Question about Ariston Technologies AWD121WH
New Ariston wash cycle
Everything is fine ...but when it is washing is it supposed to continually start and stop. It is filling and draing properly ...but it spins (washes) a number of washing this correct?
I am planning to buy this machine but who in Atlanta can help me install it?
Posted on Apr 05, 2008
This is exactly the way the systen is designed to work. It uses very little water so the machine sort of flips the clothes over and lets them soak, then flips them again. Every thing is fine as as it should be.
Posted on Feb 07, 2008
AMD 121 won't shut off, or change cycles. Continuously "hums".
Did you try just unplugging from the wall outlet, and let sit for 15 seconds and plugging back in. Sort of like a re-boot on the computer? Just a suggestion.
Jun 30, 2014 | Ariston Technologies AWD 121
Machine does not seem to be filling properly, then does nothing else.
Sounds like you're fill valves are junk which sadly happens allot. This video is very generic but should give you an idea
Jul 06, 2017 | Hotpoint Ariston Aquarius WD420 Front Load...
Machine will not finish cycle and water remains in washing machine
if the washing machine does not drain, continues to fill or fill too slowly the issue could be the pressure switch. if you have a multimeter use it to find any electrical issues if there is no reading the pressure switch needs to be replaced
Jan 29, 2011 | Ariston Technologies Ariston AWD12 Front...
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Spin/drain cycle won't start
If the timer gets to the rinse cycle and stops,
Check the lid switch for continuity. If no continuity replace the lid switch.
If the timer continues through rinse and spin without doing either, replace the timer.
May 21, 2009 | Kenmore Washing Machines
Washing machine stops on spin cycle
You need a new drain pump.
May 04, 2009 | Washing Machines
Calypso - water goes straight to drain hose-not drum
the hose may still be filled from last cycle. try to put machine in final spin mode where all water from previous wash will be spun out the drain hose. once a siphon is started it can only be stopped by introducing air into the drain hose.
Sep 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
My washer won't stop draing as it fills
Does the washer makes a full cycle properly and only problem is water's constinously draining ? If this is the phenomena, verify that the pipe discharged to the drain hose (the pipe that water going out from the machine)is at washer height up to one foot higher. Goog luck !
May 25, 2006 | GE WBB4500EWW Top Load Washer
Ariston Technologies AWD121WH Logo
70 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
