Question about Frigidaire 24 in. FDB126RB Built-in Dishwasher
Frigidaire 24" fdb641rj dishwasher
Water only gets 3/4 way up to top rack. checked pump ok ceck ball seems ok. ran without ceck ball not enough pressure to spin top arm. what else can i do
    President:
  • 1,314 Answers
The check-ball runs the top spray arm both arms don't run at the same time and that's the correct fill for this model whats your problem
Posted on Feb 17, 2008
Why are my top rack dishes not clean at all?
It is likely that sufficient water is not coming from the top arm. These dishwashers oscillate the water flow between top and bottoms sprays alternatively. This ensures water is pumped with adequate force. It is possible this mechanism is not working correctly. The device called check ball item 58 in this diagram actually does this function. The ball might be out of shape or not sitting properly causing incorrect wash water movement.
http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Dishwasher-Parts/Model-FDB1050REC0/1428/0130000/R0505129/00004?blt=06&prst=&shdMod=
Apr 30, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
TOP RACK NOT CLEANING DISHES
Possible that the motor impeller has good particles in it, causing poor water pressure, which would be most evident on the top rack. You would have to remove the spray arm, then the filter, then the torx screws to get at impeller....unfortunately, that model of dishwasher isn't the greatest in the first place for washing, since it only has the one spray arm.
Apr 04, 2010 | Frigidaire 24 in. FDB126RB Built-in...
Top water injector not working
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 24, 2009 | Frigidaire 24 in. FDB126RB Built-in...
Spray arms do not turn. water to them but not
Aug 23, 2009 | Bosch 24 in. SGS43C12 Classixx...
The top rack is not getting clean.
This is one common possibility
It may be the food chopper assembly. Mine broke last year from a toothpick,
the food doesn't get chopped because the blades are broken, then the filter clogs and water wont spray high enough.
Heres a test--turn on the dishwasher and wait until you can hear water running then open the door really fast and look at how high the water is spraying--there should be alot of water all over the top rack running down
Jan 31, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Frigidaire FDB740RCS0 Upper Armnot Turning
the motor stops and runs in the opposite direction to pump water up to the top rack. you first need to listen for the motor to stop and start. if you hear that open the door and try to tell if water was coming out of the top spray arm.
Nov 01, 2007 | Frigidaire 24 in. FDB1050RE Built-in...
Water not going through spray arms
1.does motor run? no. replace motor. 2.open door and leave the bottom rack inside dw.spin the spray arm underneath the bottom rack by hand. it should spin freely without binding. if it doesnt spin freely take out the bottom rack and try again. if it does spin freely then your bottom rack is laying on your sprayarm preventing it from rotating. 3.you could also not be getting enough water into your dw.
Mar 21, 2007 | Frigidaire 24 in. FDB421RF Built-in...
Figidare dishwasher
Maytag MDB4000AWW dishwasher:
Neither bottom or top arms seem to be rotating during wash cycle and dishs do not come out clean!
Wayne Wheeler
Jan 24, 2007 | Frigidaire 24 in. FDB435RFR Built-in...
Frigidaire 24 in. FDB126RB Built-in Dishwasher Logo
189 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
