Question about Jenn-Air SCE30600 Slide-In Electric Kitchen Range
Oven element The bottom oven element on my Jenn-Air SCE30600 range won't come on, but the upper one does. I just replaced it, but to no avail. What else could be the problem?
  • jojeeka Nov 23, 2008
    My element went out but I am not sure how to open it to get to the element (without a lot of trial and error.) How did you open it to replace your element?
    President:
  • Jenn-Air Master
  • 2,651 Answers
Bad relay on erc(electronic range control), or and open thermaostat wired in line with element you would need to pull unit and check wiring
Posted on Feb 23, 2008
Jenn-Air oven shuts down after FC and F5 errors
Their was a good possibility that the solder could have been lifting of the contact points on the board, if the symptoms return i would check this, along with the said cleaning method :)
Mar 15, 2014 | Jenn-Air SCE30600 Slide-In Electric...
My JENN-AIR oven will only heat to 250 degrees.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jul 06, 2011 | Jenn-Air SCE30600 Slide-In Electric...
Jenn-air sce30600 just replaced membrane offswitch
sounds like more than switch issue probably main circuit board!!!! :) have you tried jenn aire support?
Jul 07, 2009 | Ovens
F2 CODE OVEN OVERHEATS NO CONTROL
Try a new sensor 1st, then you may have to replace the ERC. Sensor usually solves.
Apr 14, 2009 | Jenn-Air SCE30600 Slide-In Electric...
Jenn Air Range SCE30600
i would pull unit out adn look for a bad thermostat on back wall wired inline from bake and broil elemnts, probably tripped during a clean cycle or something got to hot, common for oven to shut down because of bad safety thermo, yet stovetop function without interuption
Nov 26, 2007 | Jenn-Air SCE30600 Slide-In Electric...
Jennair range
f-5 means the clock/oven control is bad. the only way to fix this is to replace the oven control
Oven temperature
yes there is a sensor its either on the top or in the back of the oven under a power distribution box you will need a professional to do the repair its easy to damage the control computer in the oven
Nov 08, 2007 | Jenn-Air SCE30600 Slide-In Electric...
Display not working
the most common remedy is to replace the LED readouts in the oven they burn out they are light emitting diodes, that sometimes dont last long.
Apr 02, 2007 | Jenn-Air SCE30600 Slide-In Electric...
Jenn-Air SCE30600 Slide-In Electric Kitchen Range Logo
135 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
