not a code reader . Hook up scan tool an view engine data.
002 Fuel System Tests Start Here
002 OBD II Status Indicators and Codes
002 Introduction To EVAP Systems
Is there a way to narrow it down. Yes ,learn how it all works !
Jul 27, 2017 | Saturn Cars & Trucks
Xwhat deactivates asd system on 98 jeep grd. cherokee
my guess this post is , engine cranks ok, but wont start or only runs for 3 seconds. right>? why not post the symptoms first? huh?
many things, will cause the ASD to drop out.
what this relay does, is prevent fuel fires. and is part of secuity system if opted
so there are up to 8 reasons,
i guess you dont have a $9 scan tool>? and didnt scan the PCM cranking.
this page is and all year 93 to now,integrated page.
no need to worry that, only scan it, and see whats really going on.
http://www.fixkick.com/Jeeps/ASD.html
does the ASD relay pull in at all?
or only 3 seconds cranking
that be first to state.
Oct 02, 2014 | 1998 Jeep Grand Cherokee
My suzuki grand vitara ddis diesel 2008 lost power and a zigzag light appeared but the next day it was ok the garage did not find any fault codes
tool late now.
you'd need to drive with scan tool attached then see what code
set (DTC) at failure.
can be lots of things.
bad fuel, partial clogged filter.
injector clogs. and other sensors errors.
and others, this is common rail injection system, right?
get a scan tool, and have it always ready. for fails.
Feb 27, 2014 | 2000 Suzuki Esteem
My alarm is not locking
The dealer must scan the security system and see what is causing this.
Oct 10, 2012 | 2007 Honda Accord Sedan
Playback is choppy and it runs up my processor to 100% just from watching 1 video online or from my videos
1) Check your pagefile memory. to do this right hand click on My Computer and choose properties. Go to ADVANCED/ Performance Settings/Advanced Performance Options/ Go down to Virtual Memory and click on CHANGE. On each drive in the box, highlight it and choose "System managed size". Press ok/ Apply & OK, and Restart Your System.
2) One thing i feel i should tell you, is that your system MAY HAVE A VIRUS. Try scanning with Malwarebytes Anti-Malware Remover Tool just to be sure.
3) I recommend that you run a Full Diskcheck and do a DEFRAG ON ALL DRIVES AS WELL.
That should Definately Do It.. OK? GREAT LUCK & PLEASE DON'T FORGET TO RATE MY RESPONSE OK? THANKS LUCKY4LYNN2
Mar 10, 2010 | HP Pavilion dv2810US Notebook
No scan options.
HI,
this is a very normal problem with this printer..do one thing unplug the USB cable from the printer..then if its not working go unplug the USB cable..insert the CD go to my computer..right click on the cd icon explore>>util>>ccc>>uninstall l2..after that restart the system...do a complete installation..issue will be resolved...
Jan 21, 2010 | HP OfficeJet J4580 All-In-One Laser...
Wscript.exe and other .exe popping out
It sounds like you have some computer-virus or something similarly-bad on your computer.
With Internet Explorer, access: http://www.ca/com/virusinfo and run the free virus-scan and the free spyware scan.
Nov 23, 2009 | Microsoft Windows XP Professional for PC
My HP pavilion tx 1000 keeps rebooting it self over and over. I reinstalled the System Recovery DVD and it turn on for a few minutes and the reboots itself
scan your system for viruses if this doesn't solves the problem then try replacing the ram or check it using memory diagnostic tool
if every thing above is ok
==> reinstall operating system thats it
Jul 09, 2009 | HP Pavilion tx1000z Notebook
Lexmark X6170 All-In-One InkJet Printer Logo
88 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
