Question about Frigidaire PLEB27T9DC Electric Double Oven
Frigidaire 2006 double oven top oven wont turn off
I have a frigidaire double oven that is less than 2 years old p/n 318201514 it is a 30" wide stainless steel electric. After christmas dinner cooking all day at 400 degrees, the top oven shuts off on the display but the next morning the fan was running and it was about 150 degrees inside. Now the only way to keep it from getting hot and turning itself on we must turn it off at the breaker. We are still able to cook anything we want, and whatever temp, but we are tired of killing it at the breaker box. What parts do I need?? I am frustrated because its a $2k oven and is just out of warranty help!!!
  • 66 Answers
You will need a top oven thermostat
Posted on Jun 16, 2008
I have a Frigidaire Caprice double oven, 45 years old, the inner glass panel on the top oven door has shattered. I am not having any luck with finding replacement glass, any ideas?
take a profile of the glass shape (cut out the shape from cardboard) and go to a glass supply shop ( glass windows , doors , shower screens etc)
they should be able to cut and then temper the glass to make it heat proof for the door
if they cannot temper it they should be able to tell you where you can get it done
Nov 12, 2016 | Frigidaire Ovens
F43 error on Frigidaire Wall Ovn?
The code F43 means - The cooling fan speed, as read by the tachometer input of the EOC-display board, is abnormally too slow. when the cooker is on can you feel the fan is on through the upper vent? If not then the fan is the problem if you can then the fan sensor is the problem!
Oct 21, 2014 | Frigidaire PLEB30T8A Electric Double Oven
Frigidair double oven electrical problems
Good Afternoon Friend,
I understand you are having electrical problems with your Frigidaire double oven, model# GLEB30T8A. I also see that this is the third time you have had a repairman out to reconnect exposed wires in your 2 and a half year old appliance. I suggest contacting the manufacturer directly. They might have some advice or might be able to point you in the right direction to having your double oven repaired for good. Hope this is helpful.
-Best Regards-
WP
Jun 20, 2014 | Frigidaire GLEB30T8A Electric Double Oven
Pleb30t8ccb
I see that your Frigidaire double oven, model# PLEB30T8CCB, is having trouble with the top oven not heating.
I suggest giving your double oven a hard reset by cutting the power at the circuit breaker for at least 2-3 minutes.
After restoring power you will need to reset the clock. You will do this by entering in the time and pressing start.
Turn the oven on to heat up, and if it does not, I suggest either contacting the manufacturer or contacting your local authorized technician to diagnose your appliance. Hope this helps.
-Best Regards-
WP
Jan 09, 2012 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire Caprice Oven won't work
i have a double caprice oven and the top oven wont go - something to do with timers
can u help
May 12, 2009 | Frigidaire FEB27S5A Electric Single Oven
F8 / Convection portion of top oven doesn't work
F8 Oven door lock failure Check lock relay and door switches.
Apr 02, 2009 | Frigidaire 27 in. Electric Gallery Pro...
I have a Frigidaire Custom Imperial double oven which still works gret after all these years. But, the clock just died which means the timer doesn't work or the clock to turn the oven on using the timer. I...
A Frigidaire Custom Imperial double wall oven, circa 1966-1970, custom installed into brick wall needs to be replaced, in my home's kitchen. Is there a double wall oven currently available to replace the 1960's which measures less than 21 3/4 in. wide, 443/8 in. high, & 24 1/2 in. deep?
Mar 24, 2009 | Ovens
Kenmore Model #790 - smooth top range
Probably not. It sounds like your broil element burned out. This just happens sometimes. If it is this , it will have visible chunks missing. Yes, It shorted with enough force to blow the main fuse. Unplug it as sometimes it can still be live and sparking when power is restored. Element is fairly cheap usually less than $50 and you can fix it yourself.
Jun 19, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidaire PLEB27T9DC Electric Double Oven Logo
240 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
