Problems with dimming picture on Hatchi Rear Projection Televisions
I have problems with dimming picture on an Hitachi Rear Projection Televisions if I don't have the Brightness control turned all the way up.
  • michaelwa42 Feb 08, 2008
    It Is about 5 years old HDTV but not DLP. It has red, blue and green CRT lamps.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 208 Answers
What is the model of your Hitachi and how old is it? If is a DLP you lamp is going to need replaced.
Posted on Feb 07, 2008
  • Les Price Feb 09, 2008
    As a crt set ages the crts get weak and the screens may need to reset. Behind the front speaker grill (which in most cases will just pop off) you will find a panel that can be removed. You should find a small block assy with 3 screen controls and 3 focus controls. Make sure not to adjust the focus controls. The brightness level can be raised by adjusting the screen controls up. To do this you should turn off the color on the picture because you want to adjust all three colors evenly so that your brightness level increases but you need to maintain the gray scale or keep the picture black and white. Not to green, blue, or red. If this is not effective then you may have a failure in the video circuit and a tech will be needed.
I have a sony 52 inch wegagate dlp ty that has a dim picture what could be the problem?
If its a Sony and a DLP a lot of times just before the lamp life ends it gives a darker or dim picture---if it gets dim enough set will shut down.
Nov 06, 2012 | Hitachi 50UX57B 50" Rear Projection...
Picture quality is dim. There's also a continuous crackling sound emanating from the rear area, I believe in the area where the lamp goes. Is this merely a lamp problem?
check the lamp ballast board which may the cause of dim and crackling sound. check for bad high voltage transformer and dry joints connector at the ballast board.
Sep 07, 2012 | Hitachi 50VS810 50" Rear Projection HDTV
Hitachi LCD M50VS810 -- picture gradually darkened up over the past 4 days and now picture won't come on. Replace bulb?
If it uses a lamp that is possible---sets with a lamp will often dim down just before the lamp fails in a total way.
May 16, 2012 | Hitachi 50VS810 50" Rear Projection HDTV
HITACHI 53FDX01BA THE PICTURE IS GETTING DIM. ALL THE COLORS LOOK GOOD EVERYTHING IS JUST GETTING DIM
This is a common problem on this Hitachi model. You can get the parts and repair instructions from www.TvRepairKits.com. In most cases the TV will look real dim or have no video...but audio will work,
Jul 18, 2011 | Hitachi 53FDX01B 53" Rear Projection...
Picture is dark
The projection lamp require changing.The lamp picture is dim the lamp is close to the end of it life.Require a new lamp.
Sep 01, 2010 | Hitachi 42V710 42" Rear Projection HDTV
I have a question, We bought our Hatchi 50 inch tv 3 years ago
The manufacturer normally doesn't count the lamp for the warranty, but call them definitely worth checking w/ the manufacturer. Otherwise if you need to buy a lamp you can try Discount-Merchant.com they have FREE trouble shooting available so you can check to make sure it is the lamp.
Apr 21, 2010 | Hitachi 50UX57B 50" Rear Projection...
Picture intermittently goes dim.
How many hours on the lamp timer?  If 10,000 or more the lamp is approaching end of life and should be replaced.  Lamp will dim when approaching end of life rather than just go out.
Jun 03, 2009 | Hitachi 60VS810 60" Rear Projection...
Tv picture
Unit has a bad optics block (light engine). Rebuilt engines available for around $350.00. I have seen this sympton several times and I am sure this is the problem.
Mar 11, 2008 | Televison & Video
Hitachi 61SDX picture got dim shows Code 3
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Nov 17, 2007 | Hitachi 61SDX01B 61" Rear Projection...
No power
common fault on hitachi is the -26 volt supply is bad,ther should be voltage markings near or around the led's,find the b+ one thats missing or being pulled down
Aug 12, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Televison & Video Logo
183 people viewed this question
Top Televison & Video Experts
