Question about RCA OPAL M4001 MP3 Player
Connecting Usually when I plug in my OPAL to charge, a window with some options pops up or I can access the drive through "My Computer" but nowcan't get to the files through my computer. Help!
Hi, you can try to upgrade the player's firmware, you can download it from the RCA Website (connecting - moz-screenshot.jpghttp://support.rcaaudiovideo.com/downloads.aspx?product=187), the firmware it's the second app listed.
If your computer doesn't recognize the player, you'll have to turn it off and keep "PLAY" pressed for 10 seconds while connecting it to the USB port, then update the firmware.
Posted on Feb 07, 2008
How do i delete songs on my opal
When you connect the opal a window should pop up and on your media player on music an icon says opal. Click it and then click music. The songs in your opal show. Right click and press delete or remove from list.
Mar 18, 2009 | RCA OPAL M4001 MP3 Player
RCA OPAL WON'T CHARGE-SAYS BATTERY FULL BUT....
Try this: disconnect the player from the computer, turn it off Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 23, 2008 | RCA OPAL M4001 MP3 Player
RCA Opal M4002A Won't let me access playlist without shutting down
You need to re-image your firmware--it sounds like something is corrupted there. I have seen this behavior on other mp3 devices in the past; sometimes it requires special techniques to reset the device. Let's hope this isn't the case with your Opal--RCA was rude enough not to provide a handy reset procedure.
If you are daring you can try to replace the firmware files directly on your Opal using your son's files. You need to enable viewing of hidden files to do this: Tools-->Folder Options...-->View-->Show Hidden Files and Folders. Also uncheck "Hide protected operating system files (Recommended)" and say "Yes" to the dialog that pops up. You can change these back later. For MacOS X, open Terminal, then type "defaults write com.apple.finder AppleShowAllFiles TRUE", push Enter, Option-click (and hold) the Finder icon, then choose Relaunch.
Now, simply copy your Opal's files over to a local directory on your hard drive (this is a backup so you can't make things worse), and then copy your son's Opal files onto your Opal. The files should be as follows:
autorun.inf
playqueue.dat
pmp_usb.ini
RAMLIST.DAT
SETSTOR.DAT
STDBDATA.DAT
STDBDATA.IDX
STDBSTR.DAT
STDBSTR.IDX
All of these files should be placed in the root of the drive--in the folder on the Opal that also shows folders like "Audible", "FMRecord", "Music", "Pictures", etc. After the transfer, stop and unplug your Opal. Try to turn it on and see what happens. If it looks OK, try to hook up to it with Windows Media Player. If you are still having trouble, use the firmware from the RCA website--even if it is the same version. Failing that, you may need to have the device serviced or replaced.
Good Luck!
Mar 26, 2008 | RCA OPAL M4001 MP3 Player
RCA OPAL M4002 mp3 player
Mar 20, 2008 | RCA OPAL M4001 MP3 Player
RCA Opal M4008A
I had this problem.  Backing up data wasn't a concern though, as I hadn't anything on the OPAL yet.
First I let the OPAL charge up for 3 hours.  Then I made sure it was powered off.  I had previously downloaded onto a PC the firmware update for the M4004 which also works on the M4008 and other OPAL's.  I plugged the OPAL into the PC, and booted up the PC. After installing the firmware package in the PC, you get an install screen for the new firmware with a format option for the OPAL.  I selected that option, but the "start" button was greyed out as the PC still couldn;t see the OPAL.  I pressed the reset (paperclip in the back of the OPAL) for about 15 seconds, than held down the "Play" button and waited.  Eventually the software recognized the OPAL, and started to format it.
If you get a dialogue to restart the PC, press NO!  You have to read the instructions that come with the install. Eventually I reformatted the drive, and installed new firmware.
BTW, there was no picture folder after I did this, so I just created a new folder named picture and it worked fine for the thumbnail pics I threw in there.  Also when I use a MAC with the OPAL, I power the MAC up with the OPAL off but attached.  After drag and dropping files into the OPAL, I power down the MAC.  After power down the OPAL will after a pause give the "building databases please wait" messages, then when done go to the start menu.  It is difficult on a MAC to eject the OPAL, it just reappears on the desktop so shutting down is the only safe way to administer the device.  But to update firmware, which is easily corrupted BTW if you unplug the thing at the wrong time,  you HAVE to do it on a PC operating system. Might work on an Intel MAC with a PC OS though.
Hope this helps.
Dec 29, 2007 | RCA OPAL M4001 MP3 Player
Help please
my rca opal want come on when i charge it
Dec 27, 2007 | RCA OPAL M4001 MP3 Player
Error??
In Windows XP, rt click my computer. Scroll down to manage and click. Find disk management on the left and click. Your player should show up as a disk drive and you should be able to formt it here.
Dec 16, 2007 | RCA OPAL M4001 MP3 Player
RCA Opal
when you plug it into your computer either windows media player of yahoo music jukebox click to transfer information from the mp3 to the computer and look under opal then songs and all your songs will be listed and just right click and press remove.
Nov 25, 2007 | RCA OPAL M4001 MP3 Player
RCA OPAL M4001 MP3 Player Logo
18 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
