Chaintech SK8T800 Motherboard Logo
Posted on Jan 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CPU upgrade, Sempron 2800+ to Athlon 64 3700+ mobo settings?
Trying to upgrade from Sempron 2800+ to Athlon 64 3700+. Manual says set jumpers according to manual or silkscreened on momo. I found neither. What to I need to set and where do I set it? Just plugging the CPU in and powering it up didn't work.
Anonymous
Level 3:
Genius:
  • Master 1,400 Answers
  • Posted on Jan 09, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1400
Questions
Helped
392900
Points
4210
Http://support.amd.com/us/psearch/Pages/psearch.aspx?type=2.1&product=2.1.1&contentType=KB%20Article
Here is a link to amd.The jumper setting are more motherboard related.
Try going to the motherboard homepage.
5helpful
2answers
Cpu Models to upgrade Compaq Presario sr1920nx
CPU/Processor
  • Socket: 939
  • Supports the following processors:
    • AMD Athlon 64 X2 up to 4800+
    • AMD Athlon 64
    • AMD Sempron
CPU/Processor
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
CPU/Processor
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
Cpu/Processor Type
Socket: 939
    • AMD Athlon 64
    • AMD Sempron
3helpful
Have a SV266M MOBO. w/amd Athlon XP 1700 CPU. I want to upgrade
i could only fins thease specs for you
AMD Athlon up to 2400+
AMD Athlon XP up to 2600+
AMD Duron up to 1.8GHz
1helpful
2answers
I would like to find the spec manual and what cpu slot it has.
I tried to get the exact link, but the website will not allow it.
Go to this page, and put in your model number, and you will find it really easy.
http://support.asus.com/download/download.aspx?SLanguage=en-us
This board is a socket A for AMD processors.
You will need adobe reader to get this manual.
Memory +cpu upgrade
No to the cpu you selected. Board would not support that cpu. The RAM you selected would probably work but for how long I couldn't say. With prices pretty low right now it would probably be better to purchase a new motherboard, cpu, & RAM. Hope this helps.
1helpful
2answers
Ram Upgrade
Max speed supported for your mobo is: DDR2-533
You will have to buy (4) 1gb sticks (2gb sticks not supported)
To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
Here is the specs :
ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
Chipset: Nvidia GeForce 6150 LE Chipset
HD Bus:
Front Side Bus options:
Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
Special notes:
- Motherboard manufacturer's name: ASUS A8M2N-LA
- HP/Compaq name: Nodus-GL8E
NOTE: *Actual available memory may be less w/o 64 bit os
Motherboard Jetway V880DAS, PCU Athlon xp 2800, Memory PC 3200 2Gb. Bios Update 880DASA7.BIN .Operating system Windows XP Pro with Service Pack 2 I Set the CPU FSB Jumper to 166 Mhz.The computer keep...
is this the first time you encounter this problem with the athlon Xp? i have encounter this already with my PC. you should update again the bios of your computer, and load the setting of your bios to the default settings.. try to restart your computer.. and try to contact me as soon if this works for you. thanks!
3answers
Processor upgrade
Need to look at the motherboard specs along with the processor "Socket". It will usually be a 754 or 939 depending on what your motherboard says. I wouldn't try too fast and set yourself up for disappointment. I would upgrade the RAM before the processor.
No singal after upgrade my cpu.
good pm...
have you checked your video (built-in or card) or your monitor sir?...does your mobo sir supports 2800 processors?i guess your mobo failed after doing so (upgrading from 1900-2800)...try to check it sir...hope this will help...
2answers
CPU model not recognized correctly
Any multiplier settings in bios? try using something like CPUID in your OS to see if it clocks faster then what bios tells you?
Cmos resetting
Ok so you know the bat is good cause you checked the voltage. You double checked the bios jumper making sure it is not set to clear. Looking in your manual you can go to AMD XP3200+, & you are under that. So either you have a short or your bios needs flashed because it's messed up. Could have went when the cpu died.
Top Chaintech Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Chaintech Computer and Internet Expert? Answer questions, earn points and help others
