Question about Motorola Mobility RAZR V3
Key Pad I was wondering how to get my Key Pad on phone to work?
  • tiger5297 Feb 08, 2008
    My key pad lights up there is no moisture but still does not work
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Please be more specific. Do the keys not work or are they not lighting up?
  • 52 Answers
Tiger, u gotta take ur phone apart, Using a torx screw driver (about 10 dollars at radio shack or walmart) and on the display side, remove the 4 screws with the torx screw driver, using some type of blade take apart the display, remove the connector with a knife or something really thin, and with some kinda brush (a tooth brush will work) brush the two sides of the connector since i m sure u ll see alot of moist in the same connector, and put it back together and that should fix ur problem.
Posted on Feb 07, 2008
Disable Keyless entry pad
The key is mechanical so disabling the pad would make no difference.
Nov 18, 2013 | Ford Taurus Cars & Trucks
Key pad is not working ...
My Dear Your Phone Key pad IC Fault So Please change Key pad IC
And Key pad Problem will Solved
Nov 28, 2010 | Sony Ericsson Walkman W205 Cell Phone
Nokia e66 keypad is not working
First Try it:
i hope Key pad Problem will Solved
IF Key pad Problem not Solved So
Secend Option:
Please New Software install in the Phone Problem will Solved
Aug 28, 2010 | Nokia E66 Smartphone
My keypad is not working properly! what should i do??
My Dear Your Phone Key pad IC Fault SO Please change Key pad IC
And Key pad Problem will Solved Quickly
Aug 18, 2010 | Nokia 1600 Cellular Phone
Keypad in w350i not working...how 2 repair tat
Remove the external key pad and press the internal keypad on the phone board directly, may be the external key pad rubber is not contacting the one on the phone board.
Or you can loose the phone, and clean the internal part of the key pad. There might be dust on it, you could also use this medium to service your phone. If it does not work after all these, then I think you have to change the key pad completely.
I wish you the best.
Nov 23, 2009 | Computers & Internet
Function pad doesnt work
try out the samsung official repair centre near your haouse
May 16, 2009 | Samsung SGH-T429 Cellular Phone
Key pad not working
dust may be accumulated in key pad if u can try opening the panel and cleaning it or the connector of key pad would have failed try changing it
Jan 20, 2009 | Sony Ericsson W200i Cellular Phone
White screen, key pad locks up Moto W490
Update the software for your phone for free.
Click on the following link:
http://direct.motorola.com/hellomoto/support/update/
Oct 24, 2008 | Cell Phones
Lg key pad not working
ur key pad domy is damaged so change it quickly
Feb 14, 2008 | LG KG800 Cellular Phone
Screen broken
From main screen:
Either 'a':
Press 'down' on your directional pad to open up the phonebook (default setting)
OR
Press the menu key and scroll down to the phonebook entry (I'm not sure if you remember where yours is, as I changed my menu around. My phonebook listing is the first one. Dunno if this helps at all)
Then, once you are viewing your contacts:
Press the menu key.
Press 'down' on the directional pad eleven (11) times to highlight 'copy'.
Press the center of the directional pad in to select the highlighted menu item.
Press down on the directional pad once to highlight the 'all to SIM' option.
Press the center of the directional pad in to select the highlighted menu item (MERGE)
OR
Press down on the directional pad once to highlight the 'OVERWRITE' option, and then press the center of the directional pad in to select the highlighted menu item.
Depending on how many contacts you have, this will take about 30 seconds per 100 contacts.
Jan 04, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Motorola Mobility RAZR V3 Logo
27 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
