Question about Curtis-Mathis CM32010 TV
V-chip or parental control
I own 2 CurtisMathes Model CM32010 my proble is the v-chip. I can't disable it and the television will only show PG-14 shows. I get a message excessive rating, what can I do?
  • 1 more comment
  • bateykat Feb 08, 2008
    The hard reset fixed the problem. Thanks!
  • Anonymous Feb 24, 2008
    i bought
  • 4decades Feb 24, 2008
    i bought a tv with the parental code on it already how do i break the code
    Master:
    Sergeant:
  • 440 Answers
SETTING V-CHIP
This TV is fitted with a V-CHIP controller which provides you with channel viewing access controls
and restrictions. This function is to prevent your children from watching violence or sexual scenes
that you may choose to exclude.
Press the MENU button and press the SET + or – button to select the V-CHIP SET option,
then press the ENTER button.
Enter your password (4 digits) using the Direct channel selection buttons (0-9).
In the event of entering incorrect password press the RESET button. Then press the
ENTER button.
Enter the same password for confirmation, then press the ENTER button.
Press the SET + or – button to select the V-CHIP option.
Press the ENTER button to select the ON.
Press the SET + or – button to select the TV RATING or MOVIE RATING option. Press
the ENTER button.
Press the SET + or – button to select the desired rating for the applicable video or TV
channel. Press the ENTER button.
And to change or put in a new password:
NOTES:
• If you want to change password, follow steps 1 and 2 and select "CHANGE PASSWORD"
option then enter your new password.
• The V-Chip function is activated only on programs and tapes that have the rating signal.
• Once you block a program using the V-Chip function, the blocked program cannot be watched
based on the content of the show. When the program starts, the "INPUT PASSWORD" will
appear on the screen. When you want to release the V-Chip temporarily, enter the password.
If you change the channel or turn off the TV while the V-Chip function was temporarily released,
the original setting will be resumed. If you return to the channel you were watching you must
re-enter your password to temporarily release your V-Chip function again.
• When you watch the TV from the cable box or the VCR with the RF Modulator, then you release
the V-Chip temporarily, the V-Chip setting will not be resumed until you turn off the TV. The
TV channel is not used in this case.
• When changing the channel with the cable box or the VCR, approximately 10 seconds will
pass until the program appears.
End of manual text.
try this thx nick
Posted on Feb 07, 2008
  • nick helpap
    nick helpap Feb 07, 2008
    Some sets will clear the password with a hard reset. This requires you to unplug the power cord and leave the set unplugged for at least 4 hours. See if that works.
Have protron pltv-32cm. model lt32c1m1. how do i shut off the v-chip block? i don't have the password.
Hello, there is a default password, if you source is in component 2 it can't be used here are some links to the pdf file pltv types.
V-Chip Lock When turned on, blocks access to mature television and movie content, based on the MPAA and TV PG ratings selected below, unless the viewer enters a password (set below). Set Password Sets the V-Chip password. To change the password, enter the current password followed by the new password. The factory-default password is '1234'.
PROTRON PLTV 32C User Manual Parental Controls
hope this can help.
Feb 21, 2015 | Protron PLTV-32 Television
We hooked up a jvs dvd player to our curtismathes tv now when we put a movie in it has a split screen and only shows in black and white
Check the format of recording on the disc you inserted in now. Check with an other known disc, and see the result. If both shows the same fault, check the picture setting by entering DVD menu.
Dec 10, 2013 | Curtis-Mathis CM32010 TV
PF2020 RESET CHILD LOCK
Turn your television and Apex DT250 receiver on.
Push the "Menu" button on the Apex DT250 remote control.
Press the remote's "Up" and "Down" buttons to scroll through the menu options. Stop when "Parental Controls" is highlighted. Press the "Right" button to select this option.
Enter your four-digit password. If you have not set your password, use the default code of "0000."
Use the "Up" and "Down" arrows to change or set the parental control movie ratings. You can select from "None," "G," "PG," "PG-13," "R," "NC-17" and "X." Once your setting is highlighted, press the "Right" button to go to the next screen.
Use the "Up" and "Down" arrows to change or set the parental control TV ratings. You can select from "None," "TV-Y," "TV-Y7," "TV-G," "TV-PG," "TV-14" and "TV-MA." Once your desired setting is highlighted, press the "OK" button to save your settings. Once the settings are saved, you will be taken back to the main menu. Press the "Exit" key to exit the main menu.
Oct 31, 2012 | Apex Digital PF2020 20" TV
42 inch flat screen shows v-chip block tv-14 lsv what does that mean? tv fades tremendously turns blue then shuts off
V-chip Block
TV- 14 - this is a rating for movies and TV programs. Basically means PG-13 like the old movie theater rating.
lsv- means, language, ***, violence.
You TV can be set to block these programs.
In you menu look for a catagory called "locks" or "ratings"
there you will find the options of what can be veiwed and what will be blocked.
if you everything to be available, just disable all settings.
if you want to choose different things to be allowed, just click on the icons and they become blocked.
Apr 12, 2011 | Olevia LT42HVi 42 in. LCD Television
V-chip activated
Hit the Menu button on the TV. 2. 'INPUT SECRET No.' should appear. 3. Press and hold both VOL (+) and CH DOWN (9) on the TV set simultaneously until the message 'INPUT SECRET No.' disappears. 4. The vchip settings should be disabled now and the Parental controls menu should be presented, 'disable' Status if need be.
Mar 14, 2010 | Sharp 32C-240 32" TV
XBox parental control
goto xbox.com and login and turn off parent controls from there
Sep 18, 2008 | Microsoft Xbox Console
Parental Control V chip has been activated.
on my Sharp 36R-s400. Go to menu , then parental control. When dispaly asks for secret number,
press and hold volume up and channel down simultaneously until message is cleared.
This turns off parental control and clears the password.
Sep 06, 2008 | Sharp 19R-M100 19" TV
Resetting V-Chip pin code
I don't know the sharp(mfg) code to activate my universal remote
May 12, 2008 | Sharp 27U-S60 27" TV
Vchip
If you can get into the menu, and know the proper password, then you can change the parental control setting. If not then the memory chip may have to be replaced. Stargazer
Aug 05, 2007 | Samsung TXN2726 27" TV
Message protected program by tv-pg
Go into Menu /V Chip arrow key up to tv rating should show all locked volume down or visversa should should view all Note may have to volume up to get to options from menu depending on how old the tv is.
Apr 04, 2007 | Emerson EWV403 VHS VCR
Curtis-Mathis CM32010 TV Logo
407 people viewed this question
Top Curtis-Mathis Televison & Video Experts
matt martin
matt martin
Stan Skaggs
Stan Skaggs
Are you a Curtis-Mathis Televison and Video Expert? Answer questions, earn points and help others
