Question about Mitsubishi VS-6043 60" Rear Projection Television
Mitsubishi VS-6043 - 60 inch
I Need To Replace My Cracked Screen Protector But I Can't See How To Remove The Frame Work To Remove The Old Protector......... HELP
Bob
  • Hoffnagle Feb 14, 2008
    Just Like The MAN Said ..... Fairly Simple ..... Perfect
    Thanks For The Help BOB
    Champion:
  • 206 Answers
These are fairly simple, remove the speaker cover and then remove the screws at the bottom of the screen, then the whole thing lifts up and off, be sure to unplug the front panel controls, this plug can usaly be found just behind the cover behind the speaker grill
Posted on Feb 07, 2008
I just broke the diamond shield on my 2002 mistubishi. I need someone to replace it.
these tvs have 3 screens, 2 functonal, and the 3rd is just a screen protector. mitsubishi makes them so you can remove the protector to eliminate glare if you want, and its customer removable. if this is the only one that cracked, remove it and you will actually have a better picture. you just need a small flat head screwdriver. pry of the little plastic pieces at the top and bottom (some are on sides) that hold the screen in. its just held in on 2 sides, and then you flex it to get it out. if it cracked into the 2 screens behind the protector, you've got bigger issues and the repair could get expensive. contact your local mits service center for quotes, but the screens are atleast 100 each, just for parts. let me know if i can be of further assistance.
Jun 06, 2010 | Mitsubishi WS-48413 48" Rear Projection...
Glare-can we remove plasting sheeting on screen?
yes, you need a philips screwdriver, pull the speaker grill off, remove the 4 or 5 screws along the bottom of the screen assembly, unlock the 2 electrical plugs and remove them from their ties, lift up on the screen assembly and remove it. turn it upside down and remove the 4 screws holding the bottom of the frame on, remove frame bottom, slide screen protector out, re-assemble, bingo, no glare.
Sep 08, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi VS-5046
i have a 50in mitsubishi tv model vs5046 the screen protector is crack the tv works fine but need to know where can i purchase a protector or its there a number. also how much will this cost.
Oct 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
REMOVAL OF OLD SCREEN
there should be metal brackets that hold the screen in all the way around the frame. there are usually 2 screws to each bracket..you have to remove all of them to get the screen off
Aug 10, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Replacing a screen on the mitusbishi
Hi NJ,
First, which screen do you need -
The lenticular screen is dark in color is rough and has ridges.
There is a fresnel screen behind it.
IF you have a screen protector that is smooth, clear and see through, it would be the very first screen you can see and feel.
If your TV is the square shaped, 4:3 ratio TV, Mitsubishi has probably stopped production on replacement lenticular screens. HOWEVER, we have a couple of those screens still in stock.
After you take the frame off, lay it on a table or put a sheet down on the floor before you lay the frame down. You may need to take the frame apart to get the lenticular screen out.
Hope that helps,
screentv
Jul 08, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Need replacement screen for Mits. WS-48511
The other site i am associated with has used screens for mitsubishi you just have to post the measurements of your screen top to bottom and side to side dont include the frame size as we allow 1/4 inch for fitting in the frame just need the size of the screen to the frame edge.
Mar 31, 2008 | Mitsubishi WS48511 48" Rear Projection...
Need to replace a cracked screen
WD-57731 & WD-65731 Front Disassembly
57” & 65” Models Screen Frame
Removal
1) Pull off the Speaker Grill.
2) Remove all the screws (b) from the
upper rear cover (except one at an
upper corner to support the frame).
3) Remove 10 screws (a) from the
front of the screen frame.
4) Remove the remaining ***** (b)
(supporting the frame). Carefully
pull the Screen Frame from the TV
and disconnect the ES and LE
connectors.
57” & 65” Models Screens Removal from Frame
1) From the rear of the Screen Frame remove 20 screws (a) from the top and bottom rails
2) Remove 6 screws (b) from each side rail.
3) Carefully lift the Screen assembly from the Frame.
MODEL: WD-52631 / WD-57731 / WD-65731
Screen Replacement
CAUTION: Wear gloves when handling the Lenticular Screen and Fresnel Lens.
This prevents cuts and finger prints. Do not place Fresnel Lens in the sun.
This may cause fire and heat related injuries.
Lenticular Screen and Fresnel Lens Replacement
1) Apply LENS-TAPE along the rear top edge of the Lenticular Screen.
2) Place the Fresnel Lens on top of the Lenticular Screen, and apply pressure along the top edge.
3) Place the screens in the screen frame and reinstall the cushions, top, bottom and side rails.
NOTE: The Lenticular Screen label must face the front and the Fresnel Lens label face the rear.
4) Reverse the Screen Removal Procedure and insert the screens in the Bezel.
Lenticular Screen and Fresnel Lens Removal
1) Remove the top, bottom and side HOLDER-SCREEN rails and their cushions from the Screen Frame.
2) Lift the screens as a single unit from the frame.
2. Separate the Lenticular Screen and Fresnel Lens.
Note: When separating the Lenticular Screen from the Fresnel Lens, use caution
while prying the Screen and Lens apart. Use a slot type ***** driver, and
remove the pressure sensitive double sided tape.
Mar 11, 2008 | Mitsubishi WD-65731 65" HDTV
Screen replacement
Post a email link and I will email you the page from the service manualshowing the disassembly proceedure.
Jan 27, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubushi Big Screen TV Screen Protector vs 60601
that will have to be a dealer orderd item.. Unless you can find one used. I would try the tv shops in your area , they may have a used mitsubishi screen
Jan 21, 2008 | Mitsubishi VS-60601 60" Rear Projection...
Televison & Video Logo
321 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
