Question about Watches
How do change a battery of a watch?
It is a stainless steel watch.
  • Anonymous Mar 23, 2014
    stainless steel analog-digital digital working analog stopped
If you do not have the proper tools,(proper tools are recommended) and depending on the type of backing, this may help you :
  1. Locate a very small tab (or recessed area) on the edge of the back cover. This is the access point for removal.
  2. Get a kitchen knife with a rigid blade. It doesn't have to be razor sharp, it only needs to be inflexible. You can also use a small fine screwdriver.
  3. Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). Do not attempt to insert the point of the knife. Use the length of the blade.
  4. Get under the tab or recessed area and gently but firmly turn the blade upward, popping the cover off.
  5. Locate your battery(Small round disc type) remove and check the numbers on it. Go to most any local dept. stores (Wal Mart, Target, Radio Shack, etc.) and purchase same.
  6. Install battery with numbers up.
  7. Place cover over watch, and snap back into place.
Hope this helps. If not, please let me know and I will get back to you.
Posted on Feb 07, 2008
  • Rick
    Rick Feb 07, 2008
    Just an FYI, most of the department stores that you buy watch batteries from, also install them for you as well.
How to change battery -can't open case on Nouveau quartz men's watch
Take it to K-Mart jewelry dept. and ask them to take the back off to determine the battery you need. They'll do it and only charge you for the battery.
Jul 26, 2017 | Stainless Watches
How to change battery or remove back?
I would take it to a jewelry shop or watch store.
Aug 03, 2015 | Burberry Watch, Womens Swiss Stainless...
How to change a battery
If watch expensive, take it to Shop to get it changed , if watch waterproof, it needs to be changed at a shop, as when battery changed , shop checks that the watch is still 100% waterproof.
Mar 07, 2015 | Tw Steel Grandeur Diver chronograph Quartz...
Why can't I get my watch to run?
When was the battery changed last? If you have never changed it and even though it may be new, the battery can be old.
Jun 03, 2014 | Invicta Reserve Mens Bolt Zeus Swiss...
Need correct replacement battery
the watch movement deters which battery the watch needs it is very important you do not put a battery in that doesn't suit the watch as it can short out the circuit however you can get the correct size in a gold seal quality which should not leak, also the older the watch, the more demanding the watch becomes on the battery as the movement components start to experience wear and tear
Apr 16, 2014 | Wenger Swiss Military Alpine Diver...
Swiss Legend Chronograph Stainless Steel Case- how to change the battery
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving in doing it yours
Feb 24, 2010 | Swiss Legend Chronograph Stainless Steel...
I have a Seiko stainless steel ladies watch, 3 years old, only one 'winder' no fancy buttons, analogue style. It has suddenly started beeping every hour - how do I turn it off?
mcdevito75 here, The beeping must be a signal that the battery is weak, have the battery changed. Look for a small watch repair shop in your area for the battery change.
Nov 05, 2009 | Pulsar by Seiko watch PEG665Ladies...
Replacing battery on wenger swiss watch
Hate to say it but Wal-mart has the tools; seems like they'll do it for free if you buy the battery
May 27, 2009 | Swiss Army Wenger Wenger Extreme II...
I need to change the battery, how do I get the back off?
Go to any walmart jewelry department and they will change the battery for you, and show u how to take the back off.
Apr 29, 2009 | Nike Triax Armored II Men's Stainless...
Watches Logo
894 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
