Question about Bosch 23 in. SHU33A Built-In Dishwasher
Bosch dishwasher,exploded parts view,SHU33A05UC/46
I can't find a parts break down,anywhere on these sites,I would like to see where? the condsation tube connects to,also where the drain out flow from the washer to the sink drain also connects to?...we just bought this unit second hand from a lady, and she didn't have much info to help us with.I have one hose,ribbed, with a "0" ring on one end,and it is about 4' long,it looks like it will fit where the 3 connection manifold (plastic) spigot is at,(2 larger connections, and, 1 smaller connection with a small hose already connected.) other than that,I think I can figure the rest out...also a parts number/description..relavent to any diagrams that I can view on line..if possible...thank you
5 Suggested Answers
SOURCE: bosch 3000 dishwasher
Don't. Just attach your hose and the end of the Bosch hose together. Just wind up the Bosch hose and tape it to the back of the machine.
Posted on Jan 15, 2008
SOURCE: Bosch dishwaasher installation
I have overcome the problem by fitting a old style hose fitting (non threaded taps) for garden hoses (rubber end with built in clamp)and clamped it on to the hose and then onto the drain pipe. Available Bunnings for $10.00
Posted on Jul 24, 2008
  • 19396 Answers
SOURCE: There are two hoses coming
The air venting hose must not necessarily be connected to anything. What else is wrong with the appliance?
Posted on Aug 28, 2008
  • 2341 Answers
SOURCE: A few days ago our
Hello Micheal,
The F4 error code refers to a filling error on that dishwasher.
Did ya accidently turn off the water supply the otherday while clearing the drain on your disposer,the reason i ask that the not filling and the humming to me sounds as if the water valve is on and humming and calling for water yet it has no water coming to it. A humming sound on the water valve is normal its the sound of the soloniod that opens it to let the water flow..the reason ya dont hear it when the water is filling is because the sound of the flowing water muffles the hum.
Check that the water flow is good into the dishwasher and the line isnt perhaps pinched or kinked somehow
Posted on Sep 18, 2011
Dishwasher LED not lighting and dishes not cleaned
If it's making a sound, that means you have power. You may need a control board or a console or both. Check the ribbon cable between the console and the control board for any loose connections. If everything is fine, replace the parts.
Mar 12, 2014 | Bosch SHU33A05UC Stainless Steel...
I have a Bosch dishwasher, model SHU9915UC/U11. The spring mechanism on the detergent door cracked, and I bought the part to replace it. I took the front cover off of the dishwasher to determine how to...
Hello! This is Guru...Saailer...I have your information...Due to size limitations I'll need your e-mail address in order to send it to you...Send an e-mail to me and I'll send an exploded view diagram and parts list...Guru...saailer...
Jan 23, 2011 | Bosch SHU9915UC Dishwasher
Dishwasher does not drain, drain hose at the garbage disposal has been cleaned and air gap is clear.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
Nov 11, 2010 | Bosch SHU33A05UC Stainless Steel...
I need to look at bosch SHU5312UC exploded viewe of the door
I think I know the pieces you are referring to and you can only install them one way. I can direct you to and if you enter your model number you should have access to several breakdown illustrations of your d/w however, I`m here to tell you, don`t sweat it. Most illustration`s I`ve seen don`t even show them either.
Those two blocks ( which slide into the front of the hinge behind the door panel by the way ) can remain left out without any functional consequence to your dishwasher. In fact the regional training representative for north america used to joke with us techs how he had a collection of them from tossing them into his toolbox instead of putting them back in place. They do increase the structural support of the front panel, but unless you plan on moving it around frequently, I wouldn`t worry about it.
If you are still concerned, post back with your email and I can send you a complete repair guide in "pdf" format for your dishwasher.
Hope this was helpful to you. Thank you for coming to "fixya" and please let me know if I/we can assist you further in this matter. Please take a moment and rate the info I provided for you here today.
Good luck.
macmarkus :)
Mar 30, 2010 | Bosch 23 in. SHU33A Built-In Dishwasher
Parts break down on hobart crs76a pump motor seals
Hi iceman,goto,create a username and type in your model under smart parts.You will be able to see an explode view of your model.I'm a hobart tech,any ? let me know----Tony
Nov 19, 2009 | Hobart Dishwashers
We have a +11 year old Bosch SHU3006/UC/U06 that never leaves the wash cycle. We had to stop it during our last test run at 3 hours. Chat advise is suggesting a water temperature problem (I origionall...
Check continuity of the heating element to see if it is broken/open.
The dishwasher prefers that the incoming water (water heater) be 120 degrees (F)
Apr 04, 2009 | Bosch SHU3036UC Dishwasher
Mdb7601aws dishwasher door drops down
hi there,
go to to get the exploded view for your model #. it will be the located under Repair Parts.
May 31, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Bosch dishwasher sgs43a52gb
it's pretty flaky and I didn't work when I tried to download a manual for my SRS43A02GB/08, but the parts-lists do.
If you go to the 'Launch the spare parts eShop' and enter your model number (you only quote it partially above, so you then need to select the particular model), you can see the exploded parts diagram - click right-hand icon 'print all pages' to get a pdf of all the exploded diagrams. You can order from here too and they seem a lot cheaper than alternatives, but I haven't actually bought anything yet.
May 20, 2008 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Bosch 23 in. SHU33A Built-In Dishwasher Logo
1,898 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
