Question about Brother MFC-5440CN All-In-One InkJet Printer
Unable to change error. Fax memory is empty and I can not locate any paper jam.
Unable to change.
  • 74 Answers
Change what?
Posted on Apr 15, 2008
Wont print from fax memory
You may have a blocked paper sensor. Check the path the papaer would follow and located the sensors. Check them for dust or torn paper. The machine will not print until the jam error is cleared. If disconnected from power too long jobs in memory may be lost.
Aug 12, 2014 | Office Equipment & Supplies
How to clear Memory?
If the memory is filled up when a fax is received ... when there's no paper, or it is jammed (so that it can't print) ... you can print the fax (in Memory, after putting in new paper, or fixing the jam) by pressing the START/MEMORY button. After it prints, the memory is cleared.
If the memory is filled up when you're scanning and storing a document into memory (to be fax out), press the START/MEMORY key to transmit the pages that's already in memory. After transmitting the content in memory, the memory will be cleared/emptied. You'll need to scan the remaining pages to transmit (as a separate fax)
Jan 18, 2014 | Office Equipment & Supplies
Panasonic kx-ft77 paper jammed and fax im memory
I have a problem with the fax machine in question is panasonic kx ft77 . When receiving a fax error expel warm up and stop receiving the document. Or does anyone know what the problem is and how to fix it ? Thanks in advance
Aug 16, 2013 | Panasonic KX-FHD331 Plain Paper Thermal...
Paper Jam unable to find
Open the back cover door, clean the roller.
May 17, 2010 | Canon FAX-L360 Plain Paper Laser
Brother Intellifax 2920 Error "Unable to Print"
Check the flux capacitor, those usually go out on brother faxes.
I just replaced mine last week, same problem.
Jan 05, 2010 | Brother IntelliFax-2920 Fax
Unable to clean message
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model.
This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue.
1.
Check for foreign objects, such as a clip or ripped paper, inside the machine.
Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
2. If the error continues to appear, the machine may have a mechanical problem.
If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. However, there is a way to transfer faxes in memory and the Fax Journal Report to another fax machine to print them out. Do the following to transfer the data and reset the machine...
Thanks.
Dec 29, 2008 | Brother MFC-5840CN All-In-One InkJet...
Unable to clean messgae
1.
Thanks.
Unable to initialize
To clear paper jams:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000400/000095/faq000495_003.html?reg=us&c=us&lang=en&prod=mfc420cn_us
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Sep 29, 2008 | Brother MFC 420CN All-In-One InkJet...
Clearing an error
well, one of two things have happened, 1. you haven't removed all of the jammed paper, maybe you left a small piece of a piece of paper or you may bent or broken your paper jam sensor. go through the paper path very carefully and check both things.
mikey
Mar 14, 2008 | Sharp UX-B20 Plain Paper Inkjet Fax
Cleaning troubleshoot needed
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model. This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue. 1. Check for foreign objects, such as a clip or ripped paper, inside the machine. Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely. 2. If the error continues to appear, the machine may have a mechanical problem. If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. However, there is a way to transfer faxes in memory and the Fax Journal Report to another fax machine to print them out. Do the following to transfer the data and reset the machine:
Jul 28, 2007 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-5440CN All-In-One InkJet Printer Logo
62 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
